IASWD communication problem
2,586 次查看
LChll
SDK:JN-SW-4170  V1840
JN-AN-1217
About IASWD device, there is data received and sent, but it cannot be executed into the callback function APP_ZCL_cbEndpointCallback E_ZCL_CBET_CLUSTER_CUSTOM:
  • Log displays when WD receives a command from CIE
How can I solve this problem?Thanks.
ad
标签 (2)
2,484 次查看
mario_castaneda
Hi Linklai,
Could you please provide the sniffer log?
Are you sending the data to the custom cluster?
Mario
2,484 次查看
LChll
Is sending to the IASWD.
ad
2,484 次查看
mario_castaneda
Hi Linklai,
Did you look at the eCLD_IASWDCommandHandler function that is calling when the device receives an IAS command?
Mario
