Firmware Loading Failure on NXP 88W9098 Module – Error “FW failed to be active in time!”
1,802件の閲覧回数
leo_green
Hi everyone,
I'm experiencing a persistent firmware loading issue with the NXP 88W9098 Wi‑Fi 6 module on my MCIMX8DXL-WEVK board. The module is set up in a dual MAC configuration (as shown in the output of lspci) and the system attempts to load the firmware file nxp/pcieuart9098_combo_v1.bin from /lib/firmware/nxp/. However, the firmware initialization fails with errors indicating that the firmware did not become active in time.
The image has just been build and flashed from the:
  • Repo Branch: imx-linux-scarthgap
  • Repo Manifest: imx-6.6.52-2.2.0.xml
  • Machine: imx8dxlb0-lpddr4-evk
  • Distro: fsl-imx-xwayland
  • Image version: core-image-base
Commands output:
root@imx8dxlb0-lpddr4-evk:~# lspci
00:00.0 PCI bridge: Freescale Semiconductor Inc Device 0000 (rev 01)
01:00.0 Ethernet controller: Marvell Technology Group Ltd. NXP 88W9098 Wi-Fi 6 (ax) MAC #1 (rev 03)
01:00.1 Ethernet controller: Marvell Technology Group Ltd. NXP 88W9098 Wi-Fi 6 (ax) MAC #2 (rev 03)
root@imx8dxlb0-lpddr4-evk:~# modprobe mlan
[ 246.609709] mlan: loading out-of-tree module taints kernel.
root@imx8dxlb0-lpddr4-evk:~# modprobe moal mod_para=nxp/wifi_mod_para.conf
[ 256.616753] wlan: Loading MWLAN driver
[ 256.621075] wlan: Register to Bus Driver...
[ 256.625803] wlan_pcie 0000:01:00.0: enabling device (0000 -> 0002)
[ 256.634743] PCI memory map Virt0: 00000000194e9329 PCI memory map Virt2: 00000000437baee5
[ 256.648503] Attach moal handle ops, card interface type: 0x206
[ 256.655420] rps set to 0 from module param
[ 256.661818] PCIE9098: init module param from usr cfg
[ 256.666990] card_type: PCIE9098, config block: 0
[ 256.671881] cfg80211_wext=0xf
[ 256.677598] max_vir_bss=1
[ 256.680254] cal_data_cfg=none
[ 256.685668] ps_mode = 0
[ 256.688146] auto_ds = 0
[ 256.692343] host_mlme=enable
[ 256.698043] fw_name=nxp/pcieuart9098_combo_v1.bin
[ 256.705954] rx_work=1 cpu_num=2
[ 256.709128] Enable moal_recv_amsdu_packet
[ 256.714450] Attach mlan adapter operations.card_type is 0x206.
[ 256.726000] Request firmware: nxp/pcieuart9098_combo_v1.bin
[ 257.164725] prog_fw: Failed to get command done interrupt retry count = 10001
[ 263.169563] FW failed to be active in time!
[ 263.173837] wlan_dnld_fw fail ret=0xffffffff
[ 263.178155] WLAN: Fail download FW with nowwait: 0
[ 263.183025] Config Space Registers:
[ 263.186568] reg:0x00 value=0x2b431b4b
[ 263.190280] reg:0x04 value=0x00100406
[ 263.193984] reg:0x10 value=0x7210000c
[ 263.197694] reg:0x18 value=0x7230000c
[ 263.201375] reg:0x2c value=0x2b431b4b
[ 263.205069] reg:0x3c value=0x0000015b
[ 263.208793] reg:0x44 value=0x00000008
[ 263.212490] reg:0x80 value=0x10120040
[ 263.216198] reg:0x98 value=0x00000000
[ 263.219919] reg:0x170 value=0x0001001e
[ 263.223706] FW Scrach Registers:
[ 263.226973] reg:0x1c90 value=0xfedcba00
[ 263.230864] reg:0x1c98 value=0x0
[ 263.234127] reg:0x1c9c value=0x0
[ 263.339445] reg:0x1c98 value=0x0
[ 263.342705] reg:0x1c9c value=0x0
[ 263.447733] Interface registers dump from offset 0x1c98 to 0x1c9f
[ 263.453884] PCIE registers from offset 0x1c20 to 0x1c9c:
[ 263.459233] 00000000 00000002 00000000 00000000 ffffffff 00000002 00000000 00000000
[ 263.467037] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 263.474851] acb420e0 00000000 00000010 00000000 008040e3 c8701424 00036ffc 00000000
[ 263.482645] 00000000 00000000 00000000 00000000 fedcba00 00000000 00000000 00000000
[ 263.490429]
[ 263.491932] ADMA Tx/Rx/Event/Cmd/CmdResp registers:
[ 263.496845] ADMA registers dump from offset 0x10000 to 0x10068
[ 263.502736] 00100000 acb420e0 00000000 c010ad64 00000000 00000000 00000000 00000000
[ 263.510521] 00000000 00000001 00000000 00000000 00000000 00000000 00000000 0000f002
[ 263.518316] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 263.526106] 80000948 00000000 00808c8c
[ 263.529976] ADMA registers dump from offset 0x10800 to 0x10868
[ 263.535890] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 263.543733] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000f000
[ 263.551542] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 263.559339] 80000948 00000000 00808c8c
[ 263.563213] ADMA registers dump from offset 0x10880 to 0x108e8
[ 263.569108] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 263.576905] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 263.584724] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 263.592519] 80000948 00000000 00000000
[ 263.596407] ADMA registers dump from offset 0x11000 to 0x11068
[ 263.602289] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 263.610084] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000f000
[ 263.617876] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 263.625673] 80000948 00000000 00808c8c
[ 263.629553] ADMA registers dump from offset 0x11080 to 0x110e8
[ 263.635444] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 263.643238] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 263.651036] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 263.658840] 80000948 00000000 00000000
[ 263.662818] woal_request_fw failed
[ 263.666276] Firmware Init Failed
[ 263.674525] Free module params
[ 263.677717] woal_pcie_probe: failed
[ 263.681220] wlan_pcie: probe of 0000:01:00.0 failed with error -14
[ 263.687724] wlan_pcie 0000:01:00.1: enabling device (0000 -> 0002)
[ 263.694113] PCI memory map Virt0: 00000000a6a2ddaa PCI memory map Virt2: 0000000048531485
[ 263.702376] Attach moal handle ops, card interface type: 0x206
[ 263.708263] rps set to 0 from module param
[ 263.712594] PCIE9098: init module param from usr cfg
[ 263.717682] card_type: PCIE9098, config block: 0
[ 263.722355] cfg80211_wext=0xf
[ 263.725330] max_vir_bss=1
[ 263.727982] cal_data_cfg=none
[ 263.730991] ps_mode = 0
[ 263.733447] auto_ds = 0
[ 263.735932] host_mlme=enable
[ 263.738866] fw_name=nxp/pcieuart9098_combo_v1.bin
[ 263.743638] rx_work=1 cpu_num=2
[ 263.746847] Enable moal_recv_amsdu_packet
[ 263.750931] Attach mlan adapter operations.card_type is 0x206.
[ 263.761930] Request firmware: nxp/pcieuart9098_combo_v1.bin
[ 264.116546] prog_fw: Failed to get command done interrupt retry count = 10001
[ 270.121561] FW failed to be active in time!
[ 270.125832] wlan_dnld_fw fail ret=0xffffffff
[ 270.130153] WLAN: Fail download FW with nowwait: 0
[ 270.135022] Config Space Registers:
[ 270.138558] reg:0x00 value=0x2b441b4b
[ 270.142278] reg:0x04 value=0x00100406
[ 270.145972] reg:0x10 value=0x7220000c
[ 270.149684] reg:0x18 value=0x72000004
[ 270.153364] reg:0x2c value=0x2b441b4b
[ 270.157051] reg:0x3c value=0x0000025c
[ 270.160771] reg:0x44 value=0x00000008
[ 270.164479] reg:0x80 value=0x10120040
[ 270.168187] reg:0x98 value=0x00000000
[ 270.171905] reg:0x170 value=0x0001001e
[ 270.175699] FW Scrach Registers:
[ 270.179010] reg:0x1c90 value=0xfedcba00
[ 270.182910] reg:0x1c98 value=0x0
[ 270.186193] reg:0x1c9c value=0x0
[ 270.291381] reg:0x1c98 value=0x0
[ 270.294641] reg:0x1c9c value=0x0
[ 270.399925] Interface registers dump from offset 0x1c98 to 0x1c9f
[ 270.406081] PCIE registers from offset 0x1c20 to 0x1c9c:
[ 270.411431] 00000000 00000002 00000000 00000000 ffffffff 00000002 00000000 00000000
[ 270.419232] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 270.427049] ac75d0e0 00000000 00000010 00000000 008040e3 c8701424 00000000 00000000
[ 270.434842] 00000000 00000000 00000000 00000000 fedcba00 00000000 00000000 00000000
[ 270.442628]
[ 270.444130] ADMA Tx/Rx/Event/Cmd/CmdResp registers:
[ 270.449045] ADMA registers dump from offset 0x10000 to 0x10068
[ 270.454936] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 270.462717] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000f000
[ 270.470516] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 270.478298] 80000948 00000000 00808c8c
[ 270.482170] ADMA registers dump from offset 0x10800 to 0x10868
[ 270.488067] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 270.495871] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000f000
[ 270.503675] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 270.511468] 80000948 00000000 00808c8c
[ 270.515343] ADMA registers dump from offset 0x10880 to 0x108e8
[ 270.521237] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 270.529031] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 270.536853] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 270.544647] 80000948 00000000 00000000
[ 270.548545] ADMA registers dump from offset 0x11000 to 0x11068
[ 270.554426] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 270.562221] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000f000
[ 270.570014] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 270.577800] 80000948 00000000 00808c8c
[ 270.581670] ADMA registers dump from offset 0x11080 to 0x110e8
[ 270.587558] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 270.595350] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 270.603147] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[ 270.610935] 80000948 00000000 00000000
[ 270.614932] woal_request_fw failed
[ 270.618375] Firmware Init Failed
[ 270.626475] Free module params
[ 270.629944] woal_pcie_probe: failed
[ 270.633453] wlan_pcie: probe of 0000:01:00.1 failed with error -14
[ 270.641682] wlan: Register to Bus Driver Done
[ 270.647363] wlan: Driver loaded successfully
Driver configuration is default:
SD9098_0 = {
cfg80211_wext=0xf
max_vir_bss=1
cal_data_cfg=none
ps_mode=1
auto_ds=1
host_mlme=1
fw_name=nxp/sdiouart9098_combo_v1.bin
SD9098_1 = {
cfg80211_wext=0xf
max_vir_bss=1
cal_data_cfg=none
ps_mode=1
auto_ds=1
host_mlme=1
Please assist.
Thank you!
1,776件の閲覧回数
leo_green
The problem is solved. I had to blacklist automatic bluetooth driver loading by adding:
blacklist btnxpuart
to the /etc/modprobe.d/blacklist.conf file.
1,777件の閲覧回数
leo_green
blacklist btnxpuart
1,795件の閲覧回数
leo_green
Sorry, I posted wrong configuration block for sd revision, but for pci it's very similar:
PCIE9098_0 = {
        cfg80211_wext=0xf
        max_vir_bss=1
        cal_data_cfg=none
        ps_mode=0
        auto_ds=0
        host_mlme=1
PCIE9098_1 = {
        cfg80211_wext=0xf
        max_vir_bss=1
        cal_data_cfg=none
        ps_mode=1
