Building Matter Issue
10,722 次查看
Mason-Ahn
I have an IOTZTB-DK006 from NXP.
I'm currently looking at the DOC(K32W0X1-MATTER-QSG_Rev1.0(Getting started with K32W0x1 in Matter).pdf) and trying to build an environment.
I used virtual Box to create an image of ubuntu64-22.04.3.
I have read and followed the documentation, but I am not able to progress in the python Part as shown below.
I've searched the internet and installed several pip packages, but I'm still unable to resolve the issue.
What's the problem?
error: subprocess-exited-with-error
× Getting requirements to build wheel did not run successfully.
│ exit code: 1
╰─> See above for output.
note: This error originates from a subprocess, and is likely not a problem with pip.
Getting requirements to build wheel: finished with status 'error'
│ exit code: 1
['/home/ahn/NXP/matter/.environment/pigweed-venv/bin/python', '-m', 'pip', 'install', '--log', '/home/ahn/NXP/matter/.environment/pigweed-venv/pip-requirements.log', '--requirement=/home/ahn/NXP/matter/scripts/requirements.txt', '--constraint=/home/ahn/NXP/matter/scripts/constraints.txt'] {'stdout': <_io.TextIOWrapper name=3 mode='w+' encoding='UTF-8'>, 'stderr': -2}
None
Traceback (most recent call last):
File "/home/ahn/NXP/matter/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 795, in <module>
sys.exit(main())
File "/home/ahn/NXP/matter/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 787, in main
return EnvSetup(**vars(parse())).setup()
File "/home/ahn/NXP/matter/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 457, in setup
result = step(spin)
File "/home/ahn/NXP/matter/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 606, in virtualenv
if not virtualenv_setup.install(
File "/home/ahn/NXP/matter/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/virtualenv_setup/install.py", line 274, in install
pip_install('--log', os.path.join(venv_path, 'pip-requirements.log'),
File "/home/ahn/NXP/matter/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/virtualenv_setup/install.py", line 243, in pip_install
return _check_call(cmd)
File "/home/ahn/NXP/matter/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/virtualenv_setup/install.py", line 88, in _check_call
subprocess.check_call(args, **kwargs)
File "/usr/lib/python3.10/subprocess.py", line 369, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/home/ahn/NXP/matter/.environment/pigweed-venv/bin/python', '-m', 'pip', 'install', '--log', '/home/ahn/NXP/matter/.environment/pigweed-venv/pip-requirements.log', '--requirement=/home/ahn/NXP/matter/scripts/requirements.txt', '--constraint=/home/ahn/NXP/matter/scripts/constraints.txt']' returned non-zero exit status 1.
ubuntu64-22:~/NXP/matter$ pip list
Package Version
apturl 0.5.2
bcrypt 3.2.0
blinker 1.4
Brlapi 0.8.3
certifi 2020.6.20
chardet 4.0.0
click 8.0.3
colorama 0.4.4
command-not-found 0.3
cryptography 3.4.8
cupshelpers 1.0
dbus-python 1.2.18
defer 1.0.6
distlib 0.3.4
distro 1.7.0
distro-info 1.1+ubuntu0.1
duplicity 0.8.21
fasteners 0.14.1
filelock 3.6.0
future 0.18.2
httplib2 0.20.2
idna 3.3
importlib-metadata 4.6.4
jeepney 0.7.1
keyring 23.5.0
language-selector 0.1
launchpadlib 1.10.16
lazr.restfulclient 0.14.4
lazr.uri 1.0.6
lockfile 0.12.2
louis 3.20.0
macaroonbakery 1.3.1
Mako 1.1.3
Markdown 3.3.6
MarkupSafe 2.0.1
monotonic 1.6
more-itertools 8.10.0
netifaces 0.11.0
oauthlib 3.2.0
olefile 0.46
paramiko 2.9.3
pexpect 4.8.0
Pillow 9.0.1
pip 24.0
platformdirs 2.5.1
protobuf 3.12.4
ptyprocess 0.7.0
pycairo 1.20.1
pycups 2.0.1
Pygments 2.11.2
PyGObject 3.42.1
PyJWT 2.3.0
pymacaroons 0.13.0
PyNaCl 1.5.0
pyparsing 2.4.7
pyRFC3339 1.1
python-apt 2.4.0+ubuntu2
python-dateutil 2.8.1
python-debian 0.1.43+ubuntu1.1
python-dotenv 1.0.1
pytz 2022.1
pyxdg 0.27
PyYAML 5.4.1
reportlab 3.6.8
requests 2.25.1
SecretStorage 3.3.1
setuptools 69.1.1
six 1.16.0
ssh-import-id 5.11
systemd-python 234
ubuntu-advantage-tools 8001
ubuntu-drivers-common 0.0.0
ufw 0.36.1
unattended-upgrades 0.1
urllib3 1.26.5
usb-creator 0.3.7
virtualenv 20.13.0+ds
wadllib 1.3.6
wheel 0.42.0
xdg 5
xkit 0.0.0
zipp 1.0.0
ubuntu64-22:~/NXP/matter$ ls -al /home/ahn/NXP/matter/.environment/pigweed-venv/bin
total 24
drwxrwxr-x 2 ahn ahn 4096 2월 25 23:45 .
drwxrwxr-x 5 ahn ahn 4096 2월 25 23:45 ..
-rwxrwxr-x 1 ahn ahn 262 2월 25 23:45 pip
-rwxrwxr-x 1 ahn ahn 262 2월 25 23:45 pip3
-rwxrwxr-x 1 ahn ahn 262 2월 25 23:45 pip3.10
lrwxrwxrwx 1 ahn ahn 7 2월 25 23:45 python -> python3
lrwxrwxrwx 1 ahn ahn 16 2월 25 23:45 python3 -> /usr/bin/python3
lrwxrwxrwx 1 ahn ahn 7 2월 25 23:45 python3.10 -> python3
-rwxrwxr-x 1 ahn ahn 249 2월 25 23:45 wheel
标签 (2)
10,485 次查看
Mason-Ahn
Thanks about your reply..... Ricardo
10 回复数
10,680 次查看
Ricardo_Zamora
Hope you are doing well. What Releases · NXP/matter · GitHub are you using?
