How can I add my custom cluster、command and attribute?
2,574 次查看
374216459
     I want to add a custom cluster(0xFC00) to SDK(JN-AN-1216-ZigBee-3-0-IoT-ControlBridge),and I have edit the ZigbeeNodeControlBridgeCoordinator_GP_Proxy.zpscfg file as below:
I want the 0xFC00 cluster support server and client,and some commands and attributes
2,255 次查看
stephanie_m
Could you please check this post? ZigBee 3.0: Adding Clusters
I believe this will be helpful for you, nonetheless, you will need to take into account if your application will act as a server or client.
Estephania
2,255 次查看
374216459
I have add 0xFC00 Cluster to the 4170 SDK, and simple description response show it already support both client and server with 0xFC00 cluster,but when I read other attributes like manufacture name,it would‘t return "read attribute response",but it return the default response with status(0x84)微信图片_20180917130042.png微信图片_20180917130054.png
