KW41 - Reprogramming a FRDM-KW41 board using the OTAP Client Software
Introduction
This document guides to load a new software image in a KW41 device through Over The Air Programming bootloader. Also, are explained the details of how to set up the client software to change the storage method of the image.
Software Requirements
  1. IAR Embedded Workbench IDE or MCUXpresso IDE
  2. Download both, SDK FRDM-KW41Z and SDK USB-KW41Z.
Hardware Requirements
  1. FRDM-KW41Z board
OTAP Memory Management During the Update Process
The KW41 has a 512KB Program Flash with a flash address range from 0x0000_0000 to 0x0007_FFFF.
  1. The OTAP application splits the flash into two independent parts, the OTAP Bootloader, and the OTAP Client. The OTAP Bootloader verifies if there is a new image available at the OTAP Client to reprogram the device. The OTAP Client software provides the Bluetooth LE custom service needed to communicate the OTAP Client device with the OTAP Server that contains the new image file (The OTAP Server device could be another FRDM-KW41Z connected to a PC with Test Tool or a Smartphone with IoT Toolbox app). Therefore, the OTAP Client device needs to be programmed twice, first with the OTAP Bootloader, then with the Bluetooth LE application supporting OTAP Client. The mechanism created to have two different software coexisting in the same device is storing each one in different memory regions. This functionality is implemented by the linker file. In the KW41 device, the bootloader has reserved a 16 KB slot of memory from 0x0000_0000 to 0x0003_FFFF, thus the left memory is reserved among other things, by the OTAP Client demo.pastedImage_11.png
  2. To create a new image file for the client device, the developer needs to specify to the linker file that the code will be built with an offset of 16 KB since the first addresses must be reserved for the OTAP Bootloader.pastedImage_13.png
  3. In connection state, the OTAP server sends the image packets (known as chunks) to the OTAP Client device via Bluetooth LE. The OTAP Client device can store these chunks, in first instance, at the external SPI flash or the On-Chip Flash. The destination of the code is selectable in the OTAP Client software.pastedImage_15.png
  4. When the connection has finished and all chunks were sent from the OTAP Server to the OTAP Client device, the OTAP Client software writes information, such as the source of the image update (external flash or internal flash) in a portion of memory known as Bootloader Flags and then resets the MCU to execute the OTAP Bootloader code. The OTAP Bootloader reads the Bootloader Flags to get the information needed to program the device and triggers a commando to reprogram the MCU with the new application. Due to the new application was built with an offset of 16 KB, the OTAP Bootloader programs the device starting from the 0x0000_4000 address and the OTAP Client application is overwritten by the new image, therefore, after the device has been reprogrammed through this method, cannot be programmed a second time as same. Finally, the OTAP Bootloader triggers a command to start the execution of the new code automatically.
Preparing the Software to Test the OTAP Client for KW41Z Device Using IAR Embedded Workbench
  • Program the OTAP Bootloader on the FRDM-KW41Z. Program the OTAP Bootloader software from the project included in the SDK FRDM-KW41Z at the following path, or you can simply drag and drop the pre-built binary from the following path.
        OTAP Bootloader Project:
         <SDK_2.2.0_FRDM-KW41Z_download_path>\boards\frdmkw41z\wireless_examples\framework\bootloader_otap\bm\iar\bootloader_otap_bm.eww
         OTAP Bootloader pre-built binary:
           <SDK_2.2.0_FRDM-KW41Z_download_path>\tools\wireless\binaries\bootloader_otap_frdmkw41z.bin
  • Open the OTAP Client project included in the SDK FRDM-KW41Z located in the following path.
         <SDK_2.2.0_FRDM-KW41Z_download_path>\boards\frdmkw41z\wireless_examples\bluetooth\otap_client_att\freertos\iar\otap_client_att_freertos.eww
  • Customize the OTAP Client software to select the storage method. Locate the app_preinclude.h header file inside the source folder at the workspace.
  1. To select the External Flash storage method, set the "gEepromType_d" define to "gEepromDevice_AT45DB041E_c
  2. To select the Internal Flash storage method, set the "gEepromType_d" define to "gEepromDevice_InternalFlash_c"
  • Configure the linker flags. Open the project options window (Alt + F7). In "Linker->Config" window, locate the "Configuration file symbol definitions" pane.
  1. To select the External Flash storage method, remove the "gUseInternalStorageLink_d=1" linker flag
  2. To select the Internal Flash storage method, add the "gUseInternalStorageLink_d=1" linker flag
  • Load the OTAP Client software on the FRDM-KW41Z board (Ctrl + D). Stop the debug session (Ctrl + Shift + D). The default linker configurations of the project allow the OTAP Client application to be stored with the proper memory offset.
Preparing the Software to Test the OTAP Client for KW41Z Device Using MCUXpresso IDE
         wireless_examples->framework->bootloader_otap->bm
  • Click on "Import SDK examples(s)" option in the "Quickstart Panel" view.
  • Click twice on the frdmkw41z icon.
  • Open the OTAP Client project included in the SDK FRDM-KW41Z located in the following path.wireless_examples->bluetooth->otap_client_att->freertos
  • Configure the linker file.
  1. To select the External Flash storage method, are not required any changes in the project from this point. You can skip this step.
  2. To select the Internal Flash storage method, search the linker file located in the SDK USB-KW41Z at the following path and replace instead of the default linker file at the source folder in the OTAP Client project. You can copy (Ctrl + C) the linker file from SDK USB-KW41Z and paste (Ctrl + V) on the workspace directly. A warning message will be displayed, select "Overwrite".
       Linker file at the SDK USB-KW41Z:
       <SDK_2.2.0_USB-KW41Z_download_path>\boards\usbkw41z_kw41z\wireless_examples\bluetooth\otap_client_att\freertos\MKW41Z512xxx4_connectivity.ld
  • Save the changes in the project. Select "Debug" in the "Quickstart Panel". Once the project is already loaded on the device, stop the debug session.
Creating an S-Record Image File for FRDM-KW41Z OTAP Client in IAR Embedded Workbench
  • Open the connectivity project that you want to program using the OTAP Bootloader from your SDK FRDM-KW41Z. This example will make use of the glucose sensor project, this is located at the following path.
    <SDK_2.2.0_FRDM-KW41Z_download_path>\boards\frdmkw41z\wireless_examples\bluetooth\glucose_sensor\freertos\iar\glucose_sensor_freertos.eww
  • Open the project options window (Alt+F7). In Linker->Config window, add the following linker flag in the “Configuration file symbol definitions” textbox.
        gUseBootloaderLink_d=1
  • Go to the “Output Converter” window. Deselect the “Override default" checkbox, expand the “Output format” combo box and select Motorola S-records format. Click the OK button.
  • Rebuild the project.
