GENFSK Programming Documentation
1,295 次查看
Brainiac
I’m encountering difficulties implementing GENFSK mode on your MCU MCXW716.
The process isn’t intuitive, and I haven’t been able to find clear documentation on how to configure and program the radio module in GENFSK, nor which SDK components (GenFSK stack, drivers, utilities, etc.) are required for a minimal setup Could you please provide:
A step-by-step guide to initialize and control GENFSK (bitrate, CRC, preamble, packet configuration, callbacks).
A list of the necessary SDK modules and example projects for a basic GENFSK application.
Thank you very much for your help!
标记 (1)
1,253 次查看
sofiaurueta
Hope you are doing well.
There are two documents that have all the related information to the GENFSK Link Layer as well as running the Connectivity Test demo application:
The "Generic FSK Link Layer Quick Start Guide.pdf" and the "Generic FSK Link Layer API Reference Manual.pdf".
I am checking about the availability of these documents, but you can refer to them on SDK v2.16.100 under the following path <installation path>\docs\wireless\GENFSK
Ana Sofia.
