AN14114: random errors
2,609 次查看
pierluigi_p
Senior Contributor I
Dear NXP support,
we are randomly observing the following error, trying the example from AN14144 on page 31:
root@compass:/proc/mwlan/adapter0# ifconfig wlan0 down
[ 106.985739] wlan: Received disassociation request on wlan0, reason: 3
[ 106.992290] wlan: REASON: (Deauth) Sending STA is leaving (or has left) IBSS or ESS
root@compass:/proc/mwlan/adapter0# echo "rf_test_mode=1" > config
root@compass:/proc/mwlan/adapter0# echo "radio_mode=0 11" > config
root@compass:/proc/mwlan/adapter0# echo "tx_antenna=1" > config
root@compass:/proc/mwlan/adapter0# echo "bw=0" > config
root@compass:/proc/mwlan/adapter0# echo "channel=6" > config
[ 164.581703] RFTM_COMMAND ERROR: 0xffffffff
Can you provide additional details about this error ?
Best Regards
Pier
标记 (2)
2,491 次查看
Christine_Li
Hi, @pierluigi_p
Thanks for providing me logs.
From your given log, I saw you are using this command:
echo "radio_mode=0 11" >> /proc/mwlan/adapter0/config
But it is for dual Wi-Fi radios only. IW611 is  1x1  radio.
Please have try with Table 3's mode index.
Please let me know whether it works for you.
Christine.
6 回复数
2,574 次查看
Christine_Li
Hi, @pierluigi_p
1.Firstly, I think there is a typo in your description, I believe you mean our AN14114, not AN14144. Am I right?
2.Which Wi-Fi product are you using? Is it IW611?
3.Can you please check whether /proc/mwlan/adapter0 is correct Wi-Fi interface? is there any other adapters in your /proc/mwlan/ directory? Or you can list all of the adapters to try which one is correct one.
4. You command is: echo "rf_test_mode=1" > config seems different with ours, can you please correct it and try again?
echo "rf_test_mode=1" >> /proc/mwlan/adapter1/config
echo "radio_mode=0 11" >> /proc/mwlan/adapter1/config
echo "tx_antenna=1" >> /proc/mwlan/adapter1/config
echo "bw=0" >> /proc/mwlan/adapter1/config
echo "channel=6" >> /proc/mwlan/adapter1/config
5. Totally reset your device, whether still can repro this issue?
To better understand what happened, could you please help to provide logs of this issue? like dmesg logs and console logs?
Christine.
2,532 次查看
pierluigi_p
Hi @Christine_Li,
  1. sorry for the typo, you are right: I wrote it correctly in the subject but wrongly in the body
  2. yes, WiFi is IW611
  3. /proc/mwlan/adapter0 is the only available adapter in the system: the Wifi itself is working fine and the problems is only related to the test mode
  4. attached you can find the logs got using ">>", but the error persists
  5. the error persists also after the reset
Please let me know if you need further details.
Best Regards
Pier
标记 (2)
2,519 次查看
pierluigi_p
2,492 次查看
Christine_Li
Hi, @pierluigi_p
Christine.
2,481 次查看
Marco8105
Hi Christine
I'm Marco, the engineer who is actually working with the device.
Yes, this hint solves the problem. Thanks.
But it's somewhat unfortunate, that the command syntax for the two channel device has the same form as for a one channel device, just the second parameter being obsolete. That's confusing. I would have expected an error to be returned already on the radio_mode command, not on the channel selection command.
And a list of error descriptions would also greatly help. May You can add that to AN14114.
best regards
        Marco
标记 (1)
2,464 次查看
Christine_Li
Hi, @Marco8105
Thanks for your reply.
Yes, I think so. It is a little confusing for the new users.
Think about your suggestions, and I will discuss with our internal team to see how to change the commands to better understanding and avoid confusions.
Thanks for your valuable suggestions.
Based on the issue has been resolved, would you mind me close this ticket?
Please help to mark my previous answer as a solution for this issue if there is no other queries on this case.
And please feel free to create new case to us if you meet any other issue during using our product.
Christine.
