Create the wired connection between Mesh Module and BLE module
4,358件の閲覧回数
derbon43
Hello I am using Mesh Module ZigBee Mesh XBee-Pro® Long Range Wireless Mesh Communications Module & External Antenna - store.ncd....   which is using I2C connection to communicate wireless with temperature and humidity sensor, I am looking for BLE module and need to know the possible way to send data from Zigbee module to BLE module with wired circuit connection which is further sending the data to Bluetooth module connected with Arduino UNO, I am new to this work so looking for some leads to make create some useful circuit suggestions to make it useful.
3 返答(返信)
4,130件の閲覧回数
stephanie_m
You can check in this link  our available BLE solutions.
Estephania
4,130件の閲覧回数
derbon43
.Hey, Thanks for the reply, actually my main motive is to connect ZigBee receiver with BLE device(connected as the transmitter) and send the data wirelessly to the receiver which will be further connected with MCU boards.
4,130件の閲覧回数
stephanie_m
How do you want to connect them ? And the data that you want to send will be through ZigBee or BLE ?
Estephania
