Implementing Time of Flight (ToF) on KW45 Board
1,263 次查看
esmatt_07
I am currently working on the "digital_key_car_anchor" example on the KW45B41Z-EVK board using the Bluetooth module. Which peripheral is responsible for handling TX and RX using antenna as i need to implement ToF, also what are the necessary steps to correctly configure and use this peripheral?
1,241 次查看
nxf77486
Thank you for contacting NXP support.
In this case I would highly recommend to contact your NXP Sales or Distributor, to check if they have any information or details regarding this topic. That they can provide to you directly.
 I apologize for this inconvenient and please let me know if there is anything else where I can help you.
