KW37_38_39_Bluetooth LE Range Performance.pdf
This document provides information on distance measurements depending of the Bluetooth LE data rate (1Mbps, 2Mbps, LR S=2 & LR S=8).
The FRDM-KW38 boards are used to perform the measurements.
Results are similar on KW37 and KW39.
Comments
%3CLINGO-SUB%20id%3D%22lingo-sub-1123110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW37_38_39_Bluetooth%20LE%20Range%20Performance.pdf%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20document%20provides%20information%20on%20distance%20measurements%20depending%20of%20the%20Bluetooth%20LE%20data%20rate%20(1Mbps%2C%202Mbps%2C%20LR%20S%3D2%20%26amp%3B%20LR%20S%3D8).%3C%2FP%3E%3CP%3EThe%20FRDM-KW38%20boards%20are%20used%20to%20perform%20the%20measurements.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EResults%20are%20similar%20on%20KW37%20and%20KW39.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%20300%25%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1123110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20document%20provides%20information%20on%20distance%20measurements%20depending%20of%20the%20Bluetooth%20LE%20data%20rate%20(1Mbps%2C%202Mbps%2C%20LR%20S%3D2%20%26amp%3B%20LR%20S%3D8).%3C%2FP%3E%3CP%3EThe%20FRDM-KW38%20boards%20are%20used%20to%20perform%20the%20measurements.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EResults%20are%20similar%20on%20KW37%20and%20KW39.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%20300%25%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1123110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EKW37%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KW37_38_39_Bluetooth%20LE%20Range%20Performance.pdf%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%234472c4%3B%22%3ETests%20video%20released%20here%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fvideo%2Fkw39-38-37-bluetooth-low-energy-long-range-field-tests%3AKW38-MEASUREMENT%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fvideo%2Fkw39-38-37-bluetooth-low-energy-long-range-field-tests%3AKW38-MEASUREMENT%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
100% helpful (2/2)
Version history
Last update:
‎05-11-2020 05:48 AM
Updated by:
