Vybrid Tower PCB Stackup ?
2,261 次查看
ChrisNielsen
I can see the layer usage and ordering in the Gerbers but it doesn't show the actual layer spacings.  Would it be possible to post the stackup?  Thanks, Chris
标签 (5)
标记 (4)
2,060 次查看
naoumgitnik
Senior Contributor V
Hello Chris,
Attached is the stack-up and dielectric types.
I'd like to warn you, though - important here is impedance of the impedance-controlled traces; quite likely the customer would use different material and these data might be used for reference only.
Regards, Naoum Gitnik.
2,061 次查看
naoumgitnik
Hello Chris,
2,060 次查看
ChrisNielsen
Perfect.  Thanks and I appreciate the warning on dielectric constants.  I will be careful.
To help the next person, I put all the data in Excel and had it add up to ~62 mils to confirm that I understand the individual pieces properly (attached), Chris
