Intruder Alarm System Application Note JN-AN-1201 Not Working!
3,841件の閲覧回数
davidashraf
Contributor V
Hello dears ,
I've been trying ZigBee HA Intruder Alarm System Application Note JN-AN-1201 but it's not working.
I am sure of the connections and everything as I tried other application notes and worked properly.
Any idea about where the problem might be ?
Thanks in advance.
3,567件の閲覧回数
limcb
Have you tried uncommenting CFLAGS in the device makefiles then rebuilding ?
It looks like no debug messages are sent on a clean install.
4 返答(返信)
3,567件の閲覧回数
limcb
What exactly is not working ? Which part ?
More information please.
What have you tried ? What did you expect ? What happened ?
3,567件の閲覧回数
davidashraf
Contributor V
It's not achieving the functionality described in the application note
Not even showing debug messages
3,568件の閲覧回数
limcb
3,567件の閲覧回数
davidashraf
Contributor V
It worked ..Thanks you!!