  • Search the S-Record file (.srec) in the following path.<SDK_2.2.0_FRDM-KW41Z_download_path>\boards\frdmkw41z\wireless_examples\bluetooth\glucose_sensor\freertos\iar\debug
Creating an S-Record Image File for FRDM-KW41Z OTAP Client in MCUXpresso IDE
  • Open the connectivity project that you want to program using the OTAP Bootloader from MCUXpresso IDE. This example will make use of the glucose sensor project, this is located at the following path.
       wireless_examples->bluetooth->glucose_sensor->freertos
  • Search the linker file located in the SDK FRDM-KW41Z at the path below and replace instead of the default linker file at the source folder in the Glucose Sensor project. You can copy (Ctrl + C) the linker file from SDK FRDM-KW41Z and paste (Ctrl + V) on the workspace directly. A warning message will be displayed, select "Overwrite".
       Linker file at the SDK FRDM-KW41Z:
       <SDK_2.2.0_FRDM-KW41Z_download_path>\boards\frdmkw41z\wireless_examples\bluetooth\otap_client_att\freertos\MKW41Z512xxx4_connectivity.ld
  • Open the new "MKW41Z512xxx4_connectivity.ld" linker file. Locate the section placement of the figure below and remove the "FILL" and the "BYTE" statements.
  • Build the project.
  • Deploy the “Binaries” icon in the workspace. Click the right mouse button on the “.axf” file. Select the “Binary Utilities/Create S-Record” option. The S-Record file will be saved at “Debug” folder in the workspace with “.s19” extension.
Testing OTAP Client Demo Using IoT Toolbox App
  1. Save the S-Record file created with the steps in the last section in your smartphone at a known location.
  2. Open the IoT Toolbox App and select OTAP demo. Press “SCAN” to start scanning for a suitable advertiser.
  3. Press the “SW4” button on the FRDM-KW41Z board to start advertising.
  6. Press “Upload” to start the transfer.
  7. Once the transfer is complete, wait a few seconds until the bootloader has finished programming the new image. The new application will start automatically.
ラベル(3)
タグ(1)
コメント
I'm porting the OTOP client example into my HRS modified program.
Compilation seems to passe now, but i have an error during Linking step.
Invoking: MCU Linker
arm-none-eabi-gcc -L"D:\OTS\Firmware\prototm\libs" -Xlinker -Map="OTS_v1.map" -Xlinker --gc-sections -Xlinker -print-memory-usage -mcpu=cortex-m0 -mthumb -T MKW41Z512xxx4_connectivity.ld -L ../source -o "OTS_v1.axf" ./utilities/fsl_debug_console.o ./startup/startup_MKW41Z4.o ./source/common/gatt_db/gatt_database.o ./source/common/ApplMain.o ./source/common/ble_conn_manager.o ./source/common/ble_controller_task.o ./source/common/ble_host_tasks.o ./source/common/ble_init.o ./source/app_config.o ./source/global.o ./source/heart_rate_sensor.o ./source/i2cGPIO.o ./source/mlx90621.o ./source/mlx91804.o ./source/mtb.o ./source/semihost_hardfault.o ./freertos/croutine.o ./freertos/event_groups.o ./freertos/fsl_tickless_lptmr.o ./freertos/fsl_tickless_systick.o ./freertos/heap_4.o ./freertos/list.o ./freertos/port.o ./freertos/queue.o ./freertos/tasks.o ./freertos/timers.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_ant_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_ble_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_common_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_gfsk_bt_0p3_h_0p5_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_gfsk_bt_0p5_h_0p32_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_gfsk_bt_0p5_h_0p5_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_gfsk_bt_0p5_h_0p7_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_gfsk_bt_0p5_h_1p0_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_gfsk_bt_0p7_h_0p5_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_mode_datarate_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_msk_config.o ./framework/XCVR/MKW41Z4/cfgs_kw4x_3x_2x/fsl_xcvr_zgbe_config.o ./framework/XCVR/MKW41Z4/dbg_ram_capture.o ./framework/XCVR/MKW41Z4/fsl_xcvr.o ./framework/XCVR/MKW41Z4/fsl_xcvr_trim.o ./framework/XCVR/MKW41Z4/ifr_radio.o ./framework/TimersManager/Source/TMR_Adapter.o ./framework/TimersManager/Source/TimersManager.o ./framework/SerialManager/Source/UART_Adapter/UART_Adapter.o ./framework/SerialManager/Source/SPI_Adapter/SPI_Adapter.o ./framework/SerialManager/Source/I2C_Adapter/I2C_Adapter.o ./framework/SerialManager/Source/SerialManager.o ./framework/SecLib/SecLib.o ./framework/Reset/Reset.o ./framework/RNG/Source/RNG.o ./framework/Panic/Source/Panic.o ./framework/OtaSupport/Source/OtaSupport.o ./framework/OSAbstraction/Source/fsl_os_abstraction_free_rtos.o ./framework/NVM/Source/NV_Flash.o ./framework/NVM/Source/NV_FsciCommands.o ./framework/ModuleInfo/ModuleInfo.o ./framework/Messaging/Source/Messaging.o ./framework/MemManager/Source/MemManager.o ./framework/MWSCoexistence/Source/MWS.o ./framework/LowPower/Source/MKW41Z/PWR.o ./framework/LowPower/Source/MKW41Z/PWRLib.o ./framework/LowPower/Source/MKW41Z/PWR_BLE.o ./framework/Lists/GenericList.o ./framework/LED/Source/LED.o ./framework/Keyboard/Source/Keyboard.o ./framework/GPIO/GPIO_Adapter.o ./framework/FunctionLib/FunctionLib.o ./framework/Flash/Internal/Flash_Adapter.o ./framework/Flash/External/Source/Eeprom_AT26DF081A.o ./framework/Flash/External/Source/Eeprom_AT45DB021E.o ./framework/Flash/External/Source/Eeprom_AT45DB041E.o ./framework/Flash/External/Source/Eeprom_AT45DB161E.o ./framework/Flash/External/Source/Eeprom_InternalFlash.o ./framework/DCDC/Source/DCDC.o ./drivers/fsl_adc16.o ./drivers/fsl_clock.o ./drivers/fsl_common.o ./drivers/fsl_dspi.o ./drivers/fsl_dspi_freertos.o ./drivers/fsl_flash.o ./drivers/fsl_gpio.o ./drivers/fsl_i2c.o ./drivers/fsl_i2c_freertos.o ./drivers/fsl_llwu.o ./drivers/fsl_lptmr.o ./drivers/fsl_lpuart.o ./drivers/fsl_lpuart_freertos.o ./drivers/fsl_ltc.o ./drivers/fsl_pmc.o ./drivers/fsl_rtc.o ./drivers/fsl_smc.o ./drivers/fsl_tpm.o ./drivers/fsl_trng.o ./board/board.o ./board/clock_config.o ./board/gpio_pins.o ./board/peripherals.o ./board/pin_mux.o ./bluetooth/profiles/tpms/tpms_service.o ./bluetooth/profiles/otap/otap_service.o ./bluetooth/profiles/ircam/ircam_service.o ./bluetooth/profiles/heart_rate/heart_rate_service.o ./bluetooth/profiles/device_info/device_info_service.o ./bluetooth/profiles/battery/battery_service.o ./bluetooth/host/config/ble_globals.o ./bluetooth/hci_transport/source/hcit_serial_interface.o ./CMSIS/system_MKW41Z4.o -lm -lc -lgcc -lnosys -l_ble_kw41z_controller -l_ble_4-2_host_peripheral_cm0p -l_crypto_m0
Memory region Used Size Region Size %age Used
Bootloader_region: 0 GB 16383 B 0.00%
TEXT_region1: 192 B 192 B 100.00%
BootFlags_region: 4 B 7 B 57.14%
TEXT_region2: 206644 B 239416 B 86.31%
InternalStorage: 0 GB 258047 B 0.00%
NVM_region: 0 GB 8191 B 0.00%
DATA_region: 33304 B 128 KB 25.41%
c:/nxp/mcuxpressoide_11.0.0_2516/ide/plugins/com.nxp.mcuxpresso.tools.win32_11.0.0.201905131304/tools/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: section .dummy VMA [1ffffffb,20000002] overlaps section .stack VMA [1ffffe18,20000217]
collect2.exe: error: ld returned 1 exit status
PRODUCT_INFO_region: 0 GB 2047 B 0.00%
make: *** [makefile:75: OTS_v1.axf] Error 1
"make -r -j12 all" terminated with exit code 2. Build might be incomplete.
