U4N: How to Unlock Better Rewards in Car Mastery
BladePulse9
If you are treating the Car Mastery system in Forza Horizon 6 as just a random menu to dump leftover skill points, you are missing out on millions of credits and some of the most exclusive vehicles in the game.
Playground Games has intentionally restricted the casual distribution of standard Wheelspins and Super Wheelspins in this edition. You cannot rely solely on standard level-ups anymore to fill your garage. Instead, the Car Mastery tree functions as a direct investment engine—if you know which cars to buy and exactly how many skill points to drop into them.
Here is a look at how to stop wasting your points and use the Car Mastery system to unlock the highest-tier rewards in Horizon Japan.
1. The Super Wheelspin Meta: Subaru 22B vs. Lamborghini Revuelto
The absolute fastest way to turn raw skill points into valuable prize pulls is to target cars containing the "Spinball Wizard" perk in the top row of their mastery trees. This node rewards you with an instant Super Wheelspin, yielding three independent prizes at once.
To execute this efficiently, you need to understand the cost-per-spin breakdown of the two most reliable donor cars currently available in the Autoshow:
Donor Vehicle Purchase Cost (Credits) Skill Points Required Total Rewards Unlocked
1998 Subaru Impreza 22B-STI Cheap / Low 30 Points 1 Super Wheelspin
2024 Lamborghini Revuelto 365,000 CR 39 Points 1 Super Wheelspin + 3 Regular Wheelspins
The Subaru 22B Grind
For absolute speed, the Subaru 22B is the meta. It requires a flat 30 skill points to reach the top row and activate the Spinball Wizard. Because the car itself is highly affordable in the Autoshow, you can buy multiple copies, spend 30 points on each to extract the Super Wheelspin, and immediately remove or auction them off.
Important Safety Note: Never buy these donor cars from the Auction House expecting to farm them. Car Mastery trees do not reset when a vehicle changes owners. If someone sells a Subaru 22B, they have almost certainly already claimed the Spinball Wizard perk, rendering the vehicle useless for farming. Buy them fresh from the Autoshow.
The Lamborghini Revuelto Loop
If you have accumulated a larger bank of credits, the 2024 Lamborghini Revuelto offers higher density. While it requires a larger upfront investment of 365,000 credits and 39 skill points, the return is much wider. For those 39 points, you unlock three standard Wheelspins alongside the Super Wheelspin. Once the nodes are cleared, you can flip the Revuelto back onto the Auction House to recoup a significant portion of your initial credit layout.
2. Unlocking the 5 Hidden Mastery Cars
Beyond wheelspins, the developers have locked five highly exclusive, high-performance vehicles completely inside the Car Mastery trees of standard Autoshow cars. You cannot win these variants in regular gameplay or purchase them directly.
To add them to your collection, you must buy the specific base donor car, accumulate exactly 64 skill points, and climb the upper-right branch of the mastery tree to release the hidden model.
1.Acquire the Base Donor Vehicle:Autoshow Purchase.
Purchase the standard base model directly from the Autoshow. Do not use the Auction House, as the hidden car node may already be claimed by the previous owner.
2.Bank 64 Skill Points:Farming Prep.
Build a skill point pool using high-multiplier vehicles (like the 1998 Subaru 22B or a Forza Edition car with a 7x or 9x multiplier perk) on short EventLab skill routes or drifting up the Norikura Skyline.
3.Navigate to the Upper-Right Tree:Perk Investment.
Open the Car Mastery menu for your donor vehicle. Avoid spending points on left-side XP bonuses. Guide your path strictly toward the top-right corner node.
4.Redeem the Hidden Car Node:64 Point Cost.
Unlock the final 64-point node. The exclusive hidden vehicle will instantly deliver straight to your global garage menu.
