linux libmcc
6,249件の閲覧回数
Nouchi
Senior Contributor II
Is there libmcc module V2.0 for linux to match with libmcc MQX 4.1.2 ?
Emmanuel
5,611件の閲覧回数
timesyssupport
Hello all,
libmcc2 has been released for MQX 4.2
Sources for libmcc2 can be found at: http://repository.timesys.com/buildsources/l/libmcc2/
Sources for libmcc can be found at: http://repository.timesys.com/buildsources/l/libmcc/
Updated documentation can be found at: Vybrid MCC User Guide For MCC Version 2.0
10 返答(返信)
5,612件の閲覧回数
timesyssupport
Hello all,
5,611件の閲覧回数
mpfgregory
That's good news. My problem with the old libmcc was that it was released under GPLv2. I could not use it, otherwise I would have to release my project's source code. libmcc should be published under a less restrictive license like LGPLv2.
libmcc2 has 2 license files with it: GPLv2 and BSD. Does this mean it is now dual-licensed? If so, what about the the header comments in libmcc2.c and libmcc2.h? There only GPLv2 is mentioned.
5,611件の閲覧回数
timesyssupport
libmcc and libmcc2 are now both dual-license: GPLv2 or BSD.
Timesys Support
5,611件の閲覧回数
timesyssupport
Hello Emmanuel,
MCC 2.0 for use with Vybrid and MQX 4.1.2 has not yet been released. We will let you know when the release is available.
Timesys Support
5,611件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
Do you have an estimated due date?
5,611件の閲覧回数
timesyssupport
Hello Karina,
We are currently expecting the release in 1-2 months.
Timesys Support
5,611件の閲覧回数
mpfgregory
Any update on the release plan of MCC 2.0 for Linux?
5,611件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
Thanks  for let us know.
5,611件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport are you available to atttend this case?
5,611件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
Timesys Support do you have an update?
