HAB with QuadSPI XIP
adamszalkowski
When booting on a VF6 using HAB, the Authenticate Data command fails with reason HAB_INV_ADDRESS.
Does HAB not support boot from QuadSPI with XIP?
The exact command was:
CA 00 14 00 // CMD_AUTHENTICATE
02 C5 00 00 // KEY=2, PRT=CMS, ENG=ANY
00 00 0A 74 // rel. addr of signature
20 00 00 00 // block1 address to verify
00 03 DC 00 // block1 length
Any ideas?
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
CommunityBot
Community Manager
NXP Community!
cyborgnegotiato
Senior Contributor II
Hi Adam,
As I know, Vybrid has HABv4 which support XIP.
Are you sure with this HAB_INV_ADDRESS fail reason? (just for information)
HAB_INV_ADDRESS mean you have some problem with address, for more information see the HAB4_API documentation.
Could you check this relative address? Is it correct?
Utkarsh Gupta could you suggest more?
Jozef
utkarsh_gupta
I agree with Josef. HAB_INV_ADDRESS issue occurs due to either misaligned target address or denied access to that address. Please check the regions of the image addresses being signed and IVT self or entry pointer is not null.
Gupta
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you attend this case?
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport do you have an update?
timesyssupport
Hello Karina,
      We reviewed the Vybrid Security reference manual and see nothing helpful/relevant. Does the Freescale Vybrid team have any input on this?
Timesys Support
karina_valencia
NXP Apps Support
NXP Apps Support
cyborgnegotiator can you  check this case and share your thoughts?
karina_valencia
NXP Apps Support
NXP Apps Support
Jozef Maslik any update?
karina_valencia
NXP Apps Support
NXP Apps Support
utkarshgupta-b45806 can you    share your thoughts about this case?
