[KW41Z] Implementing Beacon Scanner
Bluetooth Low Energy offers the ability to broadcast data in format of non-connectable advertising packets while not being in a connection. This GAP Advertisement is widely known as a beacon and there are currently different beacon formats on the market.
This guide will help you to create your own beacon scanner to detect from which type of device is the beacon received from.
This guide it’s based on the frdmkw41z_wireless_examples_bluetooth_temperature_collector_freertos  demo in MCUXpresso
The first thing we will do it’s to disable the low power to make the development easier in the app_preinclude.h
/* Enable/Disable PowerDown functionality in PwrLib */
#define cPWR_UsePowerDownMode           0‍‍‍‍‍‍
The following changes will be all performed in the temperature_collector.c file
We will disable the timer so it keeps scanning the packets received
/* Start advertising timer
TMR_StartLowPowerTimer(mAppTimerId,
gTmrLowPowerSecondTimer_c,
TmrSeconds(gScanningTime_c),
ScanningTimeoutTimerCallback, NULL);
Then we will define some of the data we want to use as a reference.
static uint8_t NXPAd[3] =
    /* Company Identifier*/
    mAdvCompanyId,
    /* Beacon Identifier */
    0xBC
static uint8_t iBeaconAd[2] =
    0x4C, 0x00
static uint8_t EddyStoneUIDAd2[3] =
    /* ID */
    0xAA, 0xFE,
    /* Frame Type */
    0x00
static const uint8_t EddyStoneURLAd2[3] =
    /* ID */
    0xAA, 0xFE,
    /* Frame Type */
    0x10
static const uint8_t EddyStoneTLMAd2[3] =
    /* ID */
    0xAA, 0xFE,
    /* Frame Type */
    0x20
Once we have those definitions of the beacon structure of each of the types wanted we will change the function static bool_t CheckScanEvent(gapScannedDevice_t* pData)
       uint8_t index = 0;
       bool_t foundMatch = FALSE;
       bool_t EddyfoundMatch = FALSE;
       while (index < pData->dataLength)
             gapAdStructure_t adElement;
             adElement.length = pData->data[index];
             adElement.adType = (gapAdType_t)pData->data[index + 1];
             adElement.aData = &pData->data[index + 2];
            /*DESIRED BEACON SCANNER PARSER CODE */
             /* Move on to the next AD elemnt type */
             index += adElement.length + sizeof(uint8_t);
       if (foundMatch)
             SHELL_NEWLINE();
             shell_write("\r\Address :   ");
             shell_writeHex(pData->aAddress, 6);
       return foundMatch;
As you can see, there is a comment in the function that mentions the need to add the scanner parser code, depending on the beacon you want to see  will be the code to use there
NXP
if (FLib_MemCmp(NXPAD, (adElement.aData), 2))
    shell_write("\r\nFound NXP device!");
    SHELL_NEWLINE();
    shell_write("\r\nData Received:   ");
    shell_writeHex(adElement.aData, adElement.length);
    foundMatch=TRUE;
iBeacon
if (FLib_MemCmp(iBeaconAd, (adElement.aData), 2))
    shell_write("\r\nFound iBeacon device!");
    SHELL_NEWLINE();
    foundMatch=TRUE;
Eddystone
if (FLib_MemCmp(EddyStoneUIDAd1, (adElement.aData), 2))
    shell_write("\r\nFound EddyStone device!");
    if (!EddyfoundMatch)
            EddyfoundMatch=TRUE;
    else{
        if(TRUE==EddyfoundMatch && FLib_MemCmp(EddyStoneUIDAd2, (adElement.aData), 3))
            SHELL_NEWLINE();
            shell_write("\r\n[UID type] Data Received:   ");
            foundMatch=TRUE;
            EddyfoundMatch=FALSE;
        else if(TRUE==EddyfoundMatch && FLib_MemCmp(EddyStoneURLAd2, (adElement.aData), 3))
            SHELL_NEWLINE();
            shell_write("\r\n[URL type] Data Received:   ");
            foundMatch=TRUE;
        else if(TRUE==EddyfoundMatch && FLib_MemCmp(EddyStoneTLMAd2, (adElement.aData), 3))
            SHELL_NEWLINE();
            shell_write("\r\n[TLM type] Data Received:   ");
            foundMatch=TRUE;
        else
标签 (2)
评论
Is there any examples for KW36 as beacons? Is the stack same for KW41 and KW36?
No, the stack it's different. The stack's available for several IDEs in the MCUXpresso Dashboard.
Estephania
I'm not very familiar with this example. But those Beacons where will be show?
