Vybrid VBAT range
Vybrid VBAT range
2,040 次查看
Zwerg_nase
Could someone clarify if the minimum VBAT is actually only 3V? Vybrid's datasheet claims that "the target battery is a ~ 3V coin cell" whose voltage in fact may be < 3V.
1,864 次查看
naoumgitnik
Senior Contributor V
Privet, Andrey!
A new Datasheet revision (underway) will have this value changed to 2.4V.
Vsego horoshego, Naoum Gitnik.
1,865 次查看
naoumgitnik
Privet, Andrey!
1,864 次查看
Zwerg_nase
Privet from Sviblovo, Naoum)
Thanks for the quick answer!
Bud' zdorov!
Andrey Pavlenko
