FSCI: Map data channel in BLE
sensenthuran
Do you have any similar command to “LE Set Host Channel Classification Command” in FSCI so that we can map the data channel based on the WiFi operating band?   josmann‌michaelgoudey‌koonlee‌ kajac‌
Labels (3)
stephanie_m
I am sorry for the inconvenience this may cause you, but the functionality you are looking for is not supported through the FSCI or the stack.
Estephania