Have you tried this?
pip install --upgrade prompt-toolkit
Ricardo
10,674 次查看
Mason-Ahn
I proceeded the same as with the NXP DOC.
"K32W0X1-MATTER-QSG_Rev1.0(Getting started with K32W0x1 in Matter).pdf" 9page
3. Matter Building Setup instructions:
   Clone the Matter SDK using the public repo:
$ git clone https://github.com/NXPmicro/matter/
$ cd matter
$ git checkout v1.0-branch-nxp
$ git pull
$ git submodule update --init --recursive
   Start build environment by running the activate script:
$ source ./scripts/activate.sh
ubuntu64-22:~/NXP/matter$ git branch
I followed the DOC procedure. and I am using K32W061 EVK(IOTZTB-DK006)
Is there a problem?
10,655 次查看
EduardoZamora
Hello @Mason-Ahn
The document you used may not be up to date. Please, consider using the latest stable Matter release for your device from the matter repository, since v1.0 branch was updated after the QSG document was released; the best path would be to keep up with the READMEs from the application folder.
Specific steps for each example should be included in matter/examples/"example"/nxp/k32w/k32w0. There you should find the requirements, setup and building steps for the corresponding demo application.
Eduardo.
10,580 次查看
Mason-Ahn
I successfully built the lighting-app and contact-sensor-app for Matter.
and I flashed the binary I built, but K32W061 board doesn't work.
1. Is there something wrong with the Build Procedure below? check plz..
2. Can you share a pre-built image for Matters? ("K32W061 + OM15082")
    I want 2 binarys for K32W061. (chip-k32w0x-light-example.bin , chip-k32w0x-contact-example.bin)
    I just want to flash the binary to check if the board working well.
"Build Procedure"
-https://github.com/NXP/matter/blob/v1.2.0.1-tag-nxp/examples/lighting-app/nxp/k32w/k32w0/README.md
-https://github.com/NXP/matter/blob/v1.2.0.1-tag-nxp/examples/contact-sensor-app/nxp/k32w/k32w0/README.md
-K32W0X1-MATTER-QSG_Rev1.0(Getting started with K32W0x1 in Matter).pdf
(I referred to link and DOC. I just wrote down the main points below.)
a. git clone https://github.com/NXPmicro/matter/
b. git branch --list
c. git pull
d. git submodule update --init
e. source ./scripts/activate.sh
f. west init -l manifest --mf west.yml
g. west update
h. export NXP_K32W0_SDK_ROOT=~/NXP/SDK_2_6_13_K32W061DK6/
i. gn gen out/debug --args="k32w0_sdk_root=\"${NXP_K32W0_SDK_ROOT}\" chip_with_OM15082=1 chip_with_ot_cli=0 is_debug=false chip_crypto=\"platform\" chip_with_se05x=0 chip_pw_tokenizer_logging=true"
j. ninja -C out/debug
k. $NXP_K32W0_SDK_ROOT/tools/imagetool/sign_images.sh out/debug/
l. Connecting the board, Flashing the application using DK6Programmer.
m. DK6Programmer.exe -V 5 -P 1000000 -s COM5 -e Flash
n. DK6Programmer.exe -V 2 -s COM5 -P 1000000 -Y -p FLASH@0x00=k32w061dk6_ssbl.bin
k32w061dk6_ssbl.bin(SSBL project using MCUXpresso, compiled with the PDM_EXT_FLASH)
o. DK6Programmer.exe -V 5 -s COM5 -P 1000000 -w image_dir_0=0000000010000000
p. DK6Programmer.exe -V 5 -s COM5 -P 1000000 -w image_dir_1=00400000C9040101
q. DK6Programmer.exe -V 2 -s COM5 -P 1000000 -Y -p FLASH@0x4000=chip-k32w0x-light-example.bin
-> I have tried flashing the binaries "chip-k32w0x-light-example.bin and chip-k32w0x-contact-example.bin" respectively, but board doesn't work.
10,567 次查看
Ricardo_Zamora
Could you please use one of the Releases · NXP? For example, v1.2.0.1.3 is the latest release, and also you can check the features and platforms supported.
And unfortunately, we cannot provide a compiled binary. Every customer needs to build it.
Ricardo
10,139 次查看
seah
I tried the instructions from matter/examples/lighting-app/nxp/k32w/k32w0 at v1.2.0.1-tag-nxp · NXP/matter (github.com), and successfully built chip-k32w0x-light-example.bin.
I then flashed the DK6 board with command
C:\nxp\DK6Programmer> ./DK6Programmer.exe -s COM10 -p chip-k32w0x-light-example.bin
but the board UI LED does not correspond to the README file, i.e. no blinking, as below
Please advise
10,538 次查看
Mason-Ahn
I did it on the latest v1.2.0.1.3 you mentioned.
https://github.com/NXP/matter/blob/v1.2.0.1.3/examples/lighting-app/nxp/k32w/k32w0/README.md
-> I built it, and verified the Lighting APP UI behaviour on the K32W061 board.
https://github.com/NXP/matter/blob/v1.2.0.1.3/examples/contact-sensor-app/nxp/k32w/k32w0/README.md
-> I followed the same procedure as lighting-app above.
However, I encountered the following issue during the build.
If you look at the "/home/ahn/.cache/pip-tools" folder permissions mentioned above, it looks no problem.
Now "contact-sensor-app" is the problem. T.T
10,505 次查看
Ricardo_Zamora
I was not able to reproduce your issue. Both applications can be compiled correctly from my side.
I would recommend updating your packages.
Ricardo
4,918 次查看
chapoly1305
Similar issue, board does not boot after following https://github.com/NXP/matter/tree/v1.4.0.1.1/examples/lighting-app/nxp/k32w0
This conversion is not resolving any issue.
There have been many conversations. Can you please use exactly this branch, and a fresh environment, note every step and command used? Thank you.
