Flow control with RPMsg
4,315 次查看
dlm080
How is flow-control supposed to work with RPMsg?  For example, I am using an I.MX8.  If an M-core continuously sends messages to the A-core side, and the A-core side does not read them, what happens?  I assume the message queues will eventually fill up.  Is there back-pressure on the M-core side, or a notification that it is writing over it's unread messages?  I'm not seeing this.  Is it my responsibility to have the A-core send RPMsg responses to let the M-core side know that the messages were received?
4,306 次查看
dlm080
I now understand that the user is responsible for flow control (ex: by sending response RPMsgs to indicate reception).
4,307 次查看
dlm080
