Disable the SGI.
Disable the SGI.
5,335 次查看
takashitakahash
Hi community.
Our customer would like to disable the SGI.
In the current Integrity OS, SGI( Software-generated Interrupts) is enabled by default.
For SGI is not used in customer system, we want to disable.
Would you advice should be disabled in any such a procedure?
If you have any sample software I think want me to reference.
4,954 次查看
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
5 回复数
4,955 次查看
CommunityBot
Community Manager
NXP Community!
4,956 次查看
takashitakahash
Hello Jiri-san
Thank you for your information.
I talk to with taku-sann GIC settings.
Thank you,
Best.
T.Takahashi.
4,956 次查看
rendy
this looks like a question for Green Hills (developer of INTEGRITY RTOS).
Rene
4,956 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
rendy​ what is the next step here?
4,956 次查看
jiri-b36968
Hello Takashi-san,
this has  been discussed with Taku-san. It is depended on design of SoC (based on implementation or ARM GIC). It is not possible to disable SGI separately.
You can
- disable all interrupts or
- do not assert software interrupts
/Jiri
P.S. discussed internally here  Vybrid SGI implementation and SGI configuration on Vybrid
