Vybrid Security SW
Vybrid Security SW
chrislaplante
Timesys can you provide some info on what is provided if anything for customers trying to implement the security and anti-tamper mechanisms on Vybrid?  I looked at the Timesys BSP and really all I could find is an AES driver. I am not sure what is available so a customer can make use of CAAM and Trustzone?
Labels (2)
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
CommunityBot
Community Manager
NXP Community!
timesyssupport
Senior Contributor II
Hello Christopher,
Can you describe some anticipated use cases here? At this time, there is not much in the way over leveraging CAAM or Trustzone; we anticipate services work at Timesys surrounding these items, which depending on your timeline may be available for your customer's implementation.
If it is a near-term need, then I would ask you contact Timesys directly to discuss dedicated services work.
Thank you,
Timesys Support
karina_valencia
NXP Apps Support
NXP Apps Support
chrislaplante​ did you get previous comment?
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ can you help to review this case?
