There is a reset or interrupt source called "CM4 is in lockup". But what I cannot find in the Vybrid manual describing when can this happen.
When and why can this happen?
解決済! 解決策の投稿を見る。
Hi Yuri,
ARM M4 manual says "..The processor enters a lockup state if a fault occurs when executing the NMI or HardFault handlers. "
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0553a/BGBFCHGC.html
Thus it shouldn't be in the state just after system reset.
Hi Yuri,