10,485 次查看
Mason-Ahn
%3CLINGO-SUB%20id%3D%22lingo-sub-1815014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%BB%BA%E7%AD%91%E6%9D%90%E6%96%99%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E5%8F%B0%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%20IOTZTB-DK006%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E6%9F%A5%E7%9C%8B%20DOC%EF%BC%88K32w0x1-Matter-qsg_rev1.0%EF%BC%88%E5%9C%A8%20Matter%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20K32W0x1%20%E5%85%A5%E9%97%A8%EF%BC%89.pdf%EF%BC%89%E5%B9%B6%E5%B0%9D%E8%AF%95%E6%90%AD%E5%BB%BA%E4%B8%80%E4%B8%AA%E7%8E%AF%E5%A2%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%20Box%20%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%20ubuntu64-22.04.3%20%E7%9A%84%E9%95%9C%E5%83%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E9%98%85%E8%AF%BB%E5%B9%B6%E6%8C%89%E7%85%A7%E6%96%87%E6%A1%A3%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E5%9C%A8%20python%20%E9%83%A8%E5%88%86%E5%8F%96%E5%BE%97%E8%BF%9B%E5%B1%95%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%E4%BA%92%E8%81%94%E7%BD%91%E4%B8%8A%E6%90%9C%E7%B4%A2%E5%B9%B6%E5%AE%89%E8%A3%85%E4%BA%86%E5%87%A0%E4%B8%AA%20pip%20%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%0A%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22100%25%22%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MasonAhn_0-1708872697433.png%22%20style%3D%22width%3A%20660px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MasonAhn_0-1708872697433.png%22%20style%3D%22width%3A%20660px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264877i9268B7779985694E%2Fimage-dimensions%2F660x200%3Fv%3Dv2%22%20width%3D%22660%22%20height%3D%22200%22%20role%3D%22button%22%20title%3D%22MasonAhn_0-1708872697433.png%22%20alt%3D%22MasonAhn_0-1708872697433.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E...%3C%2FP%3E%0A%3CP%3Eerror%3A%20subcess-exited-with-error%3C%2FP%3E%0A%3CP%3E%C3%97%20%E8%8E%B7%E5%8F%96%E7%89%88%E6%9C%AC%E8%BD%AE%E5%AD%90%E7%9A%84%E8%A6%81%E6%B1%82%E6%9C%AA%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%E3%80%82%3CBR%20%2F%3E%E2%94%82%20%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%EF%BC%9A1%3CBR%20%2F%3E%E2%95%B0%E2%94%80%26gt%3B%20%E8%BE%93%E5%87%BA%E8%A7%81%E4%B8%8A%E6%96%87%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%AF%A5%E9%94%99%E8%AF%AF%E6%9D%A5%E8%87%AA%E4%B8%80%E4%B8%AA%E5%AD%90%E8%BF%9B%E7%A8%8B%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%B8%8D%E6%98%AF%20pip%20%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E8%8E%B7%E5%8F%96%E7%89%88%E6%9C%AC%E8%BD%AE%E5%AD%90%E7%9A%84%E8%A6%81%E6%B1%82%EF%BC%9A%E5%B7%B2%E5%AE%8C%E6%88%90%EF%BC%8C%E7%8A%B6%E6%80%81%E4%B8%BA%20%E2%80%9C%E9%94%99%E8%AF%AF%E2%80%9D%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%AD%90%E8%BF%9B%E7%A8%8B%E9%80%80%3CBR%20%2F%3E%E5%87%BA%E6%97%B6%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%3C%2FP%3E%0A%3CP%3E%C3%97%20%E8%8E%B7%E5%8F%96%E7%89%88%E6%9C%AC%E8%BD%AE%E5%AD%90%E7%9A%84%E8%A6%81%E6%B1%82%E6%9C%AA%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%E3%80%82%3CBR%20%2F%3E%E2%94%82%20%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%EF%BC%9A1%3CBR%20%2F%3E%E2%95%B0%E2%94%80%26gt%3B%20%E8%BE%93%E5%87%BA%E8%A7%81%E4%B8%8A%E6%96%87%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%AF%A5%E9%94%99%E8%AF%AF%E6%9D%A5%E8%87%AA%E5%AD%90%E8%BF%9B%E7%A8%8B%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%B8%8D%E6%98%AF%20pip%20%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%5B'%2Fhome%2Fahn%2FNXP%2Fmatter%2F.environment%2Fpigweed-venv%2Fbin%2Fpython'%2C%20'-m'%2C%20'pip'%2C%20'install'%2C%20'--log'%2C%20'%2Fhome%2Fahn%2FNXP%2Fmatter%2F.environment%2Fpigweed-venv%2Fpip-requirements.log'%E3%80%81'--requirement%3D%2Fhome%2Fahn%2FNXP%2Fmatter%2Fscripts%2Frequirements.txt'%E3%80%81'--%E7%BA%A6%E6%9D%9F%E6%9D%A1%E4%BB%B6%3D%2Fhome%2Fahn%2FNXP%2Fmatter%2Fscripts%2Fconstraints.txt'%5D%7B'stdout'%3A%2C%26lt%3B_io.TextIOWrapper%20name%3D3%20mode%3D'w%2B'%20encoding%3D'UTF-8'%26gt%3B%20'stderr'%3A%20-2%7D%3CBR%20%2F%3E%20%E6%97%A0%20T%3CBR%20%2F%3E%20raceback%EF%BC%88%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E9%80%9A%E8%AF%9D%EF%BC%89%EF%BC%9A%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%20%22%20%2Fhome%2Fahn%2FNXP%2Fmatter%2Fthird_party%2Fpigweed%2F%E4%BB%93%E5%BA%93%2Fpw_env_setup%2Fpy%2Fpw_env_setup%2Fenv_setup.py%20%22%EF%BC%8C%E7%AC%AC%20795%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%3CMODULE%3E%3CBR%20%2F%3E%20sys.exit%20(main%20())%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fahn%2FNXP%2Fmatter%2Fthird_party%2Fpigweed%2F%E4%BB%93%E5%BA%93%2Fpw_env_setup%2Fpy%2Fpw_env_setup%2Fenv_setup.py%20%22%EF%BC%8C%E7%AC%AC%20787%20%E8%A1%8C%EF%BC%8C%E4%B8%BB%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20envSetup%20(**vars%20(parse%20()))%20.setup%20()%20%