example lwip_dhcp_usb_bm and ZephyrRTOS
已解决
跳至解决方案
270 次查看
AndreiH
 I would like to know if its possbile to combine the sample:
in order to use the underlying support for USB Host RNDIS driver, on NXP board
Any help on this matter is appreciated.
Best regards.
标记 (6)
1 解答
243 次查看
DanielRuvalcaba
I'm afraid there isn't a direct way to integrate lwip_dhcp_bm example from MCUXpresso SDK into Zephyr. You will need to port the example including application, drivers and stack. Nevertheless, this action would require significant effort.
If you need this functionality in Zephyr, you’ll likely have to implement it yourself using Zephyr's native networking APIs.
I'm sorry for the inconvenience.
Daniel.
在原帖中查看解决方案
1 回复
244 次查看
DanielRuvalcaba
Daniel.
