Current consumption
Current consumption
motog
I have designed my custom board using pn7362 nfc ic. The current consumed by circuit in standby mode is at wakeup it is approx 1.1mA and in sleep mode it is 700mA. I have aded other components such as RTC, eeprom, motor ic etc as I'm using door access file for my application.
But the current consumed by the eval board(black board) is 600mA and 300mA, with the same code. I have another test board but without other ic it consumes 500mA and 250mA with the same code.
Can you suggest any changes in the mcu setting so that I can bring the current further down to match my eval board?? As I'll be using battery which will eventually drain I want to save power as much possible.
Thanks.
Tags (3)
fangfang
It is recommended that you first measure the power consumption of MCU, RTC, pn7362, EEPROM and motor IC in run normally and sleep mode. Please let me know if has the information.
Have a  nice day.
motog
Current consumption are as follows :
PN7362 - suspend mode -250uA
RTC - operating current - 700uA max; Standby current 5 uA
EEPROM - standby current 20uA
Motor IC - standby 45uA
I'm using controller in standby mode only.
If you require any other information please let me know.
fangfang
Thanks for your update information.
PN7362 and the components your provided have the normal current consumption. Please check your other components which has the higher current consumption.
motog
Hi @fangfang
It has been more than two weeks since I last got reply from you. As you can see I have provided you with all the details, I was hoping you could answer my query in some possible way.
Thanks!
motog
Hi @fangfang,
Did you find any reason which could explain high current consumption on my board??
Hope you can provide with some solutions!
fangfang
PN7362 has the normal current consumption. You may refer to the current consumption of MCU.  Hope it help you.
motog
Thanks for your help @fangfang .
I might have to look into other things which might be consuming current.
If you have any other suggestions please free to share.
fangfang
Hello
You are welcome.  Please don't hesitate to contact us if any question.
motog
The other remaining components are just antenna matching resistors and capacitors and diodes, which I dont think will be consuming high current.