17:13:22 Build Failed. 2 errors, 13 warnings. (took 8s.618ms)
I followed the tutorial by using the .ld files from SDK USB-KW41Z.
My programe was a bit too big : 105% of the 512/2 -16 Ko of bootloader. So i had to enable the compilation optimisation option "for size". I don' t think it can have an impact but i give this input in case of ....
What is this dummy partition it point for please ?
Is there a workaround to solve the issue please ?
I removed the dummy section and it build and link too. But when i run in Debug mode the program can not start and doesn' go till the Hardware first init breakpoint.
dummy __dummy_start :
. += 8;
} =0x90909090
I laso notice that  inb your tutorial, gEepromType_d sould be in app_preinclude.h header file but for me it is in board.h in sdk.
I tried to check to change ld file in otap client example by the one in usb sdk and change gEepromType_d  for internal storage, there is also error at linking step with bootlader section this time.
What are the step the properly migrate source code from otap client into hrs example for example please? i did by colmparing the two projects and incorporing line by line from otap client to hrs. It build but there is probleme with linking step. I regret that it is the own step missing for my project to be complete.
Thanks for support, i'm a bit stuck here :smileyhappy:
Hello [email protected]‌,
Could you please confirm which version of SDK do you have?  You can verify it in the installed SDKs perspective in MCUXpresso IDE (or simply you can go to https://mcuxpresso.nxp.com/en/dashboard and check for updates).
We recommend to download and install the newest SDK package (SDK 2.2.1) to discard some issues related to version compatibility. My suspect is that you have older software due DATA_region linker section does not match with the new release that splits this section into two parts: DATA1_region and DATA2_region. Did you modify the linker file to create this section?.
We are already working on release an application note explaining the details of OTAP integration on the HRS demo for FRDM-KW36. I will inform you in a few weeks when we planned to release the document.
Best regards.
Hi nxf46726,
Thanks for your help.
Sdk version is at the moment 2.2.0
Thanks for writting the tutorial.
1. Do you have an idea if it will be done? for this month or next one may be ? Just to organize my self and see if i can progress anyway.
What i did was to merge OTAP example into HRS : file missing, add the Timer callback and pieces of code here and there . It build but not linked with USB ld file
2. Do you advise to start from hrs and import otap code into it or start from otap nd move hrs into it ?
I have compared otap client demo code from sdk 2.2.0 and 2.2.1. I see some correction on complete transfert flag etc so yes , it will be better to restart from sdk 2.2.1 it seems.
3. Why should we use the USB ld file and not the OTAP client for internal flash memory ota ?
I really look forword your nice tutorial to do this properly.
Thank you so much
1. The application note will be released around half of the next month.
2. The best way to integrate OTAP is first basing on your application and then include the OTAP service on it. In other words, using the HRS as a starting point and then integrate the OTAP into it. This is done in this way because if in the future you need to integrate OTAP on another application, for example, the Glucose Sensor, the steps required are similar (probably, the same steps).
3. The linker file decides how the code must be stored on the device, also, it has the ability to reserve slots of memory for other purposes, in this case, we need to reserve a section for internal storage. The USB-KW41 board does not have an external flash, instead, it uses the internal storage method as default, so, the USB-KW41 linker already contains the proper linker memory sections for internal storage enablement. We recommend to use it because is the easiest and fastest way to get the example working (which is the purpose of this document), another way, the programmer would edit and customize the linker file to reserve the memory slot needed.
Regards.
Ok 100% clear,
I will then update all my tools and put OTA into HRS, then if all works fine, integrated my code into it.
GO back to 0 :smileysad: lol.
Thanks a lot i hope i will succeed in it, worth case in one month i will be able to compare with your method.
Thanks a lot Edgar for your precious help.
%3CLINGO-SUB%20id%3D%22lingo-sub-1108868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW41%20-%20OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFRDM-KW41%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%20size%3D%225%22%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81Over%20The%20Air%20Programming%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20KW41%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%96%B9%E6%B3%95%E3%82%82%E8%A9%B3%E3%81%97%E3%81%8F%E8%A7%A3%E8%AA%AC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%225%22%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22%3B%20font-size%3A%2022px%3B%22%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E8%A6%81%E4%BB%B6%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%22%3EIAR%20Embedded%20Workbench%20IDE%E3%81%BE%E3%81%9F%E3%81%AFMCUXpresso%20IDE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3ESDK%20FRDM-KW41Z%E3%81%A8SDK%20USB-KW41Z%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%225%22%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A6%81%E4%BB%B6%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3EFRDM-KW41Z%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3E%E6%9B%B4%E6%96%B0%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%81%AE%20OTAP%20%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3EKW41%20%E3%81%AB%E3%81%AF%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E7%AF%84%E5%9B%B2%E3%81%8C%200x0000_0000%20%E3%81%8B%E3%82%89%200x0007_FFFF%20%E3%81%BE%E3%81%A7%E3%81%AE%20512KB%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20321px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F82515i960D96BAFF0B3C1C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CFONT%20color%3D%22%23000000%22%3EOTAP%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92OTAP%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%A8OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE2%E3%81%A4%E3%81%AE%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9F%E9%83%A8%E5%88%86%E3%81%AB%E5%88%86%E5%89%B2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82OTAP%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20OTAP%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E7%94%BB%E5%83%8F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%90%AB%E3%82%80OTAP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A8OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%80%9A%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AABluetooth%20LE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99(OTAP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E5%82%99%E3%81%88%E3%81%9FPC%E3%81%BE%E3%81%9F%E3%81%AFIoT%20Toolbox%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%E3%83%95%E3%82%A9%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%88%A5%E3%81%AEFRDM-KW41Z%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%ABOTAP%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%ABOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8BBluetooth%20LE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%812%E5%9B%9E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E3%81%98%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%86%85%E3%81%AB%202%20%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%85%B1%E5%AD%98%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%82%92%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%AF%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82KW41%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%200x0000_0000%20%E3%81%8B%E3%82%89%200x0003_FFFF%20%E3%81%BE%E3%81%A7%2016%20KB%20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%92%E4%BA%88%E7%B4%84%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%B7%A6%E5%81%B4%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AF%20OTAP%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%20%E3%83%87%E3%83%A2%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%89%B9%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FFONT%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20450px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84345i38F3784A15B1F2EC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_11.