MCC support for kernel 4.1
20,628 次查看
Nouchi
Senior Contributor II
Multi-Core Communication  functionnalities will be supported in 4.1 kernel?
Emmanuel
19,357 次查看
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
23 回复数
1,185 次查看
Nouchi
Thanks for the answer. I will be very interested if you have some patches to make tests with MCC V2 on my kernel.
Emmanuel
1,185 次查看
timesyssupport
Hi Emmanuel,
Yes, we will provide patches when they are available.
Timesys Support
1,185 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ can you help to review this  case?
