ADC coexistence with Connectivity Software (solved)
1,872 次查看
lukaszgesieniec
Problem solved. After debugging I found that Keyboard Module was enabled and was causing conflict with pin used by ADC.
Hi All,
I don't see ADC driver in Connectivity Software so I try to configure ADC from example located  in \frdmkw41z\demo_apps\dac_adc folder.
I use ADC0_IRQHandler to obtain converted value. First conversion usually is OK, but second causes reset KW41Z.
How to properly handle adc irq?
Best Regads,
Lukasz
标签 (3)
标记 (2)
0 回复数
