How to Access SimpleMetering Cluster from Home Automation
2,224 次查看
tom_jacobson
I'd like my Home Automation Coordinator to send a ReadAttributesRequest to my SmartPlug devices, requesting the SimpleMetering cluster. Using the coordinator in the HA demo (JN-AN-1189), I've done a few modifications, trying to add the SimpleMetering cluster to the HA profile, then add the cluster to End Point 1 on the coordinator. Unfortunately, this causes the ZigBee module (JN5168) to crash and restart.
Can someone point me in the right direction of accessing the SimpleMetering cluster? It is a Smart Energy cluster, but it goes into Smart Plugs, which are a Home Automation device, so I assume it can be accessed somehow.
- Thomas
2,088 次查看
mario_castaneda
Hi Tomas,
Could you please take a look the next post, this will help you to add a new cluster, like SimpleMetering.
https://community.nxp.com/thread/437604
Hope it helps.
Mario
2,088 次查看
tom_jacobson
Thanks for the response, Mario. It turned out that I needed to register a few things I didn't realize needed registration (including the SimpleMetering cluster).
