Community discussions are not available
16,432件の閲覧回数
Ansari
I have created community account with below mail id.
[email protected]
I have requested/discussed our issues in this community which are faced during our development process.
Now I could see my discussions(which is created) from the past 6 months only and I am not able so refer all of my previous discussions.
Please do the needful.
Ansari
37 返答(返信)
5,144件の閲覧回数
admin
Specialist II
Hi Abdul, are you able to access this thread? https://community.freescale.com/thread/335040 it has been copied from the original thread you are looking for.
5,144件の閲覧回数
Ansari
Hi Karla,
No. Am not able to access this thread too.
Ansari
5,144件の閲覧回数
admin
Specialist II
Hi Abdul, I have just share the document with you. Can you please confirm you are able to access?
5,144件の閲覧回数
Ansari
Hi Karla,
No.  Am not able to access you shared document.  I have got below message only.
Shared discussion:
Unauthorized
Ansari
5,144件の閲覧回数
admin
Specialist II
Hi Abdul, the support team share the document with you yesterday. Were you able to access it?
5,144件の閲覧回数
admin
Specialist II
Otherwise I will have to provide you with the PDF version of thread.
5,144件の閲覧回数
Ansari
Hi Karla,
Thank you for your input.
Am not able to access the document which is sent by the support team.
In addition, as you mentioned please share the private thread as a PDF version.
Ansari
5,144件の閲覧回数
admin
Specialist II
Hi Ansari, I have shared with you the community threads. Is there anything else missing?
5,144件の閲覧回数
Rodrigue
Hi DEnisse,
May I get it as well?
thanks!
5,144件の閲覧回数
eric_kang
Dear Rodrigue Simonneau,
I have the same issue for i.MX6Q/AC97/SSI.
And I know the Questioner/Ansari received the community thread contents as PDF format.
Could you provide the contents to me?
Eric.
5,144件の閲覧回数
Ansari
Hi Karla,
I have received the community threads as PDF format.
We are proceeding further regarding our AC97 issue.
Thank you for your kind support.
Ansari
5,144件の閲覧回数
Ansari
Yes. I have tried to access that private thread after logging in only.
Ansari
5,144件の閲覧回数
Ansari
Hi Karia,
Sorry for your in-convenience.  Please allow me to explain one again.
Case 1:
I have created one discussion(around 9 months back) with the topic "iMX6- Problem with stereo recording in AC97".  The thread link for the same is mentioned below.
https://community.freescale.com/thread/320711
In this discussion, we were requested for SDMA source code to fix the AC97 audio issue.  FYI, freescale not supporting AC97 audio codec.  So we informed the same in the discussion.  After escalating with our FAE, we got the SDMA (SDMA Scripts and tool.zip) source code.  Please note that, this discussion was going on around 6 months.   At the end,  this discussion was moved to private discussion since the source code is confidential.
Right now am not able to access both created thread (mentioned in the above link) as well as the private discussion.
We need the above mentioned discussion content and the private discussion content.  So that we can contact our local FAE to resolve our issue.
Case 2:
On 29Apr2015, I was looking in my i.MX community inbox for above mentioned thread(explained in Case1) and it is not available.
So I have created one more discussion with same  topic (which is mentioned in the Case1).  The topic name is "iMX6- Problem with stereo recording in AC97".  Please find the below link for the same and note that, both thread links(Case1 & Case2) are different.
https://community.freescale.com/thread/353851
In case2 thread, we have requested for latest BSP's SDMA source code by mentioning the Case1 thread link and we got the below response
"however Freescale does not disclose sources, you can try entering SR ticket. Also you should provide solid reasons why they are necessary for you."
If we have our Case1 thread link or content, we can easily contact our local FAE and community people regarding the SDMA source code.
Please suggest us to proceed further.
Ansari
5,144件の閲覧回数
Ansari
Thank you for your consideration on our request.
No. I am missing only above mentioned thread only.
Ansari
5,144件の閲覧回数
Ansari
I believe, I have created the above mentioned discussion.  I want to refer that discussion. Since we are having AC97 audio issue and I have discussed the same in that discussion.   Now we need to contact our local FAE with that discussion.
In addition, Please let us know why I couldn’t see all of discussions(24 publications in i.MX Community) in my inbox.
Ansari
5,144件の閲覧回数
Ansari
I could see only recent 14 publications in my community Inbox.
In addition, I didn't update the email address in community.
Ansari
5,144件の閲覧回数
Ansari
I have created discussions/questions in imx community.
I am not able to access all my(created by me) previous i.MX community discussions.