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%94%A8%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%20OTAP%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E9%96%8B%E7%99%BA%E8%80%85%E3%81%AF%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%2016%20KB%20%E3%81%AE%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%20style%3D%22width%3A%20450px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F85384iBA619E5796DEC60B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_13.png%22%20alt%3D%22pastedImage_13.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_13.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E6%8E%A5%E7%B6%9A%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AF%E3%80%81OTAP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AFBluetooth%20LE%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E7%94%BB%E5%83%8F%E3%83%91%E3%82%B1%E3%83%83%E3%83%88(%E3%83%81%E3%83%A3%E3%83%B3%E3%82%AF%E3%81%A8%E5%91%BC%E3%81%B0%E3%82%8C%E3%82%8B)%E3%82%92OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E3%80%81%E5%A4%96%E9%83%A8SPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%81%E3%83%A3%E3%83%B3%E3%82%AF%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%AE%9B%E5%85%88%E3%81%AF%E3%80%81OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_15.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%20style%3D%22width%3A%20963px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84541i41B5DB14F1B8B97A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_15.png%22%20alt%3D%22pastedImage_15.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_15.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E6%8E%A5%E7%B6%9A%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%81%E3%83%A3%E3%83%B3%E3%82%AF%E3%81%8COTAP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E6%9B%B4%E6%96%B0%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9(%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%BE%E3%81%9F%E3%81%AF%E5%86%85%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5)%E3%81%AA%E3%81%A9%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%95%E3%83%A9%E3%82%B0%E3%81%A8%E5%91%BC%E3%81%B0%E3%82%8C%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%81MCU%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6OTAP%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82OTAP%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7MCU%E3%82%92%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%2016%20KB%20%E3%81%AE%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81OTAP%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%200x0000_4000%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8B%E3%82%89%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%80%81OTAP%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AF%E3%80%81%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%202%20%E5%9B%9E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81OTAP%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_18.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%20style%3D%22width%3A%20450px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84445i7178B5ECF5565A22%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_18.png%22%20alt%3D%22pastedImage_18.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_18.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20size%3D%225%22%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3EIAR%20Embedded%20Workbench%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6KW41Z%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%94%A8%E3%81%AEOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%BA%96%E5%82%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3EOTAP%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%82%92FRDM-KW41Z%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SDK%20FRDM-KW41Z%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8B%E3%82%89OTAP%20Bootloader%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%8B%E3%82%89%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BF%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%89%E3%83%A9%E3%83%83%E3%82%B0%E3%82%A2%E3%83%B3%E3%83%89%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3EOTAP%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%23993300%3B%20font-size%3A%2013px%3B%22%3E%3CEM%3E%3CSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%5Cboards%5Cfrdmkw41z%5Cwireless_examples%5Cframework%5Cbootloader_otap%5Cbm%5Ciar%5Cbootloader_otap_bm.eww%3C%2FSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3EOTAP%20Bootloader%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BF%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%3A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%23993300%3B%20font-size%3A%2013px%3B%22%3E%3CEM%3E%3CSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%5Ctools%5Cwireless%5Cbinaries%5Cbootloader_otap_frdmkw41z.bin%3C%2FSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8BSDK%20FRDM-KW41Z%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23993300%3B%20font-size%3A%2013px%3B%22%3E%3CEM%3E%3CSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%5C%E3%83%9C%E3%83%BC%E3%83%89%5CFRDMKW41z%5Cwireless_examples%5Cbluetooth%5Cotap_client_att%5Cfreertos%5Ciar%5Cotap_client_att_freertos.eww%3C%2FSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3EOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%97%E3%81%A6%E3%80%81%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82app_preinclude.h%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%99%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E5%86%85%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3COL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3E%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%23008080%3B%20background-color%3A%20%23ffffff%3B%22%3EgEepromType_d%3C%2FSPAN%3E%E3%80%8D%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%23008080%3B%22%3EgEepromDevice_AT45DB041E_c%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3E%E5%86%85%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008080%3B%20background-color%3A%20%23ffffff%3B%22%3EgEepromType_d%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8D%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%23008080%3B%22%3EgEepromDevice_InternalFlash_c%3C%2FSPAN%3E%E3%80%8D%3C%2FSPAN%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%3E%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%20%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99(Alt%20%2B%20F7)%E3%80%82%5BLinker-%26gt%3BConfig%5D%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7%E3%80%81%5BConfiguration%20file%20symbol%20definitions%5D%20%E3%83%9A%E3%82%A4%E3%83%B3%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3COL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%23008080%3B%22%3EgUseInternalStorageLink_d%3D1%3C%2FSPAN%3E%E3%80%8D%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3E%E5%86%85%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E6%96%B9%E5%BC%8F%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%23008080%3B%22%3EgUseInternalStorageLink_d%3D1%3C%2FSPAN%3E%E3%80%8D%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_321.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_321.png%22%20style%3D%22width%3A%20568px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F81859i0500E1DB246EAF7F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_321.png%22%20alt%3D%22pastedImage_321.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_321.