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fahn%2FNXP%2Fmatter%2Fthird_party%2Fpigweed%2F%E4%BB%93%E5%BA%93%2Fpw_env_setup%2Fpy%2Fpw_env_setup%2Fenv_setup.py%20%22%EF%BC%8C%E7%AC%AC%20457%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%E8%AE%BE%E7%BD%AE%3CBR%20%2F%3E%E7%BB%93%E6%9E%9C%E4%B8%AD%20%3D%20%E6%AD%A5%E9%AA%A4%EF%BC%88%E6%97%8B%E8%BD%AC%EF%BC%89%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%20%2FHOME%2FAHN%2FNXP%2FMatter%2FThird_party%2Fpigweed%2F%E4%BB%93%E5%BA%93%2Fpw_env_setup%2Fpy%2Fpw_env_%20%3CBR%20%2F%3Esetup%2Fenv_setup.py%20%22%EF%BC%8C%E7%AC%AC%20606%20%E8%A1%8C%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%20virtualenv_setup.install%EF%BC%8C%E5%88%99%E5%9C%A8%20virtualenv%20%3CBR%20%2F%3E%20%E4%B8%AD%20(%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fahn%2FNXP%2Fmatter%2Fthird_party%2Fpigweed%2F%E4%BB%93%E5%BA%93%2Fpw_env_setup%2Fpy%2Fpw_env_setup%2Fvirtualenv_setup%2Finstall.py%20%22%EF%BC%8C%E7%AC%AC%20274%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20install%20%3CBR%20%2F%3E%20pip_install%20('--log'%EF%BC%8Cos.path.join%20(venv_path%EF%BC%8C'pip-requirements.log'%EF%BC%89%E3%80%81%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fahn%2FNXP%2Fmatter%2Fthird_party%2Fpigweed%2F%E4%BB%93%E5%BA%93%2Fpw_env_setup%2Fpy%2Fpw_env_setup%2Fvirtualenv_setup%2Finstall.py%20%22%EF%BC%8C%E7%AC%AC%20243%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20pip_install%20%E4%B8%AD%3CBR%20%2F%3E%E8%BF%94%E5%9B%9E%20_check_call%20(cmd)%20%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fahn%2FNXP%2Fmatter%2Fthird_party%2Fpigweed%2F%E4%BB%93%E5%BA%93%2Fpw_env_setup%2Fpy%2Fpw_env_setup%2Fvirtualenv_setup%2Finstall.py%20%22%EF%BC%8C%E7%AC%AC%2088%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20_check_call%20subprocess.check_call%20(args%2C%20%3CBR%20%2F%3E**kwargs)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%22%2Fusr%2Flib%2Fpython3.10%2Fsubprocess.py%22%20%E3%80%81%E7%AC%AC%20369%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20check_call%3CBR%20%2F%3Eraise%20CalledProcessError(retcode%2C%20cmd)%3CBR%20%2F%3Esubprocess.CalledProcessError%EF%BC%9A%E5%91%BD%E4%BB%A4'%5B'%2Fhome%2Fahn%2FNXP%2Fmatter%2F.environment%2Fpigweed-venv%2Fbin%2Fpython'%2C%20'-m'%2C%20'pip'%2C%20'install'%2C%20'--log'%2C%20'%2Fhome%2Fahn%2FNXP%2Fmatter%2F.environment%2Fpigweed-venv%2Fpip-requirements.log'%E3%80%81'--requirement%3D%2Fhome%2Fahn%2FNXP%2Fmatter%2Fscripts%2Frequirements.txt'%E3%80%81'--%E7%BA%A6%E6%9D%9F%3D%2Fhome%2Fahn%2FNXP%2Fmatter%2Fscripts%2Fconstraints.txt'%5D'%E8%BF%94%E5%9B%9E%E9%9D%9E%E9%9B%B6%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%201%E3%80%82%3C%2FMODULE%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eubuntu64-22%3A~%2FNXP%2Fmatter%24%20pip%20list%3C%2FP%3E%0A%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%3E%0A%3CP%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%89%88%E6%9C%AC%20%3CBR%20%2F%3E-----------------------------------------------apturl%200.5.2%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Ebcrypt%203.2.0%3CBR%20%2F%3Eblinker%201.4%3CBR%20%2F%3EBrlapi%200.8.3%3CBR%20%2F%3Ecertifi%202020.6.20%3CBR%20%2F%3Echardet%204.0.0%3CBR%20%2F%3Eclick%208.0.3%3CBR%20%2F%3Ecolorama%200.4.4%3CBR%20%2F%3Ecommand-not-found%200.3%3CBR%20%2F%3Ecryptography%203.4.8%3CBR%20%2F%3Ecupshelpers%201.0%3CBR%20%2F%3Edbus-python%201.2.18%3CBR%20%2F%3Edefer%201.0.6%3CBR%20%2F%3Edistlib%200.3.4%3CBR%20%2F%3E%E5%8F%91%E8%A1%8C%E7%89%88%201.7.0%20%3CBR%20%2F%3E%E5%8F%91%E8%A1%8C%E7%89%88%E4%BF%A1%E6%81%AF%201.1%2Bubuntu0.1%20%3CBR%20%2F%3Eduplicity%200.8.21%3CBR%20%2F%3Efasteners%200.14.1%3CBR%20%2F%3Efilelock%203.6.0%3CBR%20%2F%3E%E6%9C%AA%E6%9D%A5%200.18.2%3CBR%20%2F%3Ehttplib2%200.20.2%3CBR%20%2F%3Eidna%203.3%3CBR%20%2F%3Eimportlib-metadata%204.6.4%3CBR%20%2F%3Ejeepney%200.7.1%3CBR%20%2F%3Ekeyring%2023.5.0%3CBR%20%2F%3Elanguage-selector%200.1%3CBR%20%2F%3Elaunchpadlib%201.10.16%3CBR%20%2F%3Elazr.restfulclient0.14.4%3CBR%20%2F%3Elazr.uri%201.0.6%3CBR%20%2F%3E%E9%94%81%E5%AE%9A%E6%96%87%E4%BB%B6%200.12.2%3CBR%20%2F%3E%E8%B7%AF%E6%98%93%E6%96%AF%203.20.0%3CBR%20%2F%3Emacaroonbakery%201.3.1%3CBR%20%2F%3EMako%201.1.3%3CBR%20%2F%3EMarkdown%203.3.6%3CBR%20%2F%3EMarkupSafe%202.0.1%3CBR%20%2F%3Emonotonic%201.6%3CBR%20%2F%3Emore-itertools%208.10.0%3CBR%20%2F%3Enetifaces%200.11.0%3C%2FP%3E%0A%3CP%3Eoauthlib%203.2.0%3CBR%20%2F%3Eolefile%200.46%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%3E%3CBR%20%2F%3Eparamiko%202.9.3%3CBR%20%2F%3Epexpect%204.8.0%3CBR%20%2F%3E%E6%9E%95%E5%A4%B4%209.0.1%3CBR%20%2F%3Epip%2024.0%3CBR%20%2F%3Eplatformdirs%202.5.1%3CBR%20%2F%3Eprotobuf%203.12.4%3CBR%20%2F%3Eptyprocess%200.7.0%3CBR%20%2F%3Epycairo%201.20.1%3CBR%20%2F%3Epycups%202.0.1%3CBR%20%2F%3EPygments%202.11.2%3CBR%20%2F%3EPyGObject%203.42.1%3CBR%20%2F%3EPyJWT%202.3.0%3CBR%20%2F%3Epymacaroons%200.13.0%3CBR%20%2F%3EPyNaCl%201.5.0%3CBR%20%2F%3Epyparsing%202.4.7%3CBR%20%2F%3EpyRFC3339%201.1%3CBR%20%2F%3Epython-apt%202.4.0%2Bubuntu2%3CBR%20%2F%3Epython-dateutil%202.8.1%3CBR%20%2F%3Epython-debian%200.1.43%2Bubuntu1.1%3CBR%20%2F%3Epython-dotenv%201.0.1%3CBR%20%2F%3Epytz%202022.1%3CBR%20%2F%3Epyxdg%200.27%3CBR%20%2F%3EPyYAML%205.4.1%3CBR%20%2F%3E%E6%8A%A5%E5%91%8A%E5%AE%9E%E9%AA%8C%E5%AE%A4%203.6.8%3CBR%20%2F%3E%E8%A6%81%E6%B1%82%202.25.1%3CBR%20%2F%3ESecretStorage%203.3.1%3CBR%20%2F%3Esetuptools%2069.1.1%3CBR%20%2F%3E%E5%85%AD%201.16.0%3CBR%20%2F%3Essh-import-id%205.11%3CBR%20%2F%3Esystemd-python%20234%3CBR%20%2F%3Eubuntu-advantage-tools%208001%3CBR%20%2F%3Eubuntu-drivers-common%200.0.0%3CBR%20%2F%3Eufw%200.36.1%3CBR%20%2F%3Eunattended-upgrades%200.1%3CBR%20%2F%3Eurllib3%201.26.5%3CBR%20%2F%3Eusb-creator%200.3.7%3CBR%20%2F%3Evirtualenv%2020.13.0%2Bds%3CBR%20%2F%3Ewadllib%201.3.6%3CBR%20%2F%3E%E8%BD%AE%E5%AD%90%200.42.0%3CBR%20%2F%3Exdg%205%3CBR%20%2F%3Exkit%200.0.0%3CBR%20%2F%3Ezipp%201.0.0%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eubuntu64-22%3A~%2FNXP%2Fmatter%24%20ls%20-al%20%2Fhome%2Fahn%2FNXP%2Fmatter%2F.environment%2Fpigweed-venv%2Fbin%3C%2FP%3E%0A%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22100%25%22%3Etotal%2024%3CBR%20%2F%3Edrwxrwxr-x%202%20ahn%20ahn%204096%202%EC%9B%94%2025%2023%3A45%20.%3CBR%20%2F%3Edrwxrwxr-x%205%20ahn%20ahn%204096%202%EC%9B%94%2025%2023%3A45%20...%3CBR%20%2F%3E-rwxrwxr-x%201%20ahn%20ahn%20262%202%EC%9B%94%2025%2023%3A45%20pip%3CBR%20%2F%3E-rwxrwxr-x%201%20ahn%20ahn%20262%202%EC%9B%94%2025%2023%3A45%20pip3%3CBR%20%2F%3E-rwxrwxr-x%201%20ahn%20ahn%20262%202%EC%9B%94%2025%2023%3A45%20pip3.10%3CBR%20%2F%3Elrwxrwxrwx%201%20ahn%20ahn%207%202%EC%9B%94%2025%2023%3A45%20python%20-%26gt%3B%20python3%3CBR%20%2F%3Elrwxrwxrwx%201%20ahn%20ahn%2016%202%EC%9B%94%2025%2023%3A45%20python3%20-%26gt%3B%20%2Fusr%2Fbin%2Fpython3%3CBR%20%2F%3Elrwxrwxrwx%201%20ahn%20ahn%207%202%EC%9B%94%2025%2023%3A45%20python3.10%20-%26gt%3B%20python3%3CBR%20%2F%3E-rwxrwxr-x%201%20ahn%20ahn%20249%202%EC%9B%94%2025%2023%3A45%20wheel%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1815014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E4%BA%A7%E5%93%81%EF%BC%9AK32W0%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%8D%8F%E8%AE%AE%EF%BC%9AMatter%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Building%20Matter%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%85%B3%E6%B3%A8%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Ftree%2Fv1.4.0.1.1%2Fexamples%2Flighting-app%2Fnxp%2Fk32w0%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Ftree%2Fv1.4.0.1.1%2Fexamples%2Flighting-app%2Fnxp%2Fk32w0%3C%2FA%3E%20%E5%90%8E%E6%9D%BF%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%3C%2FP%3E%3CP%3E%E8%BF%99%E7%A7%8D%E8%BD%AC%E6%8D%A2%E4%B8%8D%E8%83%BD%E8%A7%A3%E5%86%B3%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%A4%9A%E6%AC%A1%E5%AF%B9%E8%AF%9D%E3%80%82%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E4%BD%BF%E7%94%A8%E8%AF%A5%E5%88%86%E6%94%AF%E5%92%8C%E5%85%A8%E6%96%B0%E7%9A%84%E7%8E%AF%E5%A2%83%EF%BC%8C%E5%B9%B6%E8%AE%B0%E5%BD%95%E4%B8%8B%E4%BD%BF%E7%94%A8%E7%9A%84%E6%AF%8F%E4%B8%AA%E6%AD%A5%E9%AA%A4%E5%92%8C%E5%91%BD%E4%BB%A4%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Building%20Matter%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20v1.2.0.1-tag-nxp%20%C2%B7%20nxp%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Ftree%2Fv1.2.0.1-tag-nxp%2Fexamples%2Flighting-app%2Fnxp%2Fk32w%2Fk32w0%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%2FMatter%20(github.com)%20%E5%B0%9D%E8%AF%95%E4%BA%86%20matter%2Fexamples%2Flighting-app%2Fnxp%2Fk32w0%3C%2FA%3E%20%E4%B8%AD%E7%9A%84%E6%8C%87%E4%BB%A4%EF%BC%8C%E5%B9%B6%E6%88%90%E5%8A%9F%E6%9E%84%E5%BB%BA%E4%BA%86%20chip-k32w0x-light-example.bin%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E7%94%A8%E5%91%BD%E4%BB%A4%E5%88%B7%E6%96%B0%E4%BA%86%20DK6%20%E4%B8%BB%E6%9D%BF%3C%2FP%3E%3CP%3EC%3A%5Cnxp%5CDK6Programmer%26gt%3B.%2FDK6Programmer.exe%20-s%20COM10%20-p%20chip-k32w0x-light-example.bin%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%9D%BF%E7%94%A8%E6%88%B7%E7%95%8C%E9%9D%A2%20LED%20%E4%B8%8E%E8%87%AA%E8%BF%B0%E6%96%87%E4%BB%B6%E4%B8%8D%E5%AF%B9%E5%BA%94%EF%BC%8C%E5%8D%B3%E4%B8%8D%E9%97%AA%E7%83%81%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.JPG%22%20style%3D%22width%3A%20249px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F279596i08560AEDE3DA866B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%221.JPG%22%20alt%3D%221.