HCE_T4T example : UID bytes (one byte defined by HW)
Hassan
Hello Friends !
in phApp_HALConfigAutoColl function, there is a call to the function : "phhalHw_Pn5180_SetListenParameters(pHal,&sens_res[0],&nfc_id1[0],sel_res,&poll_res[0],nfc_id3);"
nfc_id1 is declared as :
uint8_t nfc_id1[3] = {0x4E, 0x6F, 0x45}; /* UID bytes (one byte defined by HW) */
The comment says "one byte defined by HW".
Here is my question : how can avoid this by defining explicitly the fourth byte of nfc_id array ?
Thank you in advance.
Hassan