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92FRDM-KW41Z%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99(Ctrl%20%2B%20D)%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%20(Ctrl%20%2B%20Shift%20%2B%20D)%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E6%97%A2%E5%AE%9A%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%81OTAP%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%81%A9%E5%88%87%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E6%A0%BC%E7%B4%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2022px%3B%22%3E%3CSTRONG%3EMCUXpresso%20IDE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6KW41Z%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AEOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%BA%96%E5%82%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3EOTAP%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%82%92FRDM-KW41Z%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SDK%20FRDM-KW41Z%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8B%E3%82%89OTAP%20Bootloader%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%8B%E3%82%89%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BF%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%89%E3%83%A9%E3%83%83%E3%82%B0%E3%82%A2%E3%83%B3%E3%83%89%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%3CFONT%20color%3D%22%23000000%22%3EOTAP%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%3C%2FFONT%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%23993300%3B%20font-size%3A%2013px%3B%22%3E%3CEM%3Ewireless_examples-%26gt%3B%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%26gt%3Bbootloader_otap-%26gt%3BBM%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CFONT%20color%3D%22%23000000%22%3EOTAP%20Bootloader%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BF%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%3A%3C%2FFONT%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%23993300%3B%20font-size%3A%2013px%3B%22%3E%3CEM%3E%3CSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%5Ctools%5Cwireless%5Cbinaries%5Cbootloader_otap_frdmkw41z.bin%3C%2FSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%23993300%3B%20font-size%3A%2013px%3B%22%3E%3CEM%3E%26nbsp%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%3E%5BQuickstart%20Panel%5D%20%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%20%5BImport%20SDK%20examples(s)%5D%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%3Efrdmkw41z%E3%82%A2%E3%82%A4%E3%82%B3%E3%83%B3%E3%82%922%E5%9B%9E%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_319.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_319.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F87634i4AEEF255DB136B96%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_319.png%22%20alt%3D%22pastedImage_319.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_319.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%3E%3CFONT%20color%3D%22%23000000%22%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8BSDK%20FRDM-KW41Z%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%3C%2FFONT%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23993300%3B%20font-size%3A%2013px%3B%22%3E%3CEM%3Ewireless_examples-%26gt%3BBluetooth-%26gt%3Botap_client_att-%26gt%3B%E3%83%95%E3%83%AA%E3%83%BC%E3%83%88%E3%82%B9%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23993300%3B%20font-size%3A%2013px%3B%22%3E%3CEM%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_320.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_320.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F81831i07EEFE41DD8A1CC7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_320.png%22%20alt%3D%22pastedImage_320.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_320.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%22%3EOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%97%E3%81%A6%E3%80%81%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82app_preinclude.h%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%99%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E5%86%85%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3COL%20style%3D%22color%3A%20%233d3d3d%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%0A%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3E%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%23008080%3B%20background-color%3A%20%23ffffff%3B%22%3EgEepromType_d%3C%2FSPAN%3E%E3%80%8D%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%23008080%3B%22%3EgEepromDevice_AT45DB041E_c%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20color%3A%20%23000000%3B%22%3E%E5%86%85%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23008080%3B%20background-color%3A%20%23ffffff%3B%22%3EgEepromType_d%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8D%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%23008080%3B%22%3EgEepromDevice_InternalFlash_c%3C%2FSPAN%3E%E3%80%8D%3C%2FSPAN%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3COL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%8B%E3%82%89%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E5%86%85%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E6%96%B9%E5%BC%8F%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3ESDK%20USB-KW41Z%3C%2FSPAN%3E%20%E3%81%AE%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8B%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%80%81OTAP%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AB%E3%81%82%E3%82%8B%E6%97%A2%E5%AE%9A%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3ESDK%20USB-KW41Z%3C%2FSPAN%3E%E3%81%8B%E3%82%89%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC(Ctrl%2BC)%E3%81%97%E3%80%81%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AB%E7%9B%B4%E6%8E%A5%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91(Ctrl%2BV)%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%80%8C%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ESDK%20USB-KW41Z%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2013px%3B%22%3E%3CEM%3E%3CSPAN%20style%3D%22color%3A%20%23993300%3B%22%3E%3CSDK_2.2.0_USB-KW41Z_DOWNLOAD_PATH%3E%5C%E3%83%9C%E3%83%BC%E3%83%89%5Cusbkw41z_kw41z%5Cwireless_exa%3C%2FSDK_2.2.0_USB-KW41Z_DOWNLOAD_PATH%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23993300%3B%22%3Emples%5Cbluetooth%5Cotap_client_att%5Cfreertos%5CMKW41Z512xxx4_connectivity.ld%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_413.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_413.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F82430i363E5C35D8BB181D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_413.png%22%20alt%3D%22pastedImage_413.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_413.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%83%91%E3%83%8D%E3%83%AB%E3%80%8D%E3%81%A7%E3%80%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E6%97%A2%E3%81%AB%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3EIAR%20Embedded%20Workbench%E3%81%A7%E3%81%AEFRDM-KW41Z%20OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E7%94%A8%E3%81%AES%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ESDK%20FRDM-KW41Z%E3%81%AEOTAP%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E6%8E%A5%E7%B6%9A%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B0%E3%83%AB%E3%82%B3%E3%83%BC%E3%82%B9%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%88%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20color%3A%20%23993300%3B%22%3E%3CEM%3E%3CSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%5C%E3%83%9C%E3%83%BC%E3%83%89%5Cfrdmkw41z%5Cwireless_examples%5Cbluetooth%5Cglucose_sensor%5Cfreertos%5Ciar%5Cglucose_sensor_freertos.eww%3C%2FSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20color%3A%20%23000000%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99(Alt%20%2B%20F7)%E3%80%82%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%26gt%3BConfig%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7%E3%80%81%5B%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E5%AE%9A%E7%BE%A9%5D%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20color%3A%20%23000000%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20color%3A%20%23008080%3B%22%3E%3CEM%3EgUseBootloaderLink_d%3D1%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20572px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84447i403E8F112F85B80E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%80%8C%E5%87%BA%E5%8A%9B%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%8D%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%82%92%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E3%80%8D%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E9%81%B8%E6%8A%9E%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%80%81%E3%80%8C%E5%87%BA%E5%8A%9B%E5%BD%A2%E5%BC%8F%E3%80%8D%E3%82%B3%E3%83%B3%E3%83%9C%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E5%B1%95%E9%96%8B%E3%81%97%E3%81%A6%E3%80%81Motorola%20S-records%E5%BD%A2%E5%BC%8F%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%5BOK%5D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20566px