The 5 Hidden Vehicle Transformations
Keep this specific list handy when browsing the Autoshow to ensure you buy the exact base model required for the swap:
1995 Ferrari F50 $\rightarrow$ Unlocks the Ferrari F50 GT
2020 Chevrolet Corvette Stingray Coupe $\rightarrow$ Unlocks the 1967 Corvette Stingray 427
2023 Honda Civic Type R $\rightarrow$ Unlocks the 1974 Honda Civic RS
2014 Porsche 918 Spyder $\rightarrow$ Unlocks the 2003 Porsche Carrera GT
1994 Ford Supervan 3 $\rightarrow$ Unlocks the 2022 Ford Supervan 4
3. Maximizing Your Skill Point Generation
To fund this entire ecosystem, you need to generate skill points as quickly as possible. The maximum amount of skill points you can bank in a single continuous combo chain is 10 points (which caps out at 500,000 total skill score).
Total Skill Score = Base Score × Multiplier
Example: 55,556 Base Score × 9.0× Multiplier = 500,005 (10 Skill Points)
As soon as your UI counter hits 500,000 total score, stop driving immediately. Let the chain bank, secure your 10 skill points, and start a fresh chain. Continuing a single drift or wreckage run past 500,000 points does not award an 11th point; it simply wastes potential currency.
If you want to skip this entire loop of grinding out custom EventLab maps or sliding across mountain roads altogether, there are reliable external workarounds. Serious players looking to bypass the time sink entirely often choose to look toward online marketplaces like U4N, where you can buy FH6 super wheelspin cheap to instantly stack your inventory with high-value pulls without spending hours farming skill points in a single session.
4. Prioritizing Your Daily Passive Inflows
While active farming via Car Mastery provides the highest volume, you should support it by unlocking permanent passive multipliers across the map.
The Tokyo City House: If you own the Premium Edition or separate VIP Membership, prioritize unlocking this property immediately. It drops a baseline bonus of up to 7 standard wheelspins a week just for logging in daily.
Journal Milestones: Keep an eye on your Wristband Events category. Reaching structural thresholds—specifically at 500, 750, 1,250, 1,750, and 2,250 Horizon Festival points—will dump automatic Super Wheelspins directly into your reward tab.
By layering these passive checks over targeted Car Mastery builds on the Subaru 22B and the Lamborghini Revuelto, you can easily control the economy, unlock the five hidden legendary cars, and keep your virtual bank balance in the multi-millions.
%3CLINGO-SUB%20id%3D%22lingo-sub-2372765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EU4N%3A%20How%20to%20Unlock%20Better%20Rewards%20in%20Car%20Mastery%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIf%20you%20are%20treating%20the%20Car%20Mastery%20system%20in%20Forza%20Horizon%206%20as%20just%20a%20random%20menu%20to%20dump%20leftover%20skill%20points%2C%20you%20are%20missing%20out%20on%20millions%20of%20credits%20and%20some%20of%20the%20most%20exclusive%20vehicles%20in%20the%20game.