Can not be invited successfully by email for private space or group!
3,157 次查看
ada_lu
NXP Apps Support
NXP Apps Support
I met twice that I was invited by some private spaces or groups by email, but failed to add in after following up the steps in system mail. And at last the only way is to be invited by community ID.
I wonder if this function is OK? My explorer is Chrome. So does Microsoft IE as I have double confirmed with it. Some colleagues around my side have the similar issue.
B.R.
Ada
2,791 次查看
admin
Specialist II
Hi Ada, the thing here is that you were invited using your email account: [email protected]
When you already had a Community account ([email protected]), I've invited you using your existing account. You should be able to access with no issues.
Denisse
2,792 次查看
admin
Specialist II
Denisse