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84542i668D9A449BD27548%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%AA%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CFONT%20color%3D%22%23000000%22%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%A7S%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB(.srec)%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%BE%E3%81%99%3C%2FFONT%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23993300%3B%20font-size%3A%2013px%3B%22%3E%3CEM%3E%3CSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%5C%E3%83%9C%E3%83%BC%E3%83%89%5CFRDMKW41Z%5Cwireless_examples%5CBluetooth%5Cglucose_sensor%5CFreeRTOS%5CIAR%5Cdebug%3C%2FSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3EMCUXpresso%20IDE%E3%81%A7%E3%81%AEFRDM-KW41Z%20OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E7%94%A8%E3%81%AES%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3EMCUXpresso%20IDE%20%E3%81%AE%20OTAP%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E6%8E%A5%E7%B6%9A%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B0%E3%83%AB%E3%82%B3%E3%83%BC%E3%82%B9%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%88%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%91%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23993300%3B%22%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20style%3D%22font-size%3A%2013px%3B%22%3Ewireless_examples-%26gt%3BBluetooth-%26gt%3Bglucose_sensor-%26gt%3B%E3%83%95%E3%83%AA%E3%83%BC%E3%83%88%E3%82%B9%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3ESDK%20FRDM-KW41Z%3C%2FSPAN%3E%3CSPAN%3E%20%E3%81%AB%E3%81%82%E3%82%8B%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%83%AA%E3%83%B3%E3%82%AB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%20%E3%80%81Glucose%20Sensor%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%81%82%E3%82%8B%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%20SDK%20FRDM-KW41Z%3C%2FSPAN%3E%3CSPAN%3E%20%E3%81%8B%E3%82%89%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC(Ctrl%2BC)%20%E3%81%97%E3%80%81%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AB%E7%9B%B4%E6%8E%A5%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91(Ctrl%2BV)%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%80%8C%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ESDK%20FRDM-KW41Z%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%22%3E%3CEM%3E%3CSPAN%20style%3D%22color%3A%20%23993300%3B%22%3E%3CSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%5C%E3%83%9C%E3%83%BC%E3%83%89%5C%3CSPAN%20style%3D%22color%3A%20%23993300%3B%22%3E%3CEM%3EFRDMKW41z%3C%2FEM%3E%3C%2FSPAN%3E%5Cwireless_exa%3C%2FSDK_2.2.0_FRDM-KW41Z_DOWNLOAD_PATH%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23993300%3B%22%3EMPLES%5CBluetooth%5Cotap_client_att%5CFreeRTOS%5CMKW41Z512xxx4_connectivity.ld%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2013px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84834iC3743F094BB37A80%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20color%3D%22%23000000%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E6%96%B0%E3%81%97%E3%81%84%E3%80%8CMKW41Z512xxx4_connectivity.ld%E3%80%8D%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%E6%AC%A1%E3%81%AE%E5%9B%B3%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E9%85%8D%E7%BD%AE%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%A6%E3%80%81%E3%80%8CFILL%E3%80%8D%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E3%80%8CBYTE%E3%80%8D%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20513px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F87635i0E9C7270FE0D9A24%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AB%20%22Binaries%22%20%E3%82%A2%E3%82%A4%E3%82%B3%E3%83%B3%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82.axf%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E4%B8%8A%E3%81%A7%E3%83%9E%E3%82%A6%E3%82%B9%E3%81%AE%E5%8F%B3%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CBinary%20Utilities%2FCreate%20S-Record%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82S-Record%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E5%86%85%E3%81%AE%E3%80%8CDebug%E3%80%8D%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E6%8B%A1%E5%BC%B5%E5%AD%90%E3%80%8C.s19%E3%80%8D%E3%81%A7%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20693px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F85114i576861937243C537%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3EIoT%20Toolbox%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20OTAP%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%20%E3%83%87%E3%83%A2%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9FS-Record%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%E3%83%95%E3%82%A9%E3%83%B3%E3%81%AE%E6%97%A2%E7%9F%A5%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EIoT%20Toolbox%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81OTAP%20%E3%83%87%E3%83%A2%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%80%8D%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81%E9%81%A9%E5%88%87%E3%81%AA%E5%BA%83%E5%91%8A%E4%B8%BB%E3%81%AE%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EFRDM-KW4Z%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%80%8CSW41%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81%E5%BA%83%E5%91%8A%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E8%A6%8B%E3%81%A4%E3%81%8B%E3%81%A3%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20225px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F85170iF0578B099640BD7B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%8C%E9%96%8B%E3%81%8F%E3%80%8D%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81S%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20225px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84359i4D0342726120F45B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_10.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%8C%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%80%8D%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E8%BB%A2%E9%80%81%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E8%BB%A2%E9%80%81%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E6%95%B0%E7%A7%92%E5%BE%85%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1108868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EBLE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EkW%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKW41Z%20%7C%2031Z%20%7C%2021Z%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFRDM-KW41%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E100%25%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%80%81OTA%20%E3%82%92%20HRS%20%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%20HRS%20%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E0%E3%81%AB%E6%88%BB%E3%82%8A%E3%81%BE%E3%81%99%3CIMG%20id%3D%22smileysad%22%20class%3D%22emoticon%20emoticon-smileysad%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-sad.png%22%20alt%3D%22Smiley%20Sad%22%20title%3D%22Smiley%20Sad%22%20%2F%3E%E7%AC%91%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%8F%E3%81%95%E3%82%93%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%A7%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%811%E3%83%B6%E6%9C%88%E3%81%A7%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%89%E3%82%AC%E3%83%BC%E3%81%95%E3%82%93%E3%80%81%E8%B2%B4%E9%87%8D%E3%81%AA%E3%81%94%E5%8D%94%E5%8A%9B%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFRDM-KW41%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fflorian.lebrun59%40gmail.com%22%20target%3D%22_blank%22%3Eflorian.lebrun59%40gmail.com%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E1.%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AF%E6%9D%A5%E6%9C%88%E5%8D%8A%E3%81%B0%E9%A0%83%E3%81%AB%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2.%20OTAP%E3%82%92%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E6%9C%80%E5%96%84%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E3%81%BE%E3%81%9A%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E3%81%9D%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%ABOTAP%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E8%A8%80%E3%81%84%E6%8F%9B%E3%81%88%E3%82%8C%E3%81%B0%E3%80%81HRS%E3%82%92%E5%87%BA%E7%99%BA%E7%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81OTAP%E3%82%92%E3%81%9D%E3%82%8C%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E5%B0%86%E6%9D%A5%E3%80%81OTAP%E3%82%92%E5%88%A5%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3(%E3%82%B0%E3%83%AB%E3%82%B3%E3%83%BC%E3%82%B9%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AA%E3%81%A9)%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%AF%E9%A1%9E%E4%BC%BC%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99(%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E5%90%8C%E3%81%98%E6%89%8B%E9%A0%86)%E3%80%82%3C%2FP%3E%3CP%3E3.