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E5%91%8A%E7%9F%A5%20%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1824625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Building%20Matter%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1824625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D.....Ricardo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1824317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Building%20Matter%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1824317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E9%87%8D%E7%8E%B0%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E4%BB%8E%E6%88%91%E8%BF%99%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%AD%A3%E7%A1%AE%E7%BC%96%E8%AF%91%E8%BF%99%E4%B8%A4%E4%B8%AA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E6%9B%B4%E6%96%B0%E4%BD%A0%E7%9A%84%E5%8C%85%E8%A3%B9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E9%87%8C%E5%8D%A1%E5%A4%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1822594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Building%20Matter%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1822594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%98%AF%E5%9C%A8%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%20v1.2.0.1.3%20%E4%B8%8A%E5%AE%8C%E6%88%90%E7%9A%84%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Fblob%2Fv1.2.0.1.3%2Fexamples%2Flighting-app%2Fnxp%2Fk32w%2Fk32w0%2FREADME.md%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Fblob%2Fv1.2.0.1.3%2Fexamples%2Flighting-app%2Fnxp%2Fk32w%2Fk32w0%2FREADME.md%3C%2FA%3E%3CBR%20%2F%3E-%26gt%3B%20%E6%88%91%E6%9E%84%E5%BB%BA%E4%BA%86%E5%AE%83%EF%BC%8C%E5%B9%B6%E9%AA%8C%E8%AF%81%E4%BA%86%20K32W061%20%E6%9D%BF%E4%B8%8A%E7%9A%84%20Lighting%20APP%20%E7%94%A8%E6%88%B7%E7%95%8C%E9%9D%A2%E8%A1%8C%E4%B8%BA%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Fblob%2Fv1.2.0.1.3%2Fexamples%2Fcontact-sensor-app%2Fnxp%2Fk32w%2Fk32w0%2FREADME.md%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Fblob%2Fv1.2.0.1.3%2Fexamples%2Fcontact-sensor-app%2Fnxp%2Fk32w%2Fk32w0%2FREADME.md%3C%2FA%3E%3CBR%20%2F%3E-%26gt%3B%20%E6%88%91%E9%87%87%E7%94%A8%E4%BA%86%E4%B8%8E%E4%B8%8A%E8%BF%B0%E7%85%A7%E6%98%8E%E5%BA%94%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E5%9C%A8%E7%89%88%E6%9C%AC%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MasonAhn_0-1709736932631.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MasonAhn_0-1709736932631.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F266826iDC8C6C377B68A591%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MasonAhn_0-1709736932631.png%22%20alt%3D%22MasonAhn_0-1709736932631.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%9F%A5%E7%9C%8B%22%2Fhome%2Fahn%2F.cache%2Fpip-tools%22%E4%B8%8A%E9%9D%A2%E6%8F%90%E5%88%B0%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E6%9D%83%E9%99%90%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MasonAhn_1-1709737256054.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MasonAhn_1-1709737256054.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F266827i1FFD9F3506F376E4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MasonAhn_1-1709737256054.png%22%20alt%3D%22MasonAhn_1-1709737256054.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%22%E6%8E%A5%E8%A7%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%22%20%E5%B0%B1%E6%98%AF%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82T.T%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1820675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Building%20Matter%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1820675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E4%B8%8D%E8%83%BD%E4%BD%BF%E7%94%A8%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Freleases%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%89%88%E6%9C%AC%C2%B7%E6%81%A9%E6%99%BA%E6%B5%A6%EF%BC%9F%3C%2FA%3E%E4%BE%8B%E5%A6%82%EF%BC%8Cv1.2.0.1.3%20%E6%98%AF%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%8C%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%E6%94%AF%E6%8C%81%E7%9A%84%E5%8A%9F%E8%83%BD%E5%92%8C%E5%B9%B3%E5%8F%B0%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E6%8F%90%E4%BE%9B%E7%BC%96%E8%AF%91%E5%90%8E%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%E6%AF%8F%E4%B8%AA%E5%AE%A2%E6%88%B7%E9%83%BD%E9%9C%80%E8%A6%81%E5%BB%BA%E9%80%A0%E5%AE%83%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E9%87%8C%E5%8D%A1%E5%A4%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1820481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Building%20Matter%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1820481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%88%90%E5%8A%9F%E5%9C%B0%E4%B8%BA%20Matter%20%E6%9E%84%E5%BB%BA%E4%BA%86%E7%85%A7%E6%98%8E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E6%8E%A5%E8%A7%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%E7%84%B6%E5%90%8E%E6%88%91%E5%88%B7%E6%96%B0%E4%BA%86%E6%88%91%E6%9E%84%E5%BB%BA%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%EF%BC%8C%E4%BD%86%E6%98%AF%20K32W061%20%E6%9D%BF%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E1%E3%80%82%E4%B8%8B%E9%9D%A2%E7%9A%84%E7%89%88%E6%9C%AC%E8%BF%87