I2C3 hangs after several write
3,567 次查看
carlovalgocela
Good Day!
I have added I2C3 in the kernel Linux-3.0.15-ts-armv71 with I2C3 clock set to 100Khz.
I'm having some issues with my A5 application were sending of I2C data results to SDA pin stuck to LOW.
This usually happens when a NACK is received. The only way to recover is to power reset the board.
Is there a way to send a stop command when a NACK is received so that we can restart sending?
标签 (2)
标记 (1)
5 回复数
3,298 次查看
timesyssupport
Senior Contributor II
Hello Carlo,
Are you able to, or have you already, provided your application in the Timesys Support queue for this issue? Are you able to do so, so our engineers can reproduce and investigate the behavior?
Thank you,
Timesys Support
3,298 次查看
timesyssupport
Hello Carlo,
We are reviewing here, and will follow up if we are able to reproduce without your custom application.
Timesys Support
3,298 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ do you have an update?
3,298 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
reminder
Timesys Support do you have an update?
3,299 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ can you attend this case?