%3CLINGO-SUB%20id%3D%22lingo-sub-2170358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAN14114%EF%BC%9A%E9%9A%8F%E6%9C%BA%E8%AF%AF%E5%B7%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E4%BA%BA%E5%91%98%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%B0%9D%E8%AF%95%E7%AC%AC%2031%20%E9%A1%B5%20AN14144%20%E4%B8%AD%E7%9A%84%E7%A4%BA%E4%BE%8B%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9A%8F%E6%9C%BA%E8%A7%82%E5%AF%9F%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40compass%3A%2Fproc%2Fmwlan%2Fadapter0%23%20ifconfig%20wlan0%20down%3CBR%20%2F%3E%5B%20106.985739%5D%20wlan%EF%BC%9AReceived%20disassociation%20request%20on%20wlan0%2C%20reason%3A%203%3CBR%20%2F%3E%5B%20106.992290%5D%20wlan%EF%BC%9AREASON%3A%20(Deauth)%20Sending%20STA%20is%20leaving%20(or%20has%20left)%20IBSS%20or%20ESS%3CBR%20%2F%3Eroot%40compass%3A%2Fproc%2Fmwlan%2Fadapter0%23%20echo%22rf_test_mode%3D1%22%20%26gt%3B%20config%3CBR%20%2F%3Eroot%40compass%3A%2Fproc%2Fmwlan%2Fadapter0%23%20echo%22radio_mode%3D0%2011%22%20%26gt%3B%20config%3CBR%20%2F%3Eroot%40compass%EF%BC%9A%2Fproc%2Fmwlan%2Fadapter0%23%20echo%22tx_antenna%3D1%22%20%26gt%3B%20config%3CBR%20%2F%3Eroot%40compass%3A%2Fproc%2Fmwlan%2Fadapter0%23%20echo%22bw%3D0%22%20%26gt%3B%20config%3CBR%20%2F%3Eroot%40compass%3A%2Fproc%2Fmwlan%2Fadapter0%23%20echo%22channel%3D6%22%20%26gt%3B%20config%3CBR%20%2F%3E%5B%20164.581703%5D%3CSTRONG%3E%20RFTM_COMMAND%20ERROR%3A%200xffffffffffff%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E6%9C%89%E5%85%B3%E6%AD%A4%E9%94%99%E8%AF%AF%E7%9A%84%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E7%A0%81%E5%A4%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2173042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN14114%3A%20random%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254976%22%20target%3D%22_blank%22%3E%40Marco8105%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%83%B3%E6%98%AF%E7%9A%84%E3%80%82%E5%AF%B9%E4%BA%8E%E6%96%B0%E7%94%A8%E6%88%B7%E6%9D%A5%E8%AF%B4%EF%BC%8C%E8%BF%99%E6%9C%89%E7%82%B9%E4%BB%A4%E4%BA%BA%E5%9B%B0%E6%83%91%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E8%80%83%E8%99%91%E4%B8%80%E4%B8%8B%E4%BD%A0%E4%BB%AC%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E4%BC%9A%E4%B8%8E%E6%88%91%E4%BB%AC%E7%9A%84%E5%86%85%E9%83%A8%E5%9B%A2%E9%98%9F%E8%AE%A8%E8%AE%BA%E5%A6%82%E4%BD%95%E4%BF%AE%E6%94%B9%E5%91%BD%E4%BB%A4%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%9B%B4%E5%A5%BD%E5%9C%B0%E7%90%86%E8%A7%A3%E5%92%8C%E9%81%BF%E5%85%8D%E6%B7%B7%E6%B7%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%AE%9D%E8%B4%B5%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%89%B4%E4%BA%8E%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E4%BB%8B%E6%84%8F%E6%88%91%E5%85%B3%E9%97%AD%E6%AD%A4%E7%A5%A8%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%E5%85%B3%E4%BA%8E%E6%AD%A4%E6%A1%88%E4%BE%8B%E7%9A%84%E7%96%91%E9%97%AE%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%8A%A9%E5%B0%86%E6%88%91%E4%B9%8B%E5%89%8D%E7%9A%84%E7%AD%94%E6%A1%88%E6%A0%87%E8%AE%B0%E4%B8%BA%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%BA%A7%E5%93%81%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%87%E5%88%B0%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E9%9A%8F%E6%97%B6%E5%90%91%E6%88%91%E4%BB%AC%E6%8F%90%E4%BA%A4%E6%96%B0%E7%9A%84%E6%A1%88%E4%BE%8B%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN14114%3A%20random%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E9%87%8C%E6%96%AF%E8%92%82%E5%A8%9C%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%20Marco%EF%BC%8C%E9%82%A3%E4%B8%AA%E5%AE%9E%E9%99%85%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E8%AF%A5%E8%AE%BE%E5%A4%87%E7%9A%84%E5%B7%A5%E7%A8%8B%E5%B8%88%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E8%BF%99%E4%