%E7%A8%8B%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FSTRONG%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E2%E3%80%82%E4%BD%A0%E8%83%BD%E5%88%86%E4%BA%AB%20Matters%20%E7%9A%84%E9%A2%84%E5%BB%BA%E7%89%88%E6%9C%AC%3C%2FSTRONG%3E%E5%90%97%EF%BC%9F(%22%3CSTRONG%3E%20K32W061%3C%2FSTRONG%3E%20%2B%20OM15082%22)%3CBR%20%2F%3E%20%E6%88%91%E6%83%B3%E8%A6%81%20K32W061%20%E7%9A%84%E4%B8%A4%E4%B8%AA%E4%BA%8C%E8%BF%9B%E5%88%B6%E3%80%82(chip-k32w0x-light-example.bin%20%2C%20chip-k32w0x-contact-example.bin)%3CBR%20%2F%3E%20%E6%88%91%E5%8F%AA%E6%83%B3%E5%88%B7%E6%96%B0%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E6%9D%A5%E6%A3%80%E6%9F%A5%E6%9D%BF%E6%98%AF%E5%90%A6%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E%22%20%E7%BC%96%E8%AF%91%E7%A8%8B%E5%BA%8F%20%22%3C%2FSTRONG%3E%20%3CBR%20%2F%3E-https%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Fblob%2Fv1.2.0.1-tag-nxp%2Fexamples%2Flighting-app%2Fnxp%2Fk32w%2Fk32w0%2FREADME.md%20%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Fblob%2Fv1.2.0.1-tag-nxp%2Fexamples%2Fcontact-sensor-app%2Fnxp%2Fk32w%2Fk32w0%2FREADME.md%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Fblob%2Fv1.2.0.1-tag-nxp%2Fexamples%2Fcontact-sensor-app%2Fnxp%2Fk32w%2Fk32w0%2FREADME.md%3C%2FA%3E%3CBR%20%2F%3E-K32W0X1-MATTER-QSG_Rev1.0%EF%BC%88K32W0x1%20%E7%89%A9%E8%B4%A8%E5%85%A5%E9%97%A8%EF%BC%89.pdf%3CBR%20%2F%3E(%E6%88%91%E6%8F%90%E5%88%B0%E4%BA%86%E9%93%BE%E6%8E%A5%E5%92%8C%20DOC%E3%80%82%E6%88%91%E5%8F%AA%E6%98%AF%E6%8A%8A%E8%A6%81%E7%82%B9%E5%86%99%E5%9C%A8%E4%B8%8B%E9%9D%A2%EF%BC%89%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%3CP%3Ea.%20git%20clone%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPmicro%2Fmatter%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPmicro%2Fmatter%2F%3C%2FA%3E%3CBR%20%2F%3Eb.%20git%20%E5%88%86%E6%94%AF%20--list%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MasonAhn_0-1709547212650.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MasonAhn_0-1709547212650.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F266267i2C897D735A06E03C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MasonAhn_0-1709547212650.png%22%20alt%3D%22MasonAhn_0-1709547212650.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3Ec.%20git%20pull%3CBR%20%2F%3Ed.%20git%20submodule%20update%20--init%3CBR%20%2F%3Ee.%20source%20.%2Fscripts%2Factivate.sh%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MasonAhn_1-1709547277878.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MasonAhn_1-1709547277878.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F266269i7080627BD20367B8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MasonAhn_1-1709547277878.png%22%20alt%3D%22MasonAhn_1-1709547277878.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3Ef.%20west%20init-l%20%E6%B8%85%E5%8D%95--mf%20west.yml%20%3CBR%20%2F%3EG.%20%E8%A5%BF%E9%83%A8%E7%9A%84%E6%9C%80%E6%96%B0%E6%83%85%E5%86%B5%3C%2FP%3E%3CP%3Eh.%20export%20NXP_K32W0_SDK_ROOT%3D~%2FNXP%2FSDK_2_6_13_K32W061DK6%2F%3CBR%20%2F%3Ei.%20export%20NXP_K32W0_SDK_ROOT%3D~%2FNXP%2FSDK_2_6_13_K32W061DK6%2F%20ii.gn%20gen%20out%2Fdebug%20--args%3D%22k32w0_sdk_root%3D%5C%22%24%7BNXP_K32W0_SDK_ROOT%7D%20%5C%22%20chip_with_OM15082%3D1%20chip_with_ot_cli%3D0%20is_debug%3Dfalse%20chip_crypto%3D%5C%22platform%5C%22%20chip_with_se05x%3D0%20chip_pw_tokenizer_logging%3Dtrue%22%3CBR%20%2F%3E%20j.%20ninja%20-C%20out%2Fdebug%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MasonAhn_2-1709547556444.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MasonAhn_2-1709547556444.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F266271i424EF1A38CE48E6F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MasonAhn_2-1709547556444.png%22%20alt%3D%22MasonAhn_2-1709547556444.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3Ek.%24NXP_K32W0_SDK_ROOT%2Ftools%2Fimagetool%2Fsign_images.sh%20out%2Fdebug%2F%3C%2FP%3E%3CP%3El.%20%E8%BF%9E%E6%8E%A5%E4%B8%BB%E6%9D%BF%EF%BC%8C%E4%BD%BF%E7%94%A8%20DK6Programmer%20%E5%88%B7%E6%96%B0%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MasonAhn_3-1709547676380.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MasonAhn_3-1709547676380.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F266275i03254F57A6DB3CE3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MasonAhn_3-1709547676380.png%22%20alt%3D%22MasonAhn_3-1709547676380.