I made the mod and I got an error, that mAdvCompanyId is not defined.
So I comment that part and I select the iBeacon scan but I coulndt see it on TeraTerm.
Regards!
I already make it work with the iBeacon but I still have the mAdvCompanyId error.
For example, if my beacon is from st the mAdvCompanyId should be the manufacturer reserved ID?
Regards!
%3CLINGO-SUB%20id%3D%22lingo-sub-1119157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BKW41Z%5D%20%E5%AE%9E%E7%8E%B0%20Beacon%20%E6%89%AB%E6%8F%8F%E4%BB%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%8E%E5%8A%9F%E8%80%97%E8%93%9D%E7%89%99%E8%83%BD%E5%A4%9F%E5%9C%A8%E6%9C%AA%E8%BF%9E%E6%8E%A5%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E4%BB%A5%E4%B8%8D%E5%8F%AF%E8%BF%9E%E6%8E%A5%E5%B9%BF%E5%91%8A%E5%8C%85%E7%9A%84%E6%A0%BC%E5%BC%8F%E5%B9%BF%E6%92%AD%E6%95%B0%E6%8D%AE%E3%80%82%E8%BF%99%E4%B8%AA%20GAP%20%E5%B9%BF%E5%91%8A%E8%A2%AB%E5%B9%BF%E6%B3%9B%E7%A7%B0%E4%B8%BA%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%3CSTRONG%3E%E4%BF%A1%E6%A0%87%3C%2FSTRONG%3E%3C%2FSPAN%3E%EF%BC%8C%E7%9B%AE%E5%89%8D%E5%B8%82%E5%9C%BA%E4%B8%8A%E6%9C%89%E4%B8%8D%E5%90%8C%E7%9A%84%E4%BF%A1%E6%A0%87%E6%A0%BC%E5%BC%8F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%AC%E6%8C%87%E5%8D%97%E5%B0%86%E5%B8%AE%E5%8A%A9%E6%82%A8%E5%88%9B%E5%BB%BA%E8%87%AA%E5%B7%B1%E7%9A%84%E4%BF%A1%E6%A0%87%E6%89%AB%E6%8F%8F%E4%BB%AA%EF%BC%8C%E4%BB%A5%E6%A3%80%E6%B5%8B%E4%BF%A1%E6%A0%87%E6%98%AF%E4%BB%8E%E5%93%AA%E7%A7%8D%E7%B1%BB%E5%9E%8B%E7%9A%84%E8%AE%BE%E5%A4%87%E6%8E%A5%E6%94%B6%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E6%8C%87%E5%8D%97%E5%9F%BA%E4%BA%8E%20MCUXpresso%20%E4%B8%AD%E7%9A%84%20frdmkw41z_wireless_examples_bluetooth_temporary_collector_freertos%20%E6%BC%94%E7%A4%BA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%A6%81%E5%81%9A%E7%9A%84%E7%AC%AC%E4%B8%80%E4%BB%B6%E4%BA%8B%E5%B0%B1%E6%98%AF%E7%A6%81%E7%94%A8%E4%BD%8E%E5%8A%9F%E8%80%97%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%9C%A8%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3E%3CEM%3Eapp_preinclude.h%3C%2FEM%3E%3C%2FSPAN%3E%E4%B8%AD%E6%9B%B4%E5%AE%B9%E6%98%93%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Enable%2FDisable%20PowerDown%20functionality%20in%20PwrLib%20*%2F%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22property%20macro%20token%22%3E%23define%20cPWR_UsePowerDownMode%20%20%20%20%20%20%20%20%20%20%200%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3C%2FSPAN%3E%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%9B%B4%E6%94%B9%E9%83%BD%E5%B0%86%E5%9C%A8%3CEM%3E%3CSPAN%20style%3D%22color%3A%20%23800080%3B%22%3Etemperature_collector.c%3C%2FSPAN%3E%3C%2FEM%3E%E4%B8%AD%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%86%E7%A6%81%E7%94%A8%E8%AE%A1%E6%97%B6%E5%99%A8%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%AE%83%E7%BB%A7%E7%BB%AD%E6%89%AB%E6%8F%8F%E6%94%B6%E5%88%B0%E7%9A%84%E6%95%B0%E6%8D%AE%E5%8C%85%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Start%20advertising%20timer%0A%20%0ATMR_StartLowPowerTimer(mAppTimerId%2C%0AgTmrLowPowerSecondTimer_c%2C%0ATmrSeconds(gScanningTime_c)%2C%0AScanningTimeoutTimerCallback%2C%20NULL)%3B%0A%20%0A*%2F%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E4%BB%AC%E5%B0%86%E5%AE%9A%E4%B9%89%E4%B8%80%E4%BA%9B%E6%88%91%E4%BB%AC%E6%83%B3%E8%A6%81%E7%94%A8%E4%BD%9C%E5%8F%82%E8%80%83%E7%9A%84%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20uint8_t%20NXPAd%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Company%20Identifier*%2F%3C%2FSPAN%3E%0A%20%20%20%20mAdvCompanyId%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Beacon%20Identifier%20*%2F%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22number%20token%22%3E0xBC%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20uint8_t%20iBeaconAd%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22number%20token%22%3E0x4C%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x00%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20uint8_t%20EddyStoneUIDAd2%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20ID%20*%2F%3C%2FSPAN%3E%20%0A%20%20%20%20%3CSPAN%20class%3D%22number%20token%22%3E0xAA%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0xFE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Frame%20Type%20*%2F%3C%2FSPAN%3E%20%20%20%20%0A%20%20%20%20%3CSPAN%20class%3D%22number%20token%22%3E0x00%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20uint8_t%20EddyStoneURLAd2%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20ID%20*%2F%3C%2FSPAN%3E%20%0A%20%20%20%20%3CSPAN%20class%3D%22number%20token%22%3E0xAA%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0xFE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Frame%20Type%20*%2F%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22number%20token%22%3E0x10%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20uint8_t%20EddyStoneTLMAd2%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20ID%20*%2F%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22number%20token%22%3E0xAA%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0xFE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Frame%20Type%20*%2F%3C%2FSPAN%3E%20%20%20%0A%20%20%20%20%3CSPAN%20class%3D%22number%20token%22%3E0x20%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%80%E6%97%A6%E6%88%91%E4%BB%AC%E6%9C%89%E4%BA%86%E6%89%80%E9%9C%80%E6%AF%8F%E7%A7%8D%E7%B1%BB%E5%9E%8B%E7%9A%84%E4%BF%A1%E6%A0%87%E7%BB%93%E6%9E%84%E7%9A%84%E5%AE%9A%E4%B9%89%