- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
I had installed BeyondStudio for NXP a week ago. I was following BeyondStudio for NXP installation guide and when i reached section 1.2.3 i wasn't able to install the two mandatory plugins. The output says: "The operation cannot be completed" followed by:
Cannot complete the install because one or more required items could not be found.
Software being installed: NXP ZBPro Configuration Editor 2.0.0 (com.jennic.sdk.zbpro.external.feature.feature.group 2.0.0)
Missing requirement: ZBPro Config Edit Support 2.0.0 (com.jennic.zps.configeditor.edit 2.0.0) requires 'bundle org.eclipse.emf.edit 0.0.0' but it could not be found
Cannot satisfy dependency:
From: NXP ZBPro Configuration Editor 2.0.0 (com.jennic.sdk.zbpro.external.feature.feature.group 2.0.0)
To: com.jennic.zps.configeditor.edit [2.0.0]
Then i tried uninstalling BeyondStudio as @mario_castaneda suggests on this forum post but nothing changed.
What gives?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello @ffonck96
Hope you are doing well.
Please, take a look at the document that is attached to this post, there you can find the steps that I followed to replicate this behavior and how to try to solve it.
Eduardo.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the reply @EduardoZamora , it worked!.
Although, part of my issue is solved I'm still wondering if Jennic RTOS Configuration Editor is available for install.
Thanks for the file it was useful, regards!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It seems that the Eclipse cloud has changed the structure of multiple dependencies packages in their repository, making older plugin versions no longer available for Beyond Studio IDE.
I apologize for any inconveniences this might cause you.
Eduardo.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello @ffonck96
Eduardo.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
