How to fill in the labels?
ycgxy1650601
Hi:
    I do not know how to fill in the labels when I want to post a new questions?
    As shown in the figure :20200911.JPG
le_flingue
hi ,
I have exactly the same problem for the same group (MPC5XXX) , is there any solution ?
ycgxy1650601
HI:
  Finally,I chose the other item for the "Select Location " combo box menu (MPC5XXX -> other) , because I could not find the better solution.
juanba
Same page as you.
So ?
Adrian
Senior Contributor IV
Labels will appear in a list under a new post just if those are available under the forum selected.
example under i.MX Forums.
ycgxy1650601
Hi:
    Thank you for your help.  I tried to post a question again,but the result is still the same.  There are not  lables.   As shown in the figure:no labels.JPG
thanks