%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%B1%BA%E5%AE%9A%E3%81%97%E3%80%81%E3%81%BE%E3%81%9F%E3%80%81%E4%BB%96%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%92%E4%BA%88%E7%B4%84%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%86%85%E9%83%A8%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E7%94%A8%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BA%88%E7%B4%84%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3EUSB-KW41%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E5%86%85%E9%83%A8%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E6%96%B9%E5%BC%8F%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%3C%2FSPAN%3EUSB-KW41%E3%83%AA%E3%83%B3%E3%82%AB%E3%81%AB%E3%81%AF%E3%80%81%E5%86%85%E9%83%A8%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E9%81%A9%E5%88%87%E3%81%AA%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E4%BE%8B%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%9C%80%E3%82%82%E7%B0%A1%E5%8D%98%E3%81%A7%E6%9C%80%E9%80%9F%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%82%E3%82%8A%20(%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%A7%E3%81%99)%E3%80%81%E5%88%A5%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%81%8C%E3%83%AA%E3%83%B3%E3%82%AB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%97%E3%81%A6%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%92%E4%BA%88%E7%B4%84%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFRDM-KW41%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnxf46726%22%20target%3D%22_blank%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFnxf46726%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESdk%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF2.2.0%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20936px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F81018i7CE660142BC59D7C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%92%E6%9B%B8%E3%81%84%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%E3%81%9D%E3%82%8C%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E4%BB%8A%E6%9C%88%E3%81%BE%E3%81%9F%E3%81%AF%E6%9D%A5%E6%9C%88%E3%81%AF%3F%E3%81%9F%E3%81%A0%E8%87%AA%E5%88%86%E3%82%92%E6%95%B4%E7%90%86%E3%81%97%E3%81%A6%E3%80%81%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E9%80%B2%E6%AD%A9%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81OTAP%E3%81%AE%E4%BE%8B%E3%82%92HRS%E3%81%AB%E3%83%9E%E3%83%BC%E3%82%B8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%3A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%A8%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%96%AD%E7%89%87%E3%82%92%E3%81%82%E3%81%A1%E3%81%93%E3%81%A1%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81USB%20ld%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20hrs%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%A6otap%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81otap%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%A6hrs%E3%82%92%E7%A7%BB%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3Esdk%202.2.0%E3%81%A82.2.1%E3%81%AEotap%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E3%83%87%E3%83%A2%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%AE%8C%E5%85%A8%E3%81%AA%E8%BB%A2%E9%80%81%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AA%E3%81%A9%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E4%BF%AE%E6%AD%A3%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%AF%E3%81%84%E3%80%81sdk%202.2.1%E3%81%8B%E3%82%89%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E6%96%B9%E3%81%8C%E8%89%AF%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20%E5%86%85%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AAota%E3%81%ABOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FUSB%20ld%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%93%E3%82%8C%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E8%A1%8C%E3%81%86%E3%81%9F%E3%82%81%E3%81%AE%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFRDM-KW41%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fflorian.lebrun59%40gmail.com%22%20target%3D%22_blank%22%3Eflorian.lebrun59%40gmail.com%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3ESDK%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82MCUXpresso%20IDE%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FSDK%E3%81%AE%E3%83%91%E3%83%BC%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99(%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fen%2Fdashboard%22%20title%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fen%2Fdashboard%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%8D%98%E3%81%AB%20https%3A%2F%2Fmcuxpresso.nxp.com%2Fen%2Fdashboard%3C%2FA%3E%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%A6%E6%9B%B4%E6%96%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E6%96%B0%E3%81%AE%20SDK%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20(SDK%202.2.1)%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%80%81%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%A0%B4%E6%A3%84%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E7%96%91%E3%81%84%E3%81%AF%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92DATA1_region%E3%81%A8DATA2_region%E3%81%AE2%E3%81%A4%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AB%E5%88%86%E5%89%B2%E3%81%99%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81DATA_region%E5%8F%A4%E3%81%84%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%80%81FRDM-KW36%E3%81%AEHRS%E3%83%87%E3%83%A2%E3%81%A7%E3%81%AEOTAP%E7%B5%B1%E5%90%88%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%95%B0%E9%80%B1%E9%96%93%E5%BE%8C%E3%81%AB%E3%80%81%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E4%BA%88%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E6%99%82%E6%9C%9F%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFRDM-KW41%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%80%E3%83%9F%E3%83%BC%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E9%96%8B%E5%A7%8B%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%BE%E3%81%A7%E9%80%B2%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%80%E3%83%9F%E3%83%BC__dummy_start%20%3A%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20.%2B%3D%208%3B%3CBR%20%2F%3E%20%7D%20%3D0x90909090%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%A7%E3%80%81gEepromType_d%20app_preinclude.h%E3%81%AB%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8F%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AFSDK%E3%81%AEboard.h%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eotap%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E4%BE%8B%E3%81%A7%20ld%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20usb%20sdk%20%E3%81%AE%201%20%E3%81%A4%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%3CSPAN%3E%E5%86%85%E9%83%A8%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%AE%20gEepromType_d%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BB%8A%E5%9B%9E%E3%81%AF%20bootlader%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%82%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92otap%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8B%E3%82%89hrs%E3%81%AE%E4%BE%8B%E3%81%AB%E9%81%A9%E5%88%87%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AF2%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%81%BE%E3%81%A8%E3%82%81%E3%80%81OTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8B%E3%82%89HRS%E3%81%AB%E8%A1%8C%E3%81%94%E3%81%A8%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%A7%E5%AE%9F%E7%8F%BE%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8C%E5%AE%8C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E6%AC%A0%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E8%87%AA%E4%BD%93%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E5%B0%91%E3%81%97%E7%AB%8B%E3%81%A1%E5%BE%80%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AOTAP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FFRDM-KW41%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOTOP%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E4%BE%8B%E3%82%92HRS%E5%A4%89%E6%9B%B4%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%AF%E4%BB%8A%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%3AMCU%E3%83%AA%E3%83%B3%E3%82%AB%3CBR%20%2F%3Earm-none-eabi-gcc%20-L%22D%3A%5COTS%5CFirmware%5Cprototm%5Clibs%22%20-Xlinker%20-map%3D%22OTS_v1.map%22-Xlinker%20--gc-sections%20-Xlinker%20-print-memory-usage%20-mcpu%3Dcortex-m0%20-mthumb%20-T%20MKW41Z512xxx4_connectivity.ld%20-L%20..