BLE Scan configuration
1,634 次查看
gaborszabo
I'm working on a HSDK Python script to collect the BLE advertisements with timestamps. I'm using now a FRDM-KW41Z board with ble_fsci_blackbox.bin firmware. My problem is that I don't see all of the advertisement packets just only the first from each device. I checked the documentation about the scan configuration but I don't see what is wrong with it. Is it the intended operation?
1,444 次查看
stephanie_m
Could you please give me more details of the advertisement? Do you only see one and you don't see anything else later?
What exactly do you see? Also, how are you configuring the scanning?
Estephania