B8%AA%E6%8F%90%E7%A4%BA%E8%A7%A3%E5%86%B3%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%9C%89%E7%82%B9%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E5%8F%8C%E5%A3%B0%E9%81%93%E8%AE%BE%E5%A4%87%E7%9A%84%E5%91%BD%E4%BB%A4%E8%AF%AD%E6%B3%95%E4%B8%8E%E5%8D%95%E5%A3%B0%E9%81%93%E8%AE%BE%E5%A4%87%E7%9A%84%E5%91%BD%E4%BB%A4%E8%AF%AD%E6%B3%95%E7%9B%B8%E5%90%8C%EF%BC%8C%E5%8F%AA%E6%98%AF%E7%AC%AC%E4%BA%8C%E4%B8%AA%E5%8F%82%E6%95%B0%E5%B7%B2%E7%BB%8F%E8%BF%87%E6%97%B6%E4%BA%86%E3%80%82%E7%9C%9F%E8%AE%A9%E4%BA%BA%E5%9B%B0%E6%83%91%E3%80%82%E6%88%91%E6%9C%AC%E4%BB%A5%E4%B8%BA%E9%94%99%E8%AF%AF%E4%BC%9A%E5%9C%A8%20radio_mode%20%E5%91%BD%E4%BB%A4%E4%B8%AD%E8%BF%94%E5%9B%9E%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%9C%A8%E9%80%9A%E9%81%93%E9%80%89%E6%8B%A9%E5%91%BD%E4%BB%A4%E4%B8%AD%E8%BF%94%E5%9B%9E%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E8%83%BD%E6%8F%90%E4%BE%9B%E4%B8%80%E4%BB%BD%E9%94%99%E8%AF%AF%E6%8F%8F%E8%BF%B0%E6%B8%85%E5%8D%95%EF%BC%8C%E4%B9%9F%E4%BC%9A%E5%A4%A7%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%85%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%20AN14114%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%E9%A9%AC%E5%8F%AF%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN14114%3A%20random%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F60868%22%20target%3D%22_blank%22%3E%40pierluigi_p%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B8%BA%E6%88%91%E6%8F%90%E4%BE%9B%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%8E%E4%BD%A0%E6%8F%90%E4%BE%9B%E7%9A%84%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E4%BD%A0%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E8%BF%99%E6%9D%A1%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%0A%3CP%3Eecho%22radio_mode%3D0%2011%22%20%26gt%3B%20%26gt%3B%20%2Fproc%2Fmwlan%2Fadapter0%2Fconfig%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E5%AE%83%E5%8F%AA%E9%80%82%E7%94%A8%E4%BA%8E%E5%8F%8C%20Wi-Fi%20%E6%97%A0%E7%BA%BF%E7%BD%91%E7%BB%9C%E3%80%82IW611%20%E6%98%AF%3CSPAN%3E%201x1%20%3C%2FSPAN%3E%E6%97%A0%E7%BA%BF%E7%94%B5%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Christine_Li_0-1758248564575.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Christine_Li_0-1758248564575.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357648iA4FCD0E38AD040FD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Christine_Li_0-1758248564575.png%22%20alt%3D%22Christine_Li_0-1758248564575.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EChristine_Li_0-1758248564575.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Christine_Li_1-1758248761431.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Christine_Li_1-1758248761431.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357649i93EEE50112E2164D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Christine_Li_1-1758248761431.png%22%20alt%3D%22Christine_Li_1-1758248761431.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EChristine_Li_1-1758248761431.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E8%A1%A8%203%20%E7%9A%84%E6%A8%A1%E5%BC%8F%E7%B4%A2%E5%BC%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%AE%83%E6%98%AF%E5%90%A6%E9%80%82%E5%90%88%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171893%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN14114%3A%20random%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171893%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%89%80%E9%99%84%E6%97%A5%E5%BF%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN14114%3A%20random%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205377%22%20target%3D%22_blank%22%3E%40Christine_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3COL%3E%3CLI%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E5%86%99%E9%94%99%E4%BA%86