OpenVG MQX Vybrid - error when calling eglCreateWindowSurface
1,223件の閲覧回数
slw
My system includes the following components:
- Freescale MQX4.1
- Freescale Vybrid VF522
- OpenVG 0.7.0
When I want to use another colorformat than ARGB8888, I get the error EGL_NO_SURFACE, when calling eglCreateWindowSurface.
I get the error when using RGB888 or RGB565.
I don't have the OpenVG sources, so I don't know what's going wrong inside this function.
Any hints ?
Sebastian
ラベル(2)
854件の閲覧回数
slw
I have found a solution.
I first have to set the same color-format in the buffer-info of the fbdev-driver, cause they have to match and openvg-lib does not set itself this information.
fb = fopen("fbdev:0", NULL);
buf_info.FORMAT = FBDEV_COLOR_RGB888;
ioctl(fb, IO_IOCTL_FBDEV_SET_BUFFER_INFO, &buf_info);
//search for matching egl-config
eglCreateContext( ......);
Sebastian
3 返答(返信)
853件の閲覧回数
cyborgnegotiato
Senior Contributor II
ioseph_martinez could you assist with this question?
Jozef
854件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you  help with this case?
855件の閲覧回数
slw
Sebastian
