How to Add a Comment?
admin
Specialist II
You can add a comment to a discussion by clicking the option Reply at the bottom of the question or specific comment.
Or click the option Add Comment located at the bottom of any file:
You will automatically start participating in any conversation around your contribution, this means you will receive notifications if someone else replies to your comment or adds a comment to the publication you´ve just participated at.
You could also make use of @mentioning when adding a comment, this will trigger an email notification to the person being @mentioned.
Tags (2)
