SW Reset not working
1,557 次查看
neilsmith
HI,
Trying to force a reset using the SRC Control Register, setting the SW_RST bit, doesn't seem to be successful, the micro doesn't restart and requires a power cycle. We have the M4 as the primary core and A5 as secondary.
Is there anything we are not doing - e.g. putting the micro in a particular state before setting the SW_RST bit?
1,437 次查看
timesyssupport
Senior Contributor II
Hello Neil,
Can you clarify your system environment please? What OS is running on each core?
Allow us time to review, as I am aware of commits against upstream Linux kernel addressing SW_RST for Vybrid.
Timesys Support
1,438 次查看
timesyssupport
Hello Neil,
Timesys Support
1,437 次查看
neilsmith
Hi, thanks for the responses.
Happy to report it is now working, since we added some new bootloader code - i think the problem wasn't in the reset, it was in our startup code.
Cheers
1,437 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you help with this case?