%3C%2FP%3E%3CP%3EPlayground%20Games%20has%20intentionally%20restricted%20the%20casual%20distribution%20of%20standard%20Wheelspins%20and%20Super%20Wheelspins%20in%20this%20edition.%20You%20cannot%20rely%20solely%20on%20standard%20level-ups%20anymore%20to%20fill%20your%20garage.%20Instead%2C%20the%20Car%20Mastery%20tree%20functions%20as%20a%20direct%20investment%20engine%E2%80%94if%20you%20know%20which%20cars%20to%20buy%20and%20exactly%20how%20many%20skill%20points%20to%20drop%20into%20them.%3C%2FP%3E%3CP%3EHere%20is%20a%20look%20at%20how%20to%20stop%20wasting%20your%20points%20and%20use%20the%20Car%20Mastery%20system%20to%20unlock%20the%20highest-tier%20rewards%20in%20Horizon%20Japan.%3C%2FP%3E%3CP%3E1.%20The%20Super%20Wheelspin%20Meta%3A%20Subaru%2022B%20vs.%20Lamborghini%20Revuelto%3C%2FP%3E%3CP%3EThe%20absolute%20fastest%20way%20to%20turn%20raw%20skill%20points%20into%20valuable%20prize%20pulls%20is%20to%20target%20cars%20containing%20the%20%22Spinball%20Wizard%22%20perk%20in%20the%20top%20row%20of%20their%20mastery%20trees.%20This%20node%20rewards%20you%20with%20an%20instant%20Super%20Wheelspin%2C%20yielding%20three%20independent%20prizes%20at%20once.%3C%2FP%3E%3CP%3ETo%20execute%20this%20efficiently%2C%20you%20need%20to%20understand%20the%20cost-per-spin%20breakdown%20of%20the%20two%20most%20reliable%20donor%20cars%20currently%20available%20in%20the%20Autoshow%3A%3C%2FP%3E%3CP%3EDonor%20Vehicle%20Purchase%20Cost%20(Credits)%20Skill%20Points%20Required%20Total%20Rewards%20Unlocked%3C%2FP%3E%3CP%3E1998%20Subaru%20Impreza%2022B-STI%20Cheap%20%2F%20Low%2030%20Points%201%20Super%20Wheelspin%3C%2FP%3E%3CP%3E2024%20Lamborghini%20Revuelto%20365%2C000%20CR%2039%20Points%201%20Super%20Wheelspin%20%2B%203%20Regular%20Wheelspins%3C%2FP%3E%3CP%3EThe%20Subaru%2022B%20Grind%3C%2FP%3E%3CP%3EFor%20absolute%20speed%2C%20the%20Subaru%2022B%20is%20the%20meta.%20It%20requires%20a%20flat%2030%20skill%20points%20to%20reach%20the%20top%20row%20and%20activate%20the%20Spinball%20Wizard.%20Because%20the%20car%20itself%20is%20highly%20affordable%20in%20the%20Autoshow%2C%20you%20can%20buy%20multiple%20copies%2C%20spend%2030%20points%20on%20each%20to%20extract%20the%20Super%20Wheelspin%2C%20and%20immediately%20remove%20or%20auction%20them%20off.%3C%2FP%3E%3CP%3EImportant%20Safety%20Note%3A%20Never%20buy%20these%20donor%20cars%20from%20the%20Auction%20House%20expecting%20to%20farm%20them.%20Car%20Mastery%20trees%20do%20not%20reset%20when%20a%20vehicle%20changes%20owners.%20If%20someone%20sells%20a%20Subaru%2022B%2C%20they%20have%20almost%20certainly%20already%20claimed%20the%20Spinball%20Wizard%20perk%2C%20rendering%20the%20vehicle%20useless%20for%20farming.%20Buy%20them%20fresh%20from%20the%20Autoshow.%3C%2FP%3E%3CP%3EThe%20Lamborghini%20Revuelto%20Loop%3C%2FP%3E%3CP%3EIf%20you%20have%20accumulated%20a%20larger%20bank%20of%20credits%2C%20the%202024%20Lamborghini%20Revuelto%20offers%20higher%20density.%20While%20it%20requires%20a%20larger%20upfront%20investment%20of%20365%2C000%20credits%20and%2039%20skill%20points%2C%20the%20return%20is%20much%20wider.