IASWD communication problem
2,580件の閲覧回数
LChll
SDK:JN-SW-4170  V1840
JN-AN-1217
About IASWD device, there is data received and sent, but it cannot be executed into the callback function APP_ZCL_cbEndpointCallback E_ZCL_CBET_CLUSTER_CUSTOM:
  • Log displays when WD receives a command from CIE
How can I solve this problem?Thanks.
ad
ラベル(2)
3 返答(返信)
2,478件の閲覧回数
mario_castaneda
Hi Linklai,
Could you please provide the sniffer log?
Are you sending the data to the custom cluster?
Mario
2,478件の閲覧回数
LChll
Is sending to the IASWD.
ad
2,478件の閲覧回数
mario_castaneda
Hi Linklai,
Did you look at the eCLD_IASWDCommandHandler function that is calling when the device receives an IAS command?
Mario