%2Fsource%20-o%20%22OTS_v1.axf%22.%2Futilities%2Ffsl_debug_console.o%20.%2Fstartup%2Fstartup_MKW41Z4.o%20.%2Fsource%2Fcommon%2Fgatt_db%2Fgatt_database.o%20.%2Fsource%2Fcommon%2FApplMain.o%20.%2Fsource%2Fcommon%2F.ble_conn_manager.o%20.%2Fsource%2Fcommon%2Fble_controller_task.o%20.%2Fsource%2Fcommon%2Fble_host_tasks.o%20.%2Fsource%2Fcommon%2Fble_init.o%20.%2Fsource%2Fapp_config.o%20.%2Fsource%2Fglobal.o%20.%2Fsource%2Fheart_rate_sensor.o%20.%2Fsource%2Fi2cGPIO.o%20.%2Fsource%2Fmlx90621.o%20.%2Fsource%2Fmlx91804.o%20.%2Fsource%2Fmtb.o.%2Fsource%2Fsemihost_hardfault.o%20.%2Ffreertos%2Fcroutine.o%20.%2Ffreertos%2Fevent_groups.o%20.%2Ffreertos%2Ffsl_tickless_lptmr.o%20.%2Ffreertos%2Ffsl_tickless_systick.o%20.%2Ffreertos%2F-heap_4.o%20.%2Ffreertos%2Flist.o%20.%2Ffreertos%2Fport.o%20.%2Ffreertos%2Fqueue.o%20.%2Ffreertos%2Ftasks.o%20.%2Ffreertos%2Ftimers.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_ant_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_ble_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_common_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_gfsk_bt_0p3_h_0p5_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_gfsk_bt_0p5_h_0p32_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_gfsk_bt_0p5_h_0p5_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_gfsk_bt_0p5_h_0p7_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_gfsk_bt_0p5_h_1p0_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_gfsk_bt_0p7_h_0p5_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_mode_datarate_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_msk_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fcfgs_kw4x_3x_2x%2Ffsl_xcvr_zgbe_config.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fdbg_ram_capture.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Ffsl_xcvr.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Ffsl_xcvr_trim.o%20.%2Fframework%2FXCVR%2FMKW41Z4%2Fifr_radio.o%20.%2Fframework%2FTimersManager%2FSource%2FTMR_Adapter.o%20.%2Fframework%2FTimersManager%2FSource%2FTimersManager.o%20.%2Fframework%2FSerialManager%2FSource%2FUART_Adapter%2FUART_Adapter.o%20.%2Fframework%2FSerialManager%2FSource%2FSPI_Adapter%2FSPI_Adapter.o%20.%2Fframework%2FSerialManager%2FSource%2FI2C_Adapter%2FI2C_Adapter.o%20.%2Fframework%2FSerialManager%2FSource%2FSerialManager.o%20.%2Fframework%2FSecLib%2FSecLib.o%20.%2Fframework%2FReset%2FReset.o%20.%2Fframework%2FRNG%2FSource%2FRNG.o%20.%2Fframework%2FPanic%2FSource%2FPanic.o%20.%2Fframework%2FOtaSupport%2FSource%2FOtaSupport.o%20.%2Fframework%2FOSAbstraction%2FSource%2Ffsl_os_abstraction_free_rtos.o%20.%2Fframework%2FNVM%2FSource%2FNV_Flash.o%20.%2Fframework%2FNVM%2FSource%2FNV_FsciCommands.o%20.%2Fframework%2FModuleInfo%2FModuleInfo.o%20.%2Fframework%2FMessaging%2FSource%2FMessaging.o%20.%2Fframework%2FMemManager%2FSource%2FMemManager.o%20.%2Fframework%2FMWSCoexistence%2FSource%2FMWS.o%20.%2Fframework%2FLowPower%2FSource%2FMKW41Z%2FPWR.o%20.%2Fframework%2FLowPower%2FSource%2FMKW41Z%2FPWRLib.o%20.%2Fframework%2FLowPower%2FSource%2FMKW41Z%2FPWR_BLE.o%20.%2Fframework%2FLists%2FGenericList.o%20.%2Fframework%2FLED%2FSource%2FLED.o%20.%2Fframework%2FKeyboard%2FSource%2FKeyboard.o%20.%2Fframework%2FGPIO%2FGPIO_Adapter.o%20.%2Fframework%2FFunctionLib%2FFunctionLib.o%20.%2Fframework%2FFlash%2FInternal%2FFlash_Adapter.o%20.%2Fframework%2FFlash%2F%E5%A4%96%E9%83%A8%2F%E3%82%BD%E3%83%BC%E3%82%B9%2FEeprom_AT26DF081A.o%20.%2Fframework%2FFlash%2FExternal%2FSource%2FEeprom_AT45DB021E.o%20.%2Fframework%2FFlash%2FExternal%2FSource%2FEeprom_AT45DB041E.o%20.%2Fframework%2FFlash%2FExternal%2FSource%2FEeprom_AT45DB161E.o%20.%2Fframework%2FFlash%2FExternal%2FSource%2FEeprom_InternalFlash.o%20.%2Fframework%2FDCDC%2FSource%2FDCDC.o%20.%2Fdrivers%2Ffsl_adc16.o%20.%2Fdrivers%2Ffsl_clock.o%20.%2Fdrivers%2Ffsl_common.o%20.%2Fdrivers%2Ffsl_dspi.o%20.%2Fdrivers%2Ffsl_dspi_freertos.o%20.%2Fdrivers%2Ffsl_flash.o%20.%2Fdrivers%2Ffsl_gpio.o%20.%2Fdrivers%2Fdrivers%2Ffsl_i2c.o%20.%2Fdrivers%2Ffsl_i2c_freertos.o%20.%2Fdrivers%2Ffsl_llwu.o%20.%2Fdrivers%2Ffsl_lptmr.o%20.%2Fdrivers%2F.to%20fsl_lpuart.o%20.%2Fdrivers%2Ffsl_lpuart_freertos.o%20.%2Fdrivers%2Ffsl_ltc.o%20.%2Fdrivers%2Ffsl_pmc.o%20.%2Fdrivers%2Ffsl_rtc.o%20.%2Fdrivers%2Ffsl_smc.o%20.%2Fdrivers%2Ffsl_tpm.o%20.%2Fdrivers%2Ffsl_trng.o%20.%2Fboard%2Fboard.o%20.%2Fboard%2Fclock_config.o%20.%2Fboard%2Fgpio_pins.o%20.%2Fboard%2Fperipherals.o%20.%2Fboard%2Fpin_mux.o%20.%2Fbluetooth%2Fprofiles%2Ftpms%2Ftpms_service.o%20.%2Fbluetooth%2Fprofiles%2Fotap%2Fotap_service.o%20.%2Fbluetooth%2Fprofiles%2Fircam%2Fircam_service%20s.o%20.%2Fbluetooth%2Fprofiles%2Fheart_rate%2Fheart_rate_service.o%20.%2Fbluetooth%2Fprofiles%2Fdevice_info%2Fdevice_info_service.o%20.%2Fbluetooth%2Fprofiles%2Fbattery%2Fbattery_service.o%20.%2Fbluetooth%2Fhost%2Fconfig%2Fble_globals.o%20.%2Fbluetooth%2F-1%20hci_transport%2Fsource%2Fhcit_serial_interface.o%20.%2FCMSIS%2Fsystem_MKW41Z4.o%20-lm%20-lc%20-lgcc%20-lnosys%20-l_ble_kw41z_controller%20-l_ble_4-2_host_peripheral_cm0p%20-l_crypto_m0%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%20%E3%82%B5%E3%82%A4%E3%82%BA%20%E9%A0%98%E5%9F%9F%E3%82%B5%E3%82%A4%E3%82%BA%20%25age%20%E4%BD%BF%E7%94%A8%3CBR%20%2F%3EBootloader_region%3A%200%20GB%2016383%20B%200.00%25%3CBR%20%2F%3E%20TEXT_region1%3A%20192%20B%20192%20B%20100.00%25%3CBR%20%2F%3EBootFlags_region%3A4%20B%207%20B%2057.14%25%3CBR%20%2F%3E%20TEXT_region2%3A206644%20B%20239416%20B86.31%25%3CBR%20%2F%3E%20%E5%86%85%E9%83%A8%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%3A%200%20GB%20258047%20B%200.00%25%3CBR%20%2F%3E%20NVM_region%3A0%20GB%208191%20B%200.00%25%3CBR%20%2F%3E%20DATA_region%3A%2033304%20B%20128%20KB%2025.41%25%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3Ec%3A%2Fnxp%2Fmcuxpressoide_11.0.0_2516%2Fide%2Fplugins%2Fcom.nxp.mcuxpresso.tools.win32_11.0.0.201905131304%2Ftools%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F8.2.1%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Fld.exe%3A%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%20.dummy%20VMA%20%5B1ffffffb%2C20000002%5D%20%E3%81%8C%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%20.stack%20VMA%20%5B1ffffe18%2C20000217%5D%20%E3%81%A8%E9%87%8D%E8%A4%87%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3Ecollect2.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20ld%20%E3%81%8C%201%20%E3%81%A4%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EPRODUCT_INFO_region%3A%200%20GB%202047%20B%200.00%25%3CBR%20%2F%3Emake%3A%20***%20%5Bmakefile%3A75%3A%20OTS_v1.axf%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%3CBR%20%2F%3E%22make%20-r%20-j12%20all%22%20%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%202%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E17%3A13%3A22%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%202%20%E4%BB%B6%E3%80%81%E8%AD%A6%E5%91%8A%E3%81%8C%2013%20%E4%BB%B6%E3%80%82(8%E7%A7%92618ms%E3%81%8B%E3%81%8B%E3%81%A3%E3%81%9F)%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF.ld%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3ESDK%20USB-KW41Z%3C%2FSPAN%3E%E3%81%8B%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E5%B0%91%E3%81%97%E5%A4%A7%E3%81%8D%E3%81%99%E3%81%8E%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE512%2F2-16%20Ko%E3%81%AE105%25%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%9C%80%E9%81%A9%E5%8C%96%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%80%8C%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%8D%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%8C%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E3%81%AF%E6%80%9D%E3%82%8F%E3%81%AA%E3%81%84%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E5%85%A5%E5%8A%9B%E3%82%92%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E4%B8%8E%E3%81%88%E3%81%BE%E3%81%99....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%80%E3%83%9F%E3%83%BC%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-14-2020 10:29 AM
更新者:
