Change Username
Change Username
0800200c9a66
Fresh Out Contributor
How can I change my username? It does not seem to be an option thru the Edit Profile view.
Tags (2)
LArmstrong1985
can you change my username in LArmstrong1985?
Thank you very much
ThanarajS
Can you change the username in my community profile? change to "ThanarajSubramani"
Thanaraj Subramani
0800200c9a66
Adrian, the username "Pete" is fine.
Adrian
Senior Contributor II
Sorry, that username is already taken.
Can you share another option?
0800200c9a66
Jaya?
Adrian
Jaya is already taken
0800200c9a66
how about 0800200C9A66 then?
This process really seems like this would be something better left to the user.
Adrian
0800200c9a66
Thanks.
Adrian
Hello 0800200c9a66‌,
Can you let me know the username that you want to use?
ThanarajS
Use User name: ThanarajSubramani
Thanaraj Subramani
