CLRC663 I2C LoadProtocol Error
1,446 次查看
octopus
I am using CLRC663 with I2C configuration in my project. eeprom error occurs every time I try to send load protocol command. Is there any known error about this situation?
标记 (1)
1,436 次查看
estephania_mart
Please help us check the following AN for more details on the load protocol.
1,421 次查看
octopus
Thank you for answer. I figure out LoadProtocol problem. It was about how write FIFOData register so this is solved. But I have another problem. When I tried to use transceive command, again EEPROM error is occured.
I am using STM32 as MCU and I2C as communication protocol.