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3Em.DK6Programmer.exe%20-V%205%20-P%201000000%20-s%20COM5%20-e%20Flash%3CBR%20%2F%3En.DK6Programmer.exe%20-V%202%20-s%20COM5%20-P%201000000%20-Y%20-p%3CSTRONG%3EFLASH%400x00%3Dk32w061dk6_ssbl.bin%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Ek32w061dk6_ssbl.bin%EF%BC%88%E4%BD%BF%E7%94%A8%20MCUXpresso%20%E7%9A%84%20SSBL%20%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%BF%E7%94%A8%20PDM_EXT_FLASH%20%E7%BC%96%E8%AF%91%EF%BC%89%3CBR%20%2F%3Eo.DK6Programmer.exe%20-V%205%20-s%20COM5%20-P%201000000%20-w%20image_dir_0%3D0000000010000000%3CBR%20%2F%3Ep%EF%BC%8EDK6Programmer.exe%20-V%205%20-s%20COM5%20-P%201000000%20-w%20image_dir_1%3D00400000C9040101%3CBR%20%2F%3Eq%EF%BC%8EDK6Programmer.exe%20-V%202%20-s%20COM5%20-P%201000000%20-Y%20-p%3CSTRONG%3EFLASH%400x4000%3Dchip-k32w0x-light-example.bin%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E-%26gt%3B%20%E6%88%91%E8%AF%95%E8%BF%87%E5%88%B7%E6%96%B0%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%20%22%20chip-k32w0x-light-example.bin%20%E5%92%8C%20chip-k32w0x-contact-example.bin%20%22%E5%88%86%E5%88%AB%E6%98%AF%EF%BC%8C%E4%BD%86%E6%98%AF%E6%9D%BF%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Building%20Matter%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225574%22%20target%3D%22_blank%22%3E%40%E9%A9%AC%E6%A3%AE-%E5%AE%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%96%87%E4%BB%B6%E5%8F%AF%E8%83%BD%E4%B8%8D%E6%98%AF%E6%9C%80%E6%96%B0%E7%9A%84%E3%80%82%E8%AF%B7%E8%80%83%E8%99%91%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Freleases%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E9%97%AE%E9%A2%98%E5%AD%98%E5%82%A8%E5%BA%93%E4%B8%AD%E4%B8%BA%E6%82%A8%E7%9A%84%E8%AE%BE%E5%A4%87%E4%BD%BF%E7%94%A8%E6%9C%80%E6%96%B0%E7%9A%84%E7%A8%B3%E5%AE%9A%E7%89%88%E6%9C%AC%3C%2FA%3E%EF%BC%8C%E5%9B%A0%E4%B8%BA%20v1.0%20%E5%88%86%E6%94%AF%E6%98%AF%E5%9C%A8%20QSG%20%E6%96%87%E6%A1%A3%E5%8F%91%E5%B8%83%E4%B9%8B%E5%90%8E%E6%9B%B4%E6%96%B0%E7%9A%84%EF%BC%9B%E6%9C%80%E4%BD%B3%E9%80%94%E5%BE%84%E6%98%AF%E4%BB%8E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E8%8E%B7%E5%8F%96%E8%87%AA%E8%BF%B0%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AF%8F%E4%B8%AA%E7%A4%BA%E4%BE%8B%E7%9A%84%E5%85%B7%E4%BD%93%E6%AD%A5%E9%AA%A4%E5%BA%94%E5%8C%85%E5%90%AB%E5%9C%A8%20matter%2Fexamples%2F%22example%22%2Fnxp%2Fk32w%2Fk32w0%20%E4%B8%AD%E3%80%82%E5%9C%A8%E9%82%A3%E9%87%8C%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E7%9B%B8%E5%BA%94%E6%BC%94%E7%A4%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E8%A6%81%E6%B1%82%E3%80%81%E8%AE%BE%E7%BD%AE%E5%92%8C%E6%9E%84%E5%BB%BA%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EEduardo%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Building%20Matter%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9A%84%E6%93%8D%E4%BD%9C%E6%AD%A5%E9%AA%A4%E4%B8%8E%E6%81%A9%E6%99%BA%E6%B5%A6%20DOC%20%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%22K32W0X1-MATTER-QSG_Rev1.0(K32W0x1%20Matter%20%E5%85%A5%E9%97%A8).pdf%229%20%E9%A1%B5%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%3CP%3E3.%20Matter%20Building%20%E8%AE%BE%E7%BD%AE%E8%AF%B4%E6%98%8E%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%85%AC%E5%85%B1%E4%BB%93%E5%BA%93%3CBR%20%2F%3E%20%E5%85%8B%E9%9A%86%20Matter%20SDK%EF%BC%9A%3CBR%20%2F%3E%20%24%20git%20clone%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPmicro%2Fmatter%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%20https%3A%2F%2Fgithub.com%2FNXPmicro%2Fmatter%2F%3C%2FA%3E%3CBR%20%2F%3E%24%20cd%20matter%20%3CBR%20%2F%3E%20%24%20git%20checkout%20v1.0-branch-nxp%20%3CBR%20%2F%3E%20%24%20git%20pull%20%3CBR%20%2F%3E%20%24%20git%20%E5%AD%90%E6%A8%A1%E5%9D%97%E6%9B%B4%E6%96%B0--init--recursive%20%E9%80%9A%E8%BF%87%E8%BF%90%E8%A1%8C%E6%BF%80%E6%B4%BB%E8%84%9A%E6%9C%AC%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%EF%BC%9A%24%20source%E3%80%82%3CBR%20%2F%3E%2Fscripts%2Factivate.sh%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3Eubuntu64-22%3A~%2FNXP%2Fmatter%24%20git%20branch%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MasonAhn_0-1708988738390.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MasonAhn_0-1708988738390.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265154i40D765D1FD89DBD4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MasonAhn_0-1708988738390.png%22%20alt%3D%22MasonAhn_0-1708988738390.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%20DOC%20%E7%9A%84%E7%A8%8B%E5%BA%8F%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%93%8D%E4%BD%9C%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20K32W061%20EVK(IOTZTB-DK006)%3C%2FP%3E%3CP%3E%E6%9C%89%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Building%20Matter%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%A1%BA%E5%88%A9%E3%80%82%E4%BD%A0%E5%9C%A8%E7%94%A8%E4%BB%80%E4%B9%88%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter%2Freleases%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%89%88%E6%9C%AC%C2%B7nxp%2FMatter%20%C2%B7%20GitHub%3C%2FA%3E%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E8%AF%95%E8%BF%87%E8%BF%99%E4%B8%AA%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3Epip%20install%20--upgrade%20prompt-toolkit%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E9%87%8C%E5%8D%A1%E5%A4%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E
