After using LPRUN mode to display a clock on an LCD, returning to normal mode crashes.
1,419 次查看
brianpaterson
During normal mode, it displays. All is well. We go to LPRUN mode to save power and only show a clock on the LCD
During LPRUN, the clock displays but on exiting back to normal mode, the DCU gives an under-run error condition. LCD goes black, system crashes.
System clock during LPRUN is set to 24MHz. Almost all peripherals are disabled.
Any thoughts?
Brian
1,338 次查看
brianpaterson
1,339 次查看
brianpaterson
Solved it.
