Interoperability between KW41Z and KW24D
2,596 次查看
norishinozaki
I'm working with FRDM-KW41Z and FRDM-K64F+FRDM-CR20A Border Router but KW41Z can't join the network(FRDM-KW24D can join).
Isn't there interoperability between Kinetis Thread Stack 1.1 and 1.0.1?
BR,
Nori Shinozaki
标记 (1)
2,412 次查看
AleGuzman
If both MCU have the same Thread spec software, you shouldn't have a problem with a mixed platform network. I think the issue is the software versions you are using.
The KW41z public Thread release comes with Thread v1.1 spec.
I'm guessing you are using a beta version for the FRDM-K64F+FRDM-CR20A  software that is Thread v1.0 spec.
We are internal testing a Thread v1.1 spec release that will be ready by mid January. Once we launch this software you will be able to have FRDM-K64 border router with FRDM-KW41 devices
2,412 次查看
norishinozaki
Hello aleguzman,
Thanks again, yes I'm using a beta version for FRDM-K64F+CR20A.
Hope to get a next release soon!
Nori Shinozaki