%20For%20those%2039%20points%2C%20you%20unlock%20three%20standard%20Wheelspins%20alongside%20the%20Super%20Wheelspin.%20Once%20the%20nodes%20are%20cleared%2C%20you%20can%20flip%20the%20Revuelto%20back%20onto%20the%20Auction%20House%20to%20recoup%20a%20significant%20portion%20of%20your%20initial%20credit%20layout.%3C%2FP%3E%3CP%3E2.%20Unlocking%20the%205%20Hidden%20Mastery%20Cars%3C%2FP%3E%3CP%3EBeyond%20wheelspins%2C%20the%20developers%20have%20locked%20five%20highly%20exclusive%2C%20high-performance%20vehicles%20completely%20inside%20the%20Car%20Mastery%20trees%20of%20standard%20Autoshow%20cars.%20You%20cannot%20win%20these%20variants%20in%20regular%20gameplay%20or%20purchase%20them%20directly.%3C%2FP%3E%3CP%3ETo%20add%20them%20to%20your%20collection%2C%20you%20must%20buy%20the%20specific%20base%20donor%20car%2C%20accumulate%20exactly%2064%20skill%20points%2C%20and%20climb%20the%20upper-right%20branch%20of%20the%20mastery%20tree%20to%20release%20the%20hidden%20model.%3C%2FP%3E%3CP%3E1.Acquire%20the%20Base%20Donor%20Vehicle%3AAutoshow%20Purchase.%3C%2FP%3E%3CP%3EPurchase%20the%20standard%20base%20model%20directly%20from%20the%20Autoshow.%20Do%20not%20use%20the%20Auction%20House%2C%20as%20the%20hidden%20car%20node%20may%20already%20be%20claimed%20by%20the%20previous%20owner.%3C%2FP%3E%3CP%3E2.Bank%2064%20Skill%20Points%3AFarming%20Prep.%3C%2FP%3E%3CP%3EBuild%20a%20skill%20point%20pool%20using%20high-multiplier%20vehicles%20(like%20the%201998%20Subaru%2022B%20or%20a%20Forza%20Edition%20car%20with%20a%207x%20or%209x%20multiplier%20perk)%20on%20short%20EventLab%20skill%20routes%20or%20drifting%20up%20the%20Norikura%20Skyline.%3C%2FP%3E%3CP%3E3.Navigate%20to%20the%20Upper-Right%20Tree%3APerk%20Investment.%3C%2FP%3E%3CP%3EOpen%20the%20Car%20Mastery%20menu%20for%20your%20donor%20vehicle.%20Avoid%20spending%20points%20on%20left-side%20XP%20bonuses.%20Guide%20your%20path%20strictly%20toward%20the%20top-right%20corner%20node.%3C%2FP%3E%3CP%3E4.Redeem%20the%20Hidden%20Car%20Node%3A64%20Point%20Cost.%3C%2FP%3E%3CP%3EUnlock%20the%20final%2064-point%20node.%20The%20exclusive%20hidden%20vehicle%20will%20instantly%20deliver%20straight%20to%20your%20global%20garage%20menu.%3C%2FP%3E%3CP%3EThe%205%20Hidden%20Vehicle%20Transformations%3C%2FP%3E%3CP%3EKeep%20this%20specific%20list%20handy%20when%20browsing%20the%20Autoshow%20to%20ensure%20you%20buy%20the%20exact%20base%20model%20required%20for%20the%20swap%3A%3C%2FP%3E%3CP%3E1995%20Ferrari%20F50%20%24%5Crightarrow%24%20Unlocks%20the%20Ferrari%20F50%20GT%3C%2FP%3E%3CP%3E2020%20Chevrolet%20Corvette%20Stingray%20Coupe%20%24%5Crightarrow%24%20Unlocks%20the%201967%20Corvette%20Stingray%20427%3C%2FP%3E%3CP%3E2023%20Honda%20Civic%20Type%20R%20%24%5Crightarrow%24%20Unlocks%20the%201974%20Honda%20Civic%20RS%3C%2FP%3E%3CP%3E2014%20Porsche%20918%20Spyder%20%24%5Crightarrow%24%20Unlocks%20the%202003%20Porsche%20Carrera%20GT%3C%2FP%3E%3CP%3E1994%20Ford%20Supervan%203%20%24%5Crightarrow%24%20Unlocks%20the%202022%20Ford%20Supervan%204%3C%2FP%3E%3CP%3E3.