Inquiry about Calculating Complex Matrix on KW45 and Using Eigen Library in C++
Larry3
I'm currently working with the KW45 and have a specific question. I wonder if it's possible to calculate complex matrix directly on the KW45. Additionally, I'm curious whether I can call the C++ Eigen library for this purpose. I've searched through the available documentation but haven't found a conclusive answer. Any suggestions, code examples, or references related to implementing such functionality on the KW45 would be extremely helpful.
Christine_Li
Hi, @Larry3
Sorry for the inconvenience.
I worry currently KW45 doesn't have any code examples can be using to calculate complex matrix, and also we don't have Eigen library in default.
If you want to try, you can download Eigen library and import it into KW45 to see whether it can work properly. But it belongs to customized requirement, we could not provide further support on this.
I apologize for the inconvenience to you again.
Christine.
