DHCP not functional on Linux?
1,662 次查看
riz1231
Folks,
We are booting  Linux (uImage-3.0-ts-armv7l)  on Vybrid from SD card, but DHCP assignment does not work properly in the Linux and we are getting the following errors:
“DHCP/BOOTP : Reply not for us, op[2] xid[b7926695]”
We are using following Jumper settings on Tower Serial (TWR-SER) module:
J2 – Ethernet PHY Clock Select – 3-4 closed (50MHz)
J3 – CLOCKIN0 Driver Select  – 2-3 closed (Route 50MHz clock to CLOCKIN0)
J12 – Ethernet PHY Configuration– 9-10 closed (RMII Select)
Kindly help us sort out this issue or there is anything missing in the Jumper settings we are using on TWR-VF65GS10 and TWR-SER module.
Rizwan Rasheed
1,117 次查看
timesyssupport
Senior Contributor II
Hello Rizwan,
What host operating system are you using? Can you confirm that you were able to successfully follow the DHCP/TFTP setup instructions from the Vybrid Tower Getting Started Guide:
https://linuxlink.timesys.com/docs/gsg/twr_vf600#SECTION00054000000000000000
We will let you know the jumper settings used on the TWR-SER as well.
Timesys Support
1,117 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you help on this case?