        auto_ds=1
        host_mlme=1
%3CLINGO-SUB%20id%3D%22lingo-sub-2067574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXP%2088W9098%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%20%E2%80%93%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8CFW%20failed%20to%20be%20active%20in%20time!%E3%80%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%3C%2FP%3E%3CP%20class%3D%22%22%3EMCIMX8DXL-WEVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AENXP%2088W9098%20Wi-Fi%206%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20MAC%20%E6%A7%8B%E6%88%90%20(lspci%20%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E5%8F%82%E7%85%A7)%20%E3%81%A7%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%20%2Flib%2Ffirmware%2Fnxp%2F%20%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20nxp%2Fpcieuart9098_combo_v1.bin%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E6%99%82%E9%96%93%E5%86%85%E3%81%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%89%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%8B%E3%82%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%3A%3C%2FSTRONG%3E%20imx-linux-scarthgap%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20%E3%83%9E%E3%83%8B%E3%83%95%E3%82%A7%E3%82%B9%E3%83%88%3A%3C%2FSTRONG%3E%20imx-6.6.52-2.2.0.xml%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3EMachine%3A%3C%2FSTRONG%3E%20imx8dxlb0-lpddr4-evk%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3A%3C%2FSTRONG%3E%20fsl-imx-xwayland%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%20%3C%2FSTRONG%3Ecore-image-base%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E5%87%BA%E5%8A%9B%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8dxlb0-lpddr4-evk%3A~%23%20lspci%0A00%3A00.0%20PCI%20bridge%3A%20Freescale%20Semiconductor%20Inc%20Device%200000%20(rev%2001)%0A01%3A00.0%20Ethernet%20controller%3A%20Marvell%20Technology%20Group%20Ltd.%20NXP%2088W9098%20Wi-Fi%206%20(ax)%20MAC%20%231%20(rev%2003)%0A01%3A00.1%20Ethernet%20controller%3A%20Marvell%20Technology%20Group%20Ltd.%20NXP%2088W9098%20Wi-Fi%206%20(ax)%20MAC%20%232%20(rev%2003)%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8dxlb0-lpddr4-evk%3A~%23%20modprobe%20mlan%0A%5B%20246.609709%5D%20mlan%3A%20loading%20out-of-tree%20module%20taints%20kernel.%0Aroot%40imx8dxlb0-lpddr4-evk%3A~%23%20modprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para.conf%0A%5B%20256.616753%5D%20wlan%3A%20Loading%20MWLAN%20driver%0A%5B%20256.621075%5D%20wlan%3A%20Register%20to%20Bus%20Driver...%0A%5B%20256.625803%5D%20wlan_pcie%200000%3A01%3A00.0%3A%20enabling%20device%20(0000%20-%26gt%3B%200002)%0A%5B%20256.634743%5D%20PCI%20memory%20map%20Virt0%3A%2000000000194e9329%20PCI%20memory%20map%20Virt2%3A%2000000000437baee5%0A%5B%20256.648503%5D%20Attach%20moal%20handle%20ops%2C%20card%20interface%20type%3A%200x206%0A%5B%20256.655420%5D%20rps%20set%20to%200%20from%20module%20param%0A%5B%20256.661818%5D%20PCIE9098%3A%20init%20module%20param%20from%20usr%20cfg%0A%5B%20256.666990%5D%20card_type%3A%20PCIE9098%2C%20config%20block%3A%200%0A%5B%20256.671881%5D%20cfg80211_wext%3D0xf%0A%5B%20256.677598%5D%20max_vir_bss%3D1%0A%5B%20256.680254%5D%20cal_data_cfg%3Dnone%0A%5B%20256.685668%5D%20ps_mode%20%3D%200%0A%5B%20256.688146%5D%20auto_ds%20%3D%200%0A%5B%20256.692343%5D%20host_mlme%3Denable%0A%5B%20256.698043%5D%20fw_name%3Dnxp%2Fpcieuart9098_combo_v1.bin%0A%5B%20256.705954%5D%20rx_work%3D1%20cpu_num%3D2%0A%5B%20256.709128%5D%20Enable%20moal_recv_amsdu_packet%0A%5B%20256.714450%5D%20Attach%20mlan%20adapter%20operations.card_type%20is%200x206.%0A%5B%20256.726000%5D%20Request%20firmware%3A%20nxp%2Fpcieuart9098_combo_v1.bin%0A%5B%20257.164725%5D%20prog_fw%3A%20Failed%20to%20get%20command%20done%20interrupt%20retry%20count%20%3D%2010001%0A%5B%20263.169563%5D%20FW%20failed%20to%20be%20active%20in%20time!