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E6%94%B9%E5%8F%98%E5%87%BD%E6%95%B0%E9%9D%99%E6%80%81%3CSPAN%20style%3D%22color%3A%20%23ff9900%3B%22%3E%3CEM%3Ebool_t%20CheckScanEvent(gapScannedDevice_t*%20pData)%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20bool_t%20%3CSPAN%20class%3D%22token%20function%22%3ECheckScanEvent%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EgapScannedDevice_t%3CSPAN%20class%3D%22operator%20token%22%3E*%3C%2FSPAN%3E%20pData%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20uint8_t%20index%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20bool_t%20foundMatch%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20FALSE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20bool_t%20EddyfoundMatch%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20FALSE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%0A%20%20%20%20%20%20%20%3CSPAN%20class%3D%22keyword%20token%22%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Eindex%20%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%3C%2FSPAN%3E%20pData%3CSPAN%20class%3D%22operator%20token%22%3E-%26gt%3B%3C%2FSPAN%3EdataLength%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20gapAdStructure_t%20adElement%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20adElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Elength%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20pData%3CSPAN%20class%3D%22operator%20token%22%3E-%26gt%3B%3C%2FSPAN%3Edata%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3Eindex%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20adElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EadType%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EgapAdType_t%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3EpData%3CSPAN%20class%3D%22operator%20token%22%3E-%26gt%3B%3C%2FSPAN%3Edata%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3Eindex%20%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20adElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3EpData%3CSPAN%20class%3D%22operator%20token%22%3E-%26gt%3B%3C%2FSPAN%3Edata%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3Eindex%20%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%0A%20%20%20%20%20%20%0A%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*DESIRED%20BEACON%20SCANNER%20PARSER%20CODE%20*%2F%3C%2FSPAN%3E%0A%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Move%20on%20to%20the%20next%20AD%20elemnt%20type%20*%2F%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20index%20%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20adElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Elength%20%3CSPAN%20class%3D%22operator%20token%22%3E%2B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Esizeof%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3Euint8_t%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%0A%20%0A%20%0A%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EfoundMatch%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3ESHELL_NEWLINE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_write%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22%5Cr%5CAddress%20%3A%20%20%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_writeHex%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EpData%3CSPAN%20class%3D%22operator%20token%22%3E-%26gt%3B%3C%2FSPAN%3EaAddress%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E6%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%20%0A%20%0A%20%20%20%20%20%20%20%3CSPAN%20class%3D%22keyword%20token%22%3Ereturn%3C%2FSPAN%3E%20foundMatch%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E6%82%A8%E6%89%80%E8%A7%81%EF%BC%8C%E5%87%BD%E6%95%B0%E4%B8%AD%E6%9C%89%E4%B8%80%E6%9D%A1%E6%B3%A8%E9%87%8A%E6%8F%90%E5%88%B0%E9%9C%80%E8%A6%81%E6%B7%BB%E5%8A%A0%E6%89%AB%E6%8F%8F%E4%BB%AA%E8%A7%A3%E6%9E%90%E5%99%A8%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%A0%B9%E6%8D%AE%E6%82%A8%E6%83%B3%E8%A6%81%E6%9F%A5%E7%9C%8B%E7%9A%84%E4%BF%A1%E6%A0%87%EF%BC%8C%E5%B0%86%E4%BD%BF%E7%94%A8%E5%85%B6%E4%B8%AD%E7%9A%84%E4%BB%A3%E7%A0%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23339966%3B%22%3E%3CSTRONG%3ENXP%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20function%22%3EFLib_MemCmp%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3ENXPAD%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_write%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22%5Cr%5CnFound%20NXP%20device!%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3ESHELL_NEWLINE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_write%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22%5Cr%5CnData%20Received%3A%20%20%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_writeHex%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20adElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Elength%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20foundMatch%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3ETRUE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23339966%3B%22%3E%3CSTRONG%3EiBeacon%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20function%22%3EFLib_MemCmp%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EiBeaconAd%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_write%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22%5Cr%5CnFound%20iBeacon%20device!