Just noticed that in the 'Software & Tools' section for the VF6xx of the Freescale website, the list of tools and IDE's seem to have gotten shorter.
Anything we should know about. Are some tools vendors stopping longer term support for the VF6xx???
Thanks.
Solved! Go to Solution.
As far as I know, DS-5 is the only IDE officially supported for the VYBRID_SAMPLE_CODE_SBCH.
However, for MQX, all those IDEs (IDE, IAR, Kiel and DS) are still supported
Which vendors did you notice no longer listed?
Generally noticed that the lists are shorter than when I previously saw that page.
If you want specifics, then I noticed that under IDE's IAR, Kiel, and even ARM's DS-5 are no longer listed on the page. Similar for other sections such as Emulators/Probes.