%0A%5B%20263.173837%5D%20wlan_dnld_fw%20fail%20ret%3D0xffffffff%0A%5B%20263.178155%5D%20WLAN%3A%20Fail%20download%20FW%20with%20nowwait%3A%200%0A%5B%20263.183025%5D%20Config%20Space%20Registers%3A%0A%5B%20263.186568%5D%20reg%3A0x00%20value%3D0x2b431b4b%0A%5B%20263.190280%5D%20reg%3A0x04%20value%3D0x00100406%0A%5B%20263.193984%5D%20reg%3A0x10%20value%3D0x7210000c%0A%5B%20263.197694%5D%20reg%3A0x18%20value%3D0x7230000c%0A%5B%20263.201375%5D%20reg%3A0x2c%20value%3D0x2b431b4b%0A%5B%20263.205069%5D%20reg%3A0x3c%20value%3D0x0000015b%0A%5B%20263.208793%5D%20reg%3A0x44%20value%3D0x00000008%0A%5B%20263.212490%5D%20reg%3A0x80%20value%3D0x10120040%0A%5B%20263.216198%5D%20reg%3A0x98%20value%3D0x00000000%0A%5B%20263.219919%5D%20reg%3A0x170%20value%3D0x0001001e%0A%5B%20263.223706%5D%20FW%20Scrach%20Registers%3A%0A%5B%20263.226973%5D%20reg%3A0x1c90%20value%3D0xfedcba00%0A%5B%20263.230864%5D%20reg%3A0x1c98%20value%3D0x0%0A%5B%20263.234127%5D%20reg%3A0x1c9c%20value%3D0x0%0A%5B%20263.339445%5D%20reg%3A0x1c98%20value%3D0x0%0A%5B%20263.342705%5D%20reg%3A0x1c9c%20value%3D0x0%0A%5B%20263.447733%5D%20Interface%20registers%20dump%20from%20offset%200x1c98%20to%200x1c9f%0A%5B%20263.453884%5D%20PCIE%20registers%20from%20offset%200x1c20%20to%200x1c9c%3A%0A%5B%20263.459233%5D%2000000000%2000000002%2000000000%2000000000%20ffffffff%2000000002%2000000000%2000000000%0A%5B%20263.467037%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20263.474851%5D%20acb420e0%2000000000%2000000010%2000000000%20008040e3%20c8701424%2000036ffc%2000000000%0A%5B%20263.482645%5D%2000000000%2000000000%2000000000%2000000000%20fedcba00%2000000000%2000000000%2000000000%0A%5B%20263.490429%5D%0A%5B%20263.491932%5D%20ADMA%20Tx%2FRx%2FEvent%2FCmd%2FCmdResp%20registers%3A%0A%5B%20263.496845%5D%20ADMA%20registers%20dump%20from%20offset%200x10000%20to%200x10068%0A%5B%20263.502736%5D%2000100000%20acb420e0%2000000000%20c010ad64%2000000000%2000000000%2000000000%2000000000%0A%5B%20263.510521%5D%2000000000%2000000001%2000000000%2000000000%2000000000%2000000000%2000000000%200000f002%0A%5B%20263.518316%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%0A%5B%20263.526106%5D%2080000948%2000000000%2000808c8c%0A%5B%20263.529976%5D%20ADMA%20registers%20dump%20from%20offset%200x10800%20to%200x10868%0A%5B%20263.535890%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20263.543733%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%200000f000%0A%5B%20263.551542%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%0A%5B%20263.559339%5D%2080000948%2000000000%2000808c8c%0A%5B%20263.563213%5D%20ADMA%20registers%20dump%20from%20offset%200x10880%20to%200x108e8%0A%5B%20263.569108%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20263.576905%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20263.584724%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%0A%5B%20263.592519%5D%2080000948%2000000000%2000000000%0A%5B%20263.596407%5D%20ADMA%20registers%20dump%20from%20offset%200x11000%20to%200x11068%0A%5B%20263.602289%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20263.610084%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%200000f000%0A%5B%20263.617876%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%0A%5B%20263.625673%5D%2080000948%2000000000%2000808c8c%0A%5B%20263.629553%5D%20ADMA%20registers%20dump%20from%20offset%200x11080%20to%200x110e8%0A%5B%20263.635444%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20263.643238%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20263.651036%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%0A%5B%20263.658840%5D%2080000948%2000000000%2000000000%0A%5B%20263.662818%5D%20woal_request_fw%20failed%0A%5B%20263.666276%5D%20Firmware%20Init%20Failed%0A%5B%20263.674525%5D%20Free%20module%20params%0A%5B%20263.677717%5D%20woal_pcie_probe%3A%20failed%0A%5B%20263.681220%5D%20wlan_pcie%3A%20probe%20of%200000%3A01%3A00.0%20failed%20with%20error%20-14%0A%5B%20263.687724%5D%20wlan_pcie%200000%3A01%3A00.1%3A%20enabling%20device%20(0000%20-%26gt%3B%200002)%0A%5B%20263.694113%5D%20PCI%20memory%20map%20Virt0%3A%2000000000a6a2ddaa%20PCI%20memory%20map%20Virt2%3A%200000000048531485%0A%5B%20263.702376%5D%20Attach%20moal%20handle%20ops%2C%20card%20interface%20type%3A%200x206%0A%5B%20263.708263%5D%20rps%20set%20to%200%20from%20module%20param%0A%5B%20263.712594%5D%20PCIE9098%3A%20init%20module%20param%20from%20usr%20cfg%0A%5B%20263.717682%5D%20card_type%3A%20PCIE9098%2C%20config%20block%3A%200%0A%5B%20263.722355%5D%20cfg80211_wext%3D0xf%0A%5B%20263.725330%5D%20max_vir_bss%3D1%0A%5B%20263.727982%5D%20cal_data_cfg%3Dnone%0A%5B%20263.730991%5D%20ps_mode%20%3D%200%0A%5B%20263.733447%5D%20auto_ds%20%3D%200%0A%5B%20263.735932%5D%20host_mlme%3Denable%0A%5B%20263.738866%5D%20fw_name%3Dnxp%2Fpcieuart9098_combo_v1.bin%0A%5B%20263.743638%5D%20rx_work%3D1%20cpu_num%3D2%0A%5B%20263.746847%5D%20Enable%20moal_recv_amsdu_packet%0A%5B%20263.750931%5D%20Attach%20mlan%20adapter%20operations.card_type%20is%200x206.%0A%5B%20263.761930%5D%20Request%20firmware%3A%20nxp%2Fpcieuart9098_combo_v1.bin%0A%5B%20264.116546%5D%20prog_fw%3A%20Failed%20to%20get%20command%20done%20interrupt%20retry%20count%20%3D%2010001%0A%5B%20270.121561%5D%20FW%20failed%20to%20be%20active%20in%20time!%0A%5B%20270.125832%5D%20wlan_dnld_fw%20fail%20ret%3D0xffffffff%0A%5B%20270.130153%5D%20WLAN%3A%20Fail%20download%20FW%20with%20nowwait%3A%200%0A%5B%20270.135022%5D%20Config%20Space%20Registers%3A%0A%5B%20270.138558%5D%20reg%3A0x00%20value%3D0x2b441b4b%0A%5B%20270.142278%5D%20reg%3A0x04%20value%3D0x00100406%0A%5B%20270.145972%5D%20reg%3A0x10%20value%3D0x7220000c%0A%5B%20270.149684%5D%20reg%3A0x18%20value%3D0x72000004%0A%5B%20270.153364%5D%20reg%3A0x2c%20value%3D0x2b441b4b%0A%5B%20270.157051%5D%20reg%3A0x3c%20value%3D0x0000025c%0A%5B%20270.160771%5D%20reg%3A0x44%20value%3D0x00000008%0A%5B%20270.164479%5D%20reg%3A0x80%20value%3D0x10120040%0A%5B%20270.168187%5D%20reg%3A0x98%20value%3D0x00000000%0A%5B%20270.171905%5D%20reg%3A0x170%20value%3D0x0001001e%0A%5B%20270.175699%5D%20FW%20Scrach%20Registers%3A%0A%5B%20270.179010%5D%20reg%3A0x1c90%20value%3D0xfedcba00%0A%5B%20270.182910%5D%20reg%3A0x1c98%20value%3D0x0%0A%5B%20270.186193%5D%20reg%3A0x1c9c%20value%3D0x0%0A%5B%20270.291381%5D%20reg%3A0x1c98%20value%3D0x0%0A%5B%20270.294641%5D%20reg%3A0x1c9c%20value%3D0x0%0A%5B%20270.399925%5D%20Interface%20registers%20dump%20from%20offset%200x1c98%20to%200x1c9f%0A%5B%20270.406081%5D%20PCIE%20registers%20from%20offset%200x1c20%20to%200x1c9c%3A%0A%5B%20270.411431%5D%2000000000%2000000002%2000000000%2000000000%20ffffffff%2000000002%2000000000%2000000000%0A%5B%20270.419232%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20270.427049%5D%20ac75d0e0%2000000000%2000000010%2000000000%20008040e3%20c8701424%2000000000%2000000000%0A%5B%20270.434842%5D%2000000000%2000000000%2000000000%2000000000%20fedcba00%2000000000%2000000000%2000000000%0A%5B%20270.442628%5D%0A%5B%20270.444130%5D%20ADMA%20Tx%2FRx%2FEvent%2FCmd%2FCmdResp%20registers%3A%0A%5B%20270.449045%5D%20ADMA%20registers%20dump%20from%20offset%200x10000%20to%200x10068%0A%5B%20270.454936%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20270.462717%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%200000f000%0A%5B%20270.470516%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%0A%5B%20270.478298%5D%2080000948%2000000000%2000808c8c%0A%5B%20270.482170%5D%20ADMA%20registers%20dump%20from%20offset%200x10800%20to%200x10868%0A%5B%20270.488067%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20270.495871%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%200000f000%0A%5B%20270.503675%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%0A%5B%20270.511468%5D%2080000948%2000000000%2000808c8c%0A%5B%20270.515343%5D%20ADMA%20registers%20dump%20from%20offset%200x10880%20to%200x108e8%0A%5B%20270.521237%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20270.529031%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20270.536853%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%0A%5B%20270.544647%5D%2080000948%2000000000%2000000000%0A%5B%20270.548545%5D%20ADMA%20registers%20dump%20from%20offset%200x11000%20to%200x11068%0A%5B%20270.554426%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20270.562221%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%200000f000%0A%5B%20270.570014%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%0A%5B%20270.577800%5D%2080000948%2000000000%2000808c8c%0A%5B%20270.581670%5D%20ADMA%20registers%20dump%20from%20offset%200x11080%20to%200x110e8%0A%5B%20270.587558%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20270.595350%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%0A%5B%20270.603147%5D%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%0A%5B%20270.610935%5D%2080000948%2000000000%2000000000%0A%5B%20270.614932%5D%20woal_request_fw%20failed%0A%5B%20270.618375%5D%20Firmware%20Init%20Failed%0A%5B%20270.626475%5D%20Free%20module%20params%0A%5B%20270.629944%5D%20woal_pcie_probe%3A%20failed%0A%5B%20270.633453%5D%20wlan_pcie%3A%20probe%20of%200000%3A01%3A00.1%20failed%20with%20error%20-14%0A%5B%20270.641682%5D%20wlan%3A%20Register%20to%20Bus%20Driver%20Done%0A%5B%20270.647363%5D%20wlan%3A%20Driver%20loaded%20successfully%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E6%A7%8B%E6%88%90%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ESD9098_0%20%3D%20%7B%0Acfg80211_wext%3D0xf%0Amax_vir_bss%3D1%0Acal_data_cfg%3Dnone%0Aps_mode%3D1%0Aauto_ds%3D1%0Ahost_mlme%3D1%0Afw_name%3Dnxp%2Fsdiouart9098_combo_v1.bin%0A%7D%0A%0ASD9098_1%20%3D%20%7B%0Acfg80211_wext%3D0xf%0Amax_vir_bss%3D1%0Acal_data_cfg%3Dnone%0Aps_mode%3D1%0Aauto_ds%3D1%0Ahost_mlme%3D1%0Afw_name%3Dnxp%2Fsdiouart9098_combo_v1.bin%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ANXP%2088W9098%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%E2%80%93%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8CFW%E3%81%AF%E6%99%82%E9%96%93%E5%86%85%E3%81%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%E3%80%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Bluetooth%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E8%87%AA%E5%8B%95%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88btnxpuart%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%92%20%2Fetc%2Fmodprobe.d%2Fblacklist.conf%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ANXP%2088W9098%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%E2%80%93%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8CFW%E3%81%AF%E6%99%82%E9%96%93%E5%86%85%E3%81%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%E3%80%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81sd%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E9%96%93%E9%81%95%E3%81%88%E3%81%A6%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81pci%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BC%BC%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EPCIE9098_0%20%3D%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20cfg80211_wext%3D0xf%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20max_vir_bss%3D1%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20cal_data_cfg%3Dnone%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20ps_mode%3D0%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20auto_ds%3D0%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20host_mlme%3D1%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20fw_name%3Dnxp%2Fpcieuart9098_combo_v1.bin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cfg80211_wext%3D0xf%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20max_vir_bss%3D1%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20cal_data_cfg%3Dnone%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20ps_mode%3D1%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20auto_ds%3D1%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20host_mlme%3D1%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20fw_name%3Dnxp%2Fpcieuart9098_combo_v1.bin%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%7D%20%20%20%20%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
