RW612 Matter Networking Example Demonstration
2,754件の閲覧回数
MrShen
I want to give an example recently. One RW612ET module is the host, and five RW612ET modules are the slaves. The five slaves collect data and send it to the host. The host is connected to the upper computer.
The host controls one of the slaves at the appropriate time, that is, the slave sends data to the host, and the host can also send data to the slaves.
These six modules form one network. May I ask which example of the host using the SDK library and which example of the slave using the SDK library?
6 返答(返信)
2,697件の閲覧回数
Christine_Li
Hello, @MrShen
Can you please check this doc and let me know whether it can meet your requirement?
RW612 Matter OTBR and Zigbee Bridge User Guide
Christine.
2,592件の閲覧回数
MrShen
Hello!
According to Build Matter OTBR and Zigbee Bridge application, execute git clone https://github.com/nxp-appcodehub/dm-matter-zigbee-bridge-rw612.git
The examples, src, and third_party folders were not found in the dm-mater-zigbee-bridge-rw612 file, dm-matter-zigbee-bridge-rw612/examples/bridge-app/nxp。
Many files are missing, which makes it impossible to execute and compile them later.屏幕截图 2025-11-14 192328.png屏幕截图 2025-11-14 192328.png
2,485件の閲覧回数
Christine_Li
Hi, @MrShen
Sorry for my late reply.
I am blocked by other higher priority issues.
I did same command locally, and found the same scenario.
Let me check internally, then update to you.
Christine.
2,473件の閲覧回数
Christine_Li
Hi, @MrShen
Sorry for the inconvenience to you.
I received our internal team's feedback that due to recent change in ACH Matter Zigbee Bridge, we need to update UG10185.
Can you please have a try with below command and let me know whether it works for you?
git clone -b rw612_with_external_transceiver https://github.com/nxp-appcodehub/dm-matter-zigbee-bridge-rw612.git
I tried on my local side, I can download it.
By the way, for your convenience, we have have an update README in below link:
https://github.com/nxp-appcodehub/dm-matter-zigbee-bridge-rw612/blob/rw612_with_external_transceiver...
Please let me know whether have any other concerns on this case, other wise, please do not hesitate to mark my answer as a solution, so that we can close this case.
Thanks!
Christine.
2,629件の閲覧回数
MrShen
Hello! The nxp file was not found in dm-matter-zigbee-bridge-rw612/examples/bridge-app/
2,740件の閲覧回数
MrShen
Should we use Matter or ZigBee? Did you not see ZigBee in the SDK import wizard?
%3CLINGO-SUB%20id%3D%22lingo-sub-2198802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW612%20%E3%83%9E%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%E3%81%AE%E4%BE%8B%E3%81%AE%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%80%E8%BF%91%E3%81%AE%E4%BE%8B%E3%82%92%E6%8C%99%E3%81%92%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%821%20%E3%81%A4%E3%81%AE%20RW612ET%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7%E3%80%815%20%E3%81%A4%E3%81%AE%20RW612ET%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%A7%E3%81%99%E3%80%825%20%E3%81%A4%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%8E%E9%9B%86%E3%81%97%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AF%E4%B8%8A%E4%BD%8D%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AF%E9%81%A9%E5%88%87%E3%81%AA%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A7%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AE%201%20%E3%81%A4%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AF%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%82%82%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%206%20%E3%81%A4%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%201%20%E3%81%A4%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%92%E5%BD%A2%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SDKs%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%E4%BE%8B%E3%81%A8%E3%80%81SDKs%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AE%E4%BE%8B%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW612%20Matter%20Networking%20Example%20Demonstration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3EBuild%20%E3%83%9E%E3%82%BF%E3%83%BC%20OTBR%E3%81%A8ZigBee%20Bridge%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-appcodehub%2Fdm-matter-zigbee-bridge-rw612.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-appcodehub%2Fdm-matter-zigbee-bridge-rw612.git%20%3C%2FA%3E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Edm-%E3%83%9E%E3%82%BF%E3%83%BC-ZigBee-bridge-rw612%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20(dm-%E3%83%9E%E3%82%BF%E3%83%BC-ZigBee-bridge-rw612%2Fexamples%2Fbridge-app%2Fnxp)%20%E3%81%AB%E3%80%81examples%E3%80%81src%E3%80%81third_party%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%BE%8C%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-14%20192328.png%22%20style%3D%22width%3A%20987px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-14%20192328.png%22%20style%3D%22width%3A%20987px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365718i61969086CC68B66F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-14%20192328.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-14%20192328.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-11-14%20192328.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW612%20Matter%20Networking%20Example%20Demonstration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81dm-matter-zigbee-bridge-rw612%2Fexamples%2Fbridge-app%2F%20%E3%81%AB%20nxp%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW612%20Matter%20Networking%20Example%20Demonstration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239904%22%20target%3D%22_blank%22%3E%40MrShen%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%80%81%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%9B%E3%82%8BCAN%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10185%26amp%3BisHTMLorPDF%3DHTML%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3ERW612%20Matter%20OTBR%20%E3%81%8A%E3%82%88%E3%81%B3%20Zigbee%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%82%AC%E3%82%A4%E3%83%89%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EChristine%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198833%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20RW612%20Matter%20Networking%20Example%20Demonstration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198833%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%9E%E3%82%BF%E3%83%BC%E3%81%A8ZigBee%E3%81%AE%E3%81%A9%E3%81%A1%E3%82%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3FSDK%20%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%20%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%81%AB%20ZigBee%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