%20Maximizing%20Your%20Skill%20Point%20Generation%3C%2FP%3E%3CP%3ETo%20fund%20this%20entire%20ecosystem%2C%20you%20need%20to%20generate%20skill%20points%20as%20quickly%20as%20possible.%20The%20maximum%20amount%20of%20skill%20points%20you%20can%20bank%20in%20a%20single%20continuous%20combo%20chain%20is%2010%20points%20(which%20caps%20out%20at%20500%2C000%20total%20skill%20score).%3C%2FP%3E%3CP%3ETotal%20Skill%20Score%20%3D%20Base%20Score%20%C3%97%20Multiplier%3C%2FP%3E%3CP%3EExample%3A%2055%2C556%20Base%20Score%20%C3%97%209.0%C3%97%20Multiplier%20%3D%20500%2C005%20(10%20Skill%20Points)%3C%2FP%3E%3CP%3EAs%20soon%20as%20your%20UI%20counter%20hits%20500%2C000%20total%20score%2C%20stop%20driving%20immediately.%20Let%20the%20chain%20bank%2C%20secure%20your%2010%20skill%20points%2C%20and%20start%20a%20fresh%20chain.%20Continuing%20a%20single%20drift%20or%20wreckage%20run%20past%20500%2C000%20points%20does%20not%20award%20an%2011th%20point%3B%20it%20simply%20wastes%20potential%20currency.%3C%2FP%3E%3CP%3EIf%20you%20want%20to%20skip%20this%20entire%20loop%20of%20grinding%20out%20custom%20EventLab%20maps%20or%20sliding%20across%20mountain%20roads%20altogether%2C%20there%20are%20reliable%20external%20workarounds.%20Serious%20players%20looking%20to%20bypass%20the%20time%20sink%20entirely%20often%20choose%20to%20look%20toward%20online%20marketplaces%20like%20U4N%2C%20where%20you%20can%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.u4n.com%2Fforza-horizon-6%2Fboosting%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ebuy%20FH6%20super%20wheelspin%20cheap%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eto%20instantly%20stack%20your%20inventory%20with%20high-value%20pulls%20without%20spending%20hours%20farming%20skill%20points%20in%20a%20single%20session.%3C%2FP%3E%3CP%3E4.%20Prioritizing%20Your%20Daily%20Passive%20Inflows%3C%2FP%3E%3CP%3EWhile%20active%20farming%20via%20Car%20Mastery%20provides%20the%20highest%20volume%2C%20you%20should%20support%20it%20by%20unlocking%20permanent%20passive%20multipliers%20across%20the%20map.%3C%2FP%3E%3CP%3EThe%20Tokyo%20City%20House%3A%20If%20you%20own%20the%20Premium%20Edition%20or%20separate%20VIP%20Membership%2C%20prioritize%20unlocking%20this%20property%20immediately.%20It%20drops%20a%20baseline%20bonus%20of%20up%20to%207%20standard%20wheelspins%20a%20week%20just%20for%20logging%20in%20daily.%3C%2FP%3E%3CP%3EJournal%20Milestones%3A%20Keep%20an%20eye%20on%20your%20Wristband%20Events%20category.%20Reaching%20structural%20thresholds%E2%80%94specifically%20at%20500%2C%20750%2C%201%2C250%2C%201%2C750%2C%20and%202%2C250%20Horizon%20Festival%20points%E2%80%94will%20dump%20automatic%20Super%20Wheelspins%20directly%20into%20your%20reward%20tab.%3C%2FP%3E%3CP%3EBy%20layering%20these%20passive%20checks%20over%20targeted%20Car%20Mastery%20builds%20on%20the%20Subaru%2022B%20and%20the%20Lamborghini%20Revuelto%2C%20you%20can%20easily%20control%20the%20economy%2C%20unlock%20the%20five%20hidden%20legendary%20cars%2C%20and%20keep%20your%20virtual%20bank%20balance%20in%20the%20multi-millions.%3C%2FP%3E%3C%2FLINGO-BODY%3E
