How to use zigbee_ed_rx_on Project?
Viki
Hi all,
My software and hardware information are as follows:
1. The SDK version I use is SDK_2.6.2 _jn5189dk6.zip, and the routine inserted into MCUXpresso IDE is Zigbee_ed_rx_on;
2. The chip I use is JN5189 and the board is JN5189 USB Dongle.
I downloaded the compiled jn5189dk6_zigbee_ed_rx_on_bm.bin file into the JN5189 USB Dongle. After I pressed the reset key, the serial port would output the information as shown in the figure below.However, the JN5189 USB Dongle did not issue the Beacon Request wireless packet. I would like to know how to network the coordinator, router, and end devuce on the JN5189 USB Dongle using the ZigBee example provided by the SDK?
Thanks for your support!
stephanie_m
hello,
Could you please provide more details on what you are trying to achieve ? Do you have three different USBs and want to load a different firmware? Or do you want t add your current USB into a known network ?
regards,
Estephania
