How to import csv with valid NDEF file to program NFC chips by Tagwriter by NXP?
2,881 次查看
CarolK
Hello, Sir or Madam,
We want to upload a list of urls in csv file on Tagwriter to program NFC chips. But it always says invalid NDEF form in csv. Could you help how to program correct Urls‘ NDEF in csv file ? Thanks a lot!
Looking forward to hearing from you!
4 回复数
2,845 次查看
KaiLi
Hello @CarolK
Could you share with us the exact type of tag or card that you are using?
kelly
2,840 次查看
CarolK
Hello, Kelly,
Pleased to hear from you!
We are using NXP Icode slix chips. We have tried it can be programmed by Tagwriter.
2,820 次查看
KaiLi
Hello @CarolK
TagWriter does not support ICODE, it's recommended that you can switch to CLRD730.
https://www.nxp.com/design/design-center/designs/pegoda-smart-card-reader-based-on-pn7642:CLRD730
kelly
2,808 次查看
CarolK
Hello, Kelly,
What about using chip type of NXP NTAG213? How we use "Write from CSV"  to program chips? We hope to get answers from this part's engineer. Thank you!
Below url can see there is a function called "Write from CSV"? Please advise how to use, thank you!
https://kdocs.cn/l/coux8GLZYcVu
