Zigbee module partner?
2,747 次查看
andy_kim
When it comes to WiFi/BT connectivity chipset, it has module partner such as Ublox, Azure, Murata,..etc.
I'd like to know if there are recommended module partners of Zigbee as well.
Thank you,
Andy
标记 (1)
2,670 次查看
bruce_havemeier
You can find the K32W-based solution from CEL here:
https://www.cel.com/product/cmp53x/
There's a standard and long-range version, additional integrated Flash...
2,671 次查看
bruce_havemeier
2,647 次查看
andy_kim
Dear Ricardo,
Thank you for your feedback and reminding it of me.
Let me close this case.
Thank you,
Andy
2,722 次查看
Ricardo_Zamora
Hello Andy,
Hope you are doing well. You can find a JN5189 module from Azurewave. And also there is a K32W061 module from California Eastern Laboratories.
Ricardo