%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3ESHELL_NEWLINE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_write%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22%5Cr%5CnData%20Received%3A%20%20%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_writeHex%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20adElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Elength%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20foundMatch%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3ETRUE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23339966%3B%22%3E%3CSTRONG%3E%E5%9F%83%E8%BF%AA%E6%96%AF%E9%80%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20function%22%3EFLib_MemCmp%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EEddyStoneUIDAd1%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_write%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22%5Cr%5CnFound%20EddyStone%20device!%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%0A%20%20%20%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E!%3C%2FSPAN%3EEddyfoundMatch%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20EddyfoundMatch%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3ETRUE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%20%20%20%20%3CSPAN%20class%3D%22keyword%20token%22%3Eelse%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3ETRUE%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3EEddyfoundMatch%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%20function%22%3EFLib_MemCmp%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EEddyStoneUIDAd2%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3ESHELL_NEWLINE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_write%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22%5Cr%5Cn%5BUID%20type%5D%20Data%20Received%3A%20%20%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_writeHex%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20adElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Elength%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20foundMatch%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3ETRUE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20EddyfoundMatch%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3EFALSE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%20%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22keyword%20token%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3ETRUE%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3EEddyfoundMatch%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%20function%22%3EFLib_MemCmp%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EEddyStoneURLAd2%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3ESHELL_NEWLINE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_write%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22%5Cr%5Cn%5BURL%20type%5D%20Data%20Received%3A%20%20%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Ehell_writeHex%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20adElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Elength%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20foundMatch%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3ETRUE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20EddyfoundMatch%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3EFALSE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%20%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22keyword%20token%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3ETRUE%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3D%3C%2FSPAN%3EEddyfoundMatch%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%20function%22%3EFLib_MemCmp%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EEddyStoneTLMAd2%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3ESHELL_NEWLINE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_write%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22%5Cr%5Cn%5BTLM%20type%5D%20Data%20Received%3A%20%20%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22token%20function%22%3Eshell_writeHex%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EadElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3EaData%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20adElement%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Elength%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20foundMatch%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3ETRUE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20EddyfoundMatch%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3EFALSE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22keyword%20token%22%3Eelse%3C%2FSPAN%3E%20%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20EddyfoundMatch%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3ETRUE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%20%0A%20%20%20%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%0A%20%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1119157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EBLE%E8%BD%AF%E4%BB%B6%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%8D%83%E7%93%A6%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%5BKW41Z%5D%20%E5%AE%9E%E7%8E%B0%E4%BF%A1%E6%A0%87%E6%89%AB%E6%8F%8F%E4%BB%AA%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%20KW36%20%E4%BD%9C%E4%B8%BA%E4%BF%A1%E6%A0%87%E7%9A%84%E4%BE%8B%E5%AD%90%EF%BC%9FKW41%20%E5%92%8C%20KW36%20%E7%9A%84%E5%A0%86%E6%A0%88%E7%9B%B8%E5%90%8C%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:42 AM
更新人:
