Error when I used the END node send 16 doubles data at a time : No data written to APDU
4,469件の閲覧回数
GP_Mao
I am a novice in JN51 and I have encountered the following problems recently. Thank you very much for helping me  .
No errors when I send 15 doubles data  or 14 doubles data at a time ,15 doubles data  result:
errors when I send 16 doubles data  or 14 doubles data at a time 16_doubles.PNG
code:
ラベル(2)
5 返答(返信)
4,445件の閲覧回数
mario_castaneda
Hi @GP_Mao,
I hope you are doing great.
Could you please confirm what JN device are you working on? JN5169 or the JN5189?
What is the example or the AN that you are using? What is the SDK version that you have installed?
Mario
4,435件の閲覧回数
GP_Mao
HI  @mario_castaneda ,
Thanks for your reply!
I'm working on JN5169 , JN_AN_1217,The SDK is JN_SW_4107(Build 1840 ).
GP_Mao
4,422件の閲覧回数
mario_castaneda
Hi @GP_Mao,
I am not sure if I am following the issue that you are getting.
You have more options if you select your device and in the properties path the advance options.
I am not sure if I am following your issue, but you are not seeing the packets?
Mario
4,413件の閲覧回数
GP_Mao
Hi.@mario_castaneda,
What I want to know is  the maximum number of bytes  can be written to an APDU at a  time,How to achieve it?
GP_Mao
4,383件の閲覧回数
mario_castaneda
Hi @GP_Mao,
What is the value of your numwrite value?
However, please look at the B.1 Fragmented Data Transfers that explain a little bit more the process that you want.
https://www.nxp.com/docs/en/user-guide/JN-UG-3048.pdf
Mario