%EF%BC%8C%E6%82%A8%E8%AF%B4%E5%BE%97%E5%AF%B9%EF%BC%9A%E6%88%91%E5%9C%A8%E4%B8%BB%E9%A2%98%E9%87%8C%E5%86%99%E5%AF%B9%E4%BA%86%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%AD%A3%E6%96%87%E9%87%8C%E5%86%99%E9%94%99%E4%BA%86%3C%2FLI%3E%3CLI%3E%E6%98%AF%E7%9A%84%EF%BC%8CWiFi%20%E6%98%AF%20IW611%3C%2FLI%3E%3CLI%3E%2Fproc%2Fmwlan%2Fadapter0%20%E6%98%AF%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%94%AF%E4%B8%80%E5%8F%AF%E7%94%A8%E7%9A%84%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%9AWifi%20%E6%9C%AC%E8%BA%AB%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E9%97%AE%E9%A2%98%E4%BB%85%E4%B8%8E%E6%B5%8B%E8%AF%95%E6%A8%A1%E5%BC%8F%E6%9C%89%E5%85%B3%E3%80%82%3C%2FLI%3E%3CLI%3E%22%26gt%3B%20%26gt%3B%20%22%20%EF%BC%8C%E4%BD%86%E9%94%99%E8%AF%AF%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FLI%3E%3CLI%3ERESET%E5%90%8E%E9%94%99%E8%AF%AF%E4%B9%9F%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E7%A0%81%E5%A4%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN14114%3A%20random%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F60868%22%20target%3D%22_blank%22%3E%40pierluigi_p%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E1.%E9%A6%96%E5%85%88%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E7%9A%84%E6%8F%8F%E8%BF%B0%E4%B8%AD%E6%9C%89%E4%B8%80%E4%B8%AA%E9%94%99%E5%88%AB%E5%AD%97%EF%BC%8C%E6%88%91%E7%9B%B8%E4%BF%A1%E6%82%A8%E6%8C%87%E7%9A%84%E6%98%AF%E6%88%91%E4%BB%AC%E7%9A%84%20AN14114%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20AN14144%E3%80%82%E6%88%91%E8%AF%B4%E5%BE%97%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E2.%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E7%A7%8D%20Wi-Fi%20%E4%BA%A7%E5%93%81%EF%BC%9F%E6%98%AF%20IW611%20%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E3.%E8%AF%B7%E6%A3%80%E6%9F%A5%3CSPAN%3E%2Fproc%2Fmwlan%2Fadapter0%E6%98%AF%E5%90%A6%E4%B8%BA%E6%AD%A3%E7%A1%AE%E7%9A%84%20Wi-Fi%20%E6%8E%A5%E5%8F%A3%EF%BC%8C%2Fproc%2Fmwlan%2F%E7%9B%AE%E5%BD%95%E4%B8%8B%E6%98%AF%E5%90%A6%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%9F%E6%88%96%E8%80%85%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%88%97%E5%87%BA%E6%89%80%E6%9C%89%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%8C%E7%9C%8B%E7%9C%8B%E5%93%AA%E4%B8%AA%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E4.%E6%82%A8%E7%9A%84%E5%91%BD%E4%BB%A4%E6%98%AF%EF%BC%9A%20echo%22rf_test_mode%3D1%22%20%26gt%3B%20%E9%85%8D%E7%BD%AE%E4%BC%BC%E4%B9%8E%E4%B8%8E%E6%88%91%E4%BB%AC%E7%9A%84%E4%B8%8D%E5%90%8C%EF%BC%8C%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E6%9B%B4%E6%AD%A3%E5%90%8E%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eecho%20%22rf_test_mode%3D1%22%20%26gt%3B%26gt%3B%20%2Fproc%2Fmwlan%2Fadapter1%2Fconfig%0Aecho%20%22radio_mode%3D0%2011%22%20%26gt%3B%26gt%3B%20%2Fproc%2Fmwlan%2Fadapter1%2Fconfig%0Aecho%20%22tx_antenna%3D1%22%20%26gt%3B%26gt%3B%20%2Fproc%2Fmwlan%2Fadapter1%2Fconfig%0Aecho%20%22bw%3D0%22%20%26gt%3B%26gt%3B%20%2Fproc%2Fmwlan%2Fadapter1%2Fconfig%0Aecho%20%22channel%3D6%22%20%26gt%3B%26gt%3B%20%2Fproc%2Fmwlan%2Fadapter1%2Fconfig%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E5%E3%80%82%E5%AE%8C%E5%85%A8%20RESET%20%E4%BD%A0%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%8C%E6%98%AF%E5%90%A6%E8%BF%98%E8%83%BD%E9%87%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%B8%BA%E4%BA%86%E6%9B%B4%E5%A5%BD%E5%9C%B0%E4%BA%86%E8%A7%A3%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%8C%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%B8%AE%E5%8A%A9%E6%8F%90%E4%BE%9B%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E6%97%A5%E5%BF%97%EF%BC%9F%E6%AF%94%E5%A6%82%20dmesg%20%E6%97%A5%E5%BF%97%E5%92%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E6%97%A5%E5